jelly bean wifi tether
Irvgotti
836
39
Has anyone got a working WiFi tether? Or will the default one work since this is a port from the gsm and VZW has touched this. Would that allow it to be free or will it charge? I turned it on but didn't get a msg about adding hotspot to the plan like on my dads thunderbolt. So give me some info plz
Jet300
312
53
28
I would think if you get no warning you're good to go. In ICS if you turned in the hot spot via a widget and not from the settings menu it bypasses the carrier check and you get free wifi hot spot
How did you try and turn it on?
Chocu1a
177
9
Working fine on JB here, too. Just turned it on in settings & used it on my Acer a100. Connected right up & full 4G speeds.
Jet300
312
53
28
No I haven't tried because. Too afraid of tethering charges.
It works like it always has ... just download switchpro or any other widget from the market and use the built in tether. You may even be able to select it from the settings menu. If you don't get a warning from VZW when you activate the hotspot all is fine and you can tether free of charge.
Edit: Just tried it from the settings menu and it works like a champ. No need for the widget if ya dont want to.
andrewshah
Active member
May 16, 2012
35
5
For some reason Wifi tethering will not work whatsoever on Jellybean on my device. I've tried multiple apps from the Play Store as well as the tethering option in the settings menu. The only thing that works is USB tethering.
yugopalmguy
Active member
Dec 26, 2011
27
I loaded Razor's JB and the settings option did not work for me, however I switched over to Vicious V4 JB and it works perfectly with no warnings at all.
Cory S
69
3
I tried to tether my LTE GNex to my Nexus 7, it connects but the WiFi icon remains grey and it never gets internet access.
I'm running the latest Vicious 4.1.1 rom.
gregs1213
272
17
Does activating the wi-fi through settings go a lot slower for you guys as well? Not as in slow internet connection, but it takes a while to send out wifi-signal and connect.. This was true for me and my brother (both have rooted G.Nex on JB)..
Irvgotti
836
39
Maybe its the rom. Mine use to be slow. But its not anymore
drkrleitch
