Verizon Galaxy S4 - WiFi Issues. 4.3?
1800getownd
So I recently got a GS4 and I'm having WiFi issues. WiFi worked for a day then I started getting "Your network connection is unstable" and wifi no longer worked. Researched this problem a bit and 4.3 seems to be the cause of it. I think it may be an app that kicks in that causes WiFi to fall off.
I tryed:
- restarting router
- fooling with router settings
- disabling caller id app
- turning off auto network switch option in WiFi
- factory reset phone, WiFi worked again then stopped after a while.
Anyone know of a fix for this? Is it possible to downgrade to 4.2?
tl;dr phones basically a potato without WiFi :/
Non
