After 18 months(?), the battery isn't going to hold up as well as it did when it was new, but 15% in 8 hours of doing nothing with the screen off seems a but much. (Not a lot, just a bit - 10% would be okay.)
In the morning, after starting at 100%, go to Settings/General/Battery and take a screen shot. (If there are more items, scroll down and take another screen shot. Then tap the graph at the top and take a screen shot. Post those screen shots here. (See
How To Post Screenshots on Android Central.) Then we'll see what we're talking about. (I have a Note 3, but still running 4.4.2, so I should be getting a little worse battery life than you are. I took mine off the charger about 2 hours ago and have been using it, and I'm down to 91% at the moment.)
If you can charge it overnight, then get through the day without fropping the battery below 40%, I wouldn't worry. (Leaving it on the charger all night won't hurt it - charging stops when the battery is fully charged. Dropping the battery down to 20% will shorten its life.)
If you can't do that, I'd buy a spar battery, keep it fully charged and in some sort of soft plastic case (Walmart sells thin transparent plastic by the yard, and it glues with plastic cement) in your pocket (it's what I do) then, if the battery drops to 40% and I still need to use the phone for a while, I swap batteries.
