06-27-2014 04:38 PM
180 ... 34567 ...
tools
  1. Droid_Evo_8's Avatar
    that is cool, to each their own. I just hate changing the battery, doesnt matter how big or small
    It's most helpful when you're on a long trip, especially when there's no available outlets around. (Like in camping)
    01-27-2013 09:40 PM
  2. dubge's Avatar
    ya I can see where that would be helpful, for me though, I dont have trips like that and when I go camping, the phone gets shut off
    01-27-2013 09:47 PM
  3. dt81's Avatar
    I only go camping if my Prevost bus can fit :-)
    01-27-2013 09:53 PM
  4. Droid_Evo_8's Avatar
    Me either, I rather replace my back cover if it breaks rather than that irreplacable charging port that needs to be replaced with the phone.
    01-27-2013 09:59 PM
  5. dubge's Avatar
    lol dont use your fist to take the cover off/on or plug it in and they should be fine, seriously I have never broken a cover or port and have the warranty/insurance if that happened
    01-28-2013 10:59 AM
  6. dt81's Avatar
    Gotta say.. so far I'm impressed with the battery. been 6 hours and I only went down 20 percent, using my phone normally. very impressed.
    fwhomeboy likes this.
    01-30-2013 03:39 PM
  7. dt81's Avatar
    one question... Your KernelOS, what percent of that is being used? when I check GSAM battery, it's always at the top with 14-18%. is that normal?
    01-30-2013 05:25 PM
  8. 7711's Avatar
    my experience with Li batteries is the cheap ones lose their ability to hold a charge faster. That experience was 7 years ago and maybe things have changed. I'm going to try one of the 6200 m batteries for summer outings.
    01-30-2013 06:53 PM
  9. jbomb's Avatar
    I purchased this battery and received it the model number on the battery is not the same as my Verizon note 2. Will it still work?
    It won't turn on when I put the battery in. Is that possibly because it shipped dead... I plugged in charger and nothing.
    Sent from my Note Dos.
    01-31-2013 12:26 AM
  10. jbomb's Avatar
    01-31-2013 12:28 AM
  11. Droid_Evo_8's Avatar
    Hmmm. I guess they don't come pre-charged a bit like the three 3500mah batteries that I bought from Amazon. Maybe try charging it for a few hours then see what happens. (Charge it with the phone off)
    01-31-2013 04:22 AM
  12. izhazissuez's Avatar
    Did you remove the yellow film on the connector area? I made that mistake
    Sent from my SCH-I605 using Tapatalk 2
    jbomb likes this.
    01-31-2013 04:32 AM
  13. dt81's Avatar
    What Brown guy said, there is a clear plastic cover over the connecting ports that's u have to remove.
    jbomb likes this.
    01-31-2013 04:53 AM
  14. jbomb's Avatar
    Thanks fellas that was it.
    01-31-2013 08:05 PM
  15. YukeYukeTroublemaker's Avatar
    I know others have asked before about my screen time during discharge and keep forgetting but here is an instance that i used the phone more on the light to moderate side...
    Attached Thumbnails 4000mah Ebay Battery review-screenshots_2013-01-31-22-12-08.png   4000mah Ebay Battery review-screenshots_2013-01-31-22-12-16.png
    02-01-2013 06:13 AM
  16. cdf3's Avatar
    Impressive!!
    02-01-2013 06:54 AM
  17. Roustermiller's Avatar
    Just ordered mine can't wait to get it
    Sent From My Galaxy Note 2 Using Tapatalk 2
    02-01-2013 08:52 AM
  18. fwhomeboy's Avatar
    BTW, there is a little plastic yellow film over the charging contacts so you gotta be sure to remove that first. It's almost undetectable.
    02-01-2013 09:45 AM
  19. dt81's Avatar
    I'm using this battery now for the second time after a full charge.. Been 7 hours and I'm at 82 percent. love this battery.
    02-01-2013 04:08 PM
  20. Tinmania's Avatar
    Wondering if they are the same 3500mah batteries that I got. Are yours 3.7v or 3.8 (like oem). Mine are 3.7v and while I am still running them through initial cycles they don't quite seem to last as long as my oem. Even so at the price I paid I am not really going to complain.
    Michael
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    02-01-2013 05:00 PM
  21. dt81's Avatar
    I purchased the 3500mah as well that u are talking about and they didn't last much longer than the stock. but this 4000mAh sure does!!!
    02-01-2013 06:22 PM
  22. fwhomeboy's Avatar
    Yes, I agree. This battery is great. Again I say it's worth 12 bucks anyday.
    02-01-2013 09:29 PM
  23. Droid_Evo_8's Avatar
    Michael
    Yes, you guys are correct. I just noticed it today that it doesn't last much longer than the stock battery it came with. (suprisingly) I guess I'm gonna have to buy a Samsung charger (and maybe another stock battery too) and maybe that 4000mah that you guys talking about.
    02-02-2013 12:16 AM
  24. dt81's Avatar
    I would. I just switched over to the 3500 for the night to do another cycle charge on the 4000. 17 hours and I finally hit 35 percent
    02-02-2013 12:42 AM
  25. jbomb's Avatar
    4000 review.
    Seems similar to stock on first cycle.
    02-02-2013 12:49 AM
180 ... 34567 ...
  1. Ebay/Amazon Replacement Battery Reviews?
    By Dave4321 in forum Samsung Galaxy S3
    Last Post: 07-18-2012, 05:47 PM
  2. Chinese Ebay batteries...Huge thumbs up
    By CEaton in forum EVO Accessories
    Last Post: 11-12-2010, 07:31 PM
  3. 3000 mah Chinese battery review
    By EVOLICIOUS in forum HTC EVO 4G
    Last Post: 08-04-2010, 11:36 PM
  4. Replies: 1
    Last Post: 07-19-2010, 12:34 PM
  5. 10 dollar ebay battery review...
    By youngzayiles in forum EVO Accessories
    Last Post: 07-12-2010, 09:51 PM
