Devils Advocate
I have noticed the battery problem since the "outage" I put that in quotes since I am not in a 4G area but I still like my Bolt.
just wondering if it was normal for the charge to go for 100 to 96 just after a few minutes after i take it off the charger. Don't know if i should take it back since ive only had it for four days and get a new. Any ideas? :-\
I moved to bamf 1.6.3 remix last night and have 70% battery remaining after setting up apps and screens. I would normally have 30% battery at this point in the day with minimal use. Switching roms helped a ton for me.
USB car chargers only output 500mAh - regardless of their rated output. The TB will see it as a USB host (like a PC/laptop) and will not draw any more power than that. Use a 1A car charger like this $5 charger from Motorola. The Verizon charger is rated at 750mAh out. If you're in your car using Nav or more, 750mAh will not keep up. The wall charger pushes 1A - get a car charger that matches.
