JtothaR
So what are you doing different that's giving you such great battery life? I'm sure everyone in this thread would love any suggestions/tips.
I use recent apps to close out of apps I'm not planning on using, I calibrate my battery repeatedly by running the phone dead and charging on an external charger until 100%. I keep the screen on low brightness unless I go outside. I set beautiful widgets to update weather every two hours. I don't need to know the weather every hour at work.
The external charger also came with a second battery so If I want to play music and surf on it for 6 hours straight and kill the battery fully it's no longer a problem. I just swap in a fully charged battery and keep going.
Also guys, you have to realize, the speed of this phone has caused me to use it for browsing instead of my tablet, use it for gaming, instead of my tablet, and listen to music all day at work (since it's capable of streaming audio instead of being choppy like past phones) My signal at work was barely usable by my old Motorola, but this phone stays locked on.
I'll take a wild guess that you guys are using the device more than your past devices also, because it's more usable. If the screen is on more than half the time between charges, you can't expect more than 10 hours out of it. Last night after I posted about my 2%. I killed the phone, swapped the battery out, turned it back on and had a 3 hour text conversation while listening to internet radio(screen was on for 3-4 hours straight). The phone dropped by 80% over 7 hours. This is to be expected.
Try that on your old phone and see what happens.
With extreme heavy use, I realize that I must adjust my expectations accordingly. With normal use it will easily go the whole day even with 4g on and low signal, which is awesome IMO.
-James
