How do you use the charger that came with it?
Sent from my VM670 using Tapatalk
Just use your normal charger.
After using mine for two months, it definitely lasts an incredible amount of time. If I try hard enough, I can get this baby to last 3 days with moderate use. The only glitch is that the battery meter will always be inaccurate. The battery percentage will fall to 1% as fast as it did with the original battery, then for the next day or two it will just sit at 1%. I've tried multiple battery stats wipes, offline recharge to complete discharge then another complete offline recharge and I've not been able to make the battery meter more accurate.
I wonder if that might be because the battery meter is voltage-based?
One of the two I have been using has become unusable. It has lasted nearly a year but I haven't been using my OV much since I received my G-nex. I left the battery on the charger for about 2 weeks and now its has swelled beyond the space for it within the phone. It works fine but the back won't stay on it just pops off.
I bought a new set of two batteries from Ebay by Anker. 2x 1600mAh with charger and have been surprised with the capacity these thing have. With low use I am seeing 1d 12h. And a full day with heavy use I am very happy since I am also back to the slim stock case.
Well, Gadgets-N-Gizmos refunded my money, so on your review I've purchased the 2x Anker batteries and charger off Ebay. Hopefully they will work out better.
