Hello bionicdr,
Thank you for posting. I would like to help. I want to make sure I understand how you wish to configure the SW so I am going to restate it back using some very specific dialog:
Congfig:
CompanionLink build 5004
DejaOffice v 1.12.3
Android Device and OS ??? (Please respond with the specific info.)
A couple of things to note. If you change the Sync Method, you must do a Purge and Reload all on the next Sync. CompanionLink is not designed to randomly change the Sync method for a Sync profile, and doing that will cause a number of undesired results that lead to pretty complicated technical issues.
Can you please fill out the following items so I can be sure I understand you correctly:
Profile 1.
Box 1 Select the device you want to sync with = Bionic
Box 2 Select your Sync Method = companionlink pro / wifi
Box 3 Slect you PC Web Database = ACT 2011
Profile 2
Box 1 Select the device you want to sync with = Google
Box 2 Select your Sync Method = companikonlink pro
(this one is one way sync to google, only to eliminate duplicates)
Since I'm shooting for a purple sky here it would be wonderful If I could also sync my Nook (android Froyo)
I also have an exchange account on the phone, it only syncs back to outlook, I have yet to figure out how to send an appointment via deja Office calendar.
Thanks for your attempt to help.
Please respond with this information filed out and I can advise you what expected behavior is, and how to configure CompanionLink to what you want it to do, if it is possible.
