Double power button for camera...
jd4d
108
I'm running Q beta 5 on my 3XL and I'm on vacation and while trying to double tap the power button to open the camera, it's just sitting on a dark screen with the camera icon showing and it's very annoying and I'm missing some great opportunities at some pics. Is anyone else having this problem and is there a fix for it? Right now the only way to open the camera app is thru the icon. Thanks for reading.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,981
6,549
113
Oh wow that sucks , try restarting the phone ?
Mine been good.
Enjoy your vacation
dov1978
Trusted Member
Oct 22, 2012
1,749
Mine has done this fairly regularly on Beta 4&5
It's hit or miss whether the camera will fully open using the double tap from sleep. Usually it doesn't fully open when I really need it to for an opportunistic photo and the moment gets lost.
mrpackerguy
396
5
18
Did you go into Settings>system>gestures to make sure that function is enabled? It's called "Jump to Camera" and should be toggled on
Martin_F
102
I'm having the same issue on Q5.
I noticed when I would touch the fingerprint sensor right after, it would unlock the camera fine.
jd4d
108
Yes, I've got it enabled in the gesture settings. That's why I can't understand why it doing it. Could it be a bug in Q beta doing it in certain devices?
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,981
6,549
113
Try long pressing the camera app , tap info clear cache ,data, then force stop see if that works ,I know its beta and could be a bug but worth a try.
dov1978
Trusted Member
Oct 22, 2012
1,749
Definitely a bug. It happens less than it did in Beta 4 so hopefully it'll be completely fixed by Beta 6 or the official version in a month or so. It's just frustrating as like you say it can mean missing some really good photos because your screen is just sitting black with a camera icon on it while you lose your shot.
foxbat121
1,729
38
I had this happen to me from time to time on stock Android P as well. Not that I want to take pictures. But sometimes, I just want to wake up the phone and ended up with a blank screen. IIRC, press or swipe home button area helps to bring the home screen back.
jrussellcampbell
