How to install S-Voice to galaxy nexus
Jutch
6
Hey everyone. I'm new to rooting and all this stuff so I have a question. How do I install the S-Voice app that was leaked to my rooted Galaxy Nexus. It is rooted but with stock 4.0.2 from verizon. Any help would be appreciated.
P.S. I already have the files downloaded and ready to go, I just don't know how to get it on there.
davidsnoodles
218
10
Depends, I've seen a flashable version of S-Voice and the apk. If you have the apk, just use a file browsing program (I use ASTRO) and install from there. If it's the flashable one (ends with .zip), go into your recovery and install .zip through recovery (aka Clockwork Mod).
Reactions: zero neck
Jutch
6
I have the zip one. It had a bunch of different files in there. Should I just put the whole zip file onto my galaxy and unzip it there?
svfd757
667
54
An expert I am not but what I did was download the file straight to my phone and flashed it in clock work recovery
2defmouze
3,945
1,552
Under security settings you have to make sure you check to allow installation from unknown sources as well.
As was pointed out.. S Voice is just a skinned vlingo (with the basic and beta versions combined a bit)
