ThreeofNine
Active member
Re: AT&T Galaxy S3 4.3 Update Likes/Issues
Hallelujah!!! "Move to SD card" is BACK! well for some apps anyway. I'll take it!
Would someone please let me know if it's possible to disable all the AT&T bloatware after this update, without root? Thank you in advance.
Foxfi is crashing though!
I am experiencing the same problem. Not just notifications of pic downloads. All downloads.
That really sucks.. It seems to have killed my FoxFi as well.. I knew I shouldn't have trusted AT&T to give me an update.. Grr!
If anyone knows a way to get around this without having to root, let me know. I can't root because this is a work phone and Mobile Iron won't work if rooted..
I downloaded Foxfi from play store (the one that specifies sprint/AT&T) and it is a newer build of 2.13.1 compared to 1.95.4 (which was working prior to the upgrade) and it seems to work now. I paid $7.95 for the full version.
Does this update install the new version of google maps?
I use maps all the time and hate the new version and am currently still using the old version, which I dont want to lose.
I uninstalled 1.95.4 and installed 2.13.1. I used my old 1.95.4 key to "unlock" 2.13.1. But it's still not working for me.
On the lock screen settings, you need to have Multiple widgets checked. Swipe the clock on the lock screen and then you should see the + to add a widget. Then you can add Dashclock and then move it to your main lockscreen page. It took me a little bit to figure it out.
Are you sure it is working? This version is also just giving me the notice about contacting AT&T about enabling tethering plans...
Sent from my Sero 7 Pro using Tapatalk 4
So, I've been living in 4.1.2 land for a while and one of the things I've heard about in newer Android versions is Photosphere. Is this available for AT&T GSIII or is it only for Nexus phones?
