Build 14 is out. I updated the OP. Best bet is to download from the hosted sites on your computer and transfer to your device, the OTA updater is hosed.
Ok, I downloaded and flashed this ROM tonight (figured I'd give it a try after giving Jedi a try for no other reason than just because I am obsessed with messing around with this phone lol). Everything appeared to install/flash correctly, but when it is reset, it gets hung in the animated intro (the jelly beans falling). Even after 20 min, it still is stuck there. I had flashed back to a stock rooted ROM, wiped dalvik, cache, and wiped data, so I don't know why in the world it's getting hung. Any ideas? Thanks!
I guess I'm gonna have to go back to Jedi tonight...
Did you do a system wipe? In TWRP recovery, (which I highly recommend) there are 4 options when wiping: cache, dalvik cache, factory reset, system. System wipe deletes the previous ROM, factory reset does not. Also make sure you downloaded a good file, not a corrupt or incomplete file. Let us know how it goes if you give it another shot.
Sent from my SCH-I605
Thanks! I think you nailed my issue and I will try how you described. I swear, I am a software engineer and have flashed a number of ROMS on various Android devices, but I still feel like I am such a beginner, ugh! I *think* I used the Factory Reset option with TWRP instead of System wipe, and I guess I ASSuMEd that flashing the stock rooted ROM would get me back to rooted stock (and wipe the ROM I was on). I will let you know how it goes, but it will probably be tonight before I can get to it. Thanks again!
My best guess is the system wipe was the issue. You don't need to flash a stock ROM when jumping from one ROM to another. The system wipe usually will take care of everything, in addition to the other 3 wipes. Good luck!
I was totally unaware of that (just having to system wipe to switch ROMs). I guess that is from not knowing the difference between Factory Reset and System wipe on TWRP. I just tried what you said (the System wipe was shockingly fast. Is it supposed to take a while?). I reset my phone and the animated Jelly Beans start up screen is still going, so I may have just downloaded a corrupt/incomplete file. Guess I will have to take care of that tonight when I am at home. Does the animated screen take a while the first time after installing the ROM?
Thanks again!
Just to be clear, cause I don't want to give you bad info...when switching from one ROM to another ROM, like from CleanROM to JELLYBEANS ROM, you need to wipe all 4 in TWRP:cache, dalvik, factory reset, system. You can't just wipe system and switch ROMs. When flashing a new build of the same ROM you are already running, like going from BEANS Build 13 to build 14, you can simply wipe cache and dalvik cache, then flash the new build. That's what they call a "dirty flash". 99% of the time the dirty flash works going from one version/build to another. Occasionally you may run into issues, but very rarely. You probably know all this, I just wanted to make sure I didn't mess you up!
So back to your flashing ...the animated boot up screen can take up to 5 minutes or more if this is a new ROM on your device. If you get stuck in the bootloop, you most likely have either a bad ROM file, or messed up in the flashing sequence in TWRP recovery. As long as you are familiar with what you are doing, its not a big deal. You can get back to a previous ROM and start over.
Awesome! Enjoy.
Anyone having problems with sd card swap after build 14?It won't let me do sd swap??
So just a short 2 weeks after my return to Android on a Note 2, I have decided to root, and would like to flash the Beans Rom. With the current one click option for the Root, that seems pretty easy and straight forward. Where I get a bit fuzzy/can't find directions is how to flash the new Rom once I have root? Do I just drop the file into the Phone memory and use TWRP to flash it? Or do I need a program on my PC to flash it? I tried searching, but was not able to find a real clear answer.
