Wireless battery cover bulk
ShaggyKids
2,714
37
48
I'm thinking about using my coupon at Samsung to get a wireless battery cover for my note 3. It mentions in the description that when installed the cover will result in a very slight increase in the overall size of the device.
For those who have this cover just how much of an increase would you say there is?
Notes from Deb's Note 3
ShaggyKids
2,714
37
48
Do you find it charges rather quickly? For example slower or faster than the included charging cable that came with the phone?
I'm also wondering from those who use this kind of device charger if you notice any discoloration on the backside of the devices you charged with that?
beh
1,378
16
The difference is about 1/16th of an inch. Because the wireless back is sloped at the edges like the original back it is actually easier to pick it up off of a flat surface. The wireless back is not flexible like the original back so you can't "peel" it off but must work a finger nail or credit card around the periphery to remove it.
It charges very fast but only if you use the Samsung charging pad. This is not a conspiracy however, the Samsung branded charging pad is the only one I have found that has a 2 amp output. All the other charging pads, stands, etc. that I have found in my searching have an output range of 700 to 1000 mAmps (0,7 to 1.0 amps). These will charge the Note 3 but only if it is off and you are willing to wait much longer in my experience.
I have not found any discoloration of the back (mine is black in color) nor does the phone or the charger pad ever get above room temperature to the touch.
BBSeattle
1,315
12
Wireless seems to always be slower than cable. At the same time I find it more than reasonable for my needs.
I have never timed it but if I I am around 75% it takes about 30 minutes to get to 100%.
I have a wireless charger on my desk and in the car, I just drop it down on the charger and find myself rarely less than 80% battery throughout the day.
Discoloration, no.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
The Wireless charging back definitely adds some bulk. Many cases won't fit. With regards to charging rate, somewhere around 800 ma which is about 40% of stock.
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3
beh
1,378
16
I have found no need for a case for the Note 3 for me. I always keep it in my shirt pocket and the engineered material used for the back has such a great tactile feel so it doesn't slip from you hand I would never cover it up. Besides, after having the S3 and S4, both of which had great design styling, I would rather have a good looking phone and honor the artists that designed it than just have another brick in my hand. Just me, but I definitely like me. ;^)
smhism
151
To put it in some perspective, it adds enough bulk that the camera lens is ever so slightly recessed from the back cover. No case I've tried has fit it except for a bumper case that just goes along the outer edge. As far as speed of charging, I charge mine over night so I don't notice how long it really takes, but it would be a bit slower than using the cable charger that came with it. Also, I've no issues taking the wireless cover off simply by prying it up as I did the original cover.
Sent from my SM-N900V using AC Forums mobile app
Adrianb72
Active member
Mar 1, 2011
29
This. I love the feel of the phone now with the wireless charging cover. Perfect weight. Great tactile feel. Too pretty to cover up. Also, no Verizon logo!
beh
1,378
16
Amen to no Verizon logo. And as you indicated the Verizon back cover was much more "slippery" than any other brand version.
crazed_z06
71
4
I have one. In fact, you're probably reading the review I left on there.
I should revise my review because it adds a noticeable increase in size. It's not huge, but it's noticeable enough that I no longer use it :(
Non
