Been having a couple issues with my Maxx over the last month +, and just want to know if anyone else is experiencing any of these. If so, any suggestions for a fix would be welcomed.
- Connectivity Drops - This has been an issue since the ICS update (was not an issue previous to that). All of a sudden, my phone decides it doesn't want to make a connection via wifi or 4G/3G and either won't load websites, won't load information in apps (such as FB, WeatherBug, etc), and occasionally won't make a phone call even if I'm in a coverage area (I get an immediate busy signal). As I said, this happens on both Wifi and 4G/3G. I can usually correct it by turning off/on my Wifi radio (I assume it forces the phone to select a signal to use). If that doesn't work, I need to reboot. This probably happens a couple times per week.
- Text Messaging - I use the native text app, and an annoyance is that I'll send a text to someone, and if I send another text to them while still in the conversation window, the keyboard will automatically insert the last word I typed in the previous message into the new message. I am using Swype as well, if that matters. I have tried clearing the text app cache, but that doesn't seem to do the trick.
- Text Messaging II - When I choose a contact to send a text to, it will display the phone number of the contact instead of the contact's name. If I remove, and re-add, the name will be displayed.
Anyone else run into these items, or know of a solution (aside from FR, which I would like to avoid)?
TIA.
TIA.
