Droid Razr Maxx HD stuck in left hand mode
A
AC Question
Don't know how I did it, but everything is flopped to what appears to be left hand mode on my Motorola Droid Maxx HD, Verizon, running 4.4.2. Anyone know how to flop it back?
Toid
Found the trick, settings, about phone, scroll to build number, tap 7 times. After the third tap a little dialog pops up saying you are almost there or something like that. This worked, my phone is back to right hand mode. Thanks!
N4Newbie
Trusted Member
Nov 15, 2012
5,006
You're welcome; however that doesn't change the fact that something is a bit odd here. So far as I know the phone should be in "normal" mode until you enable Developer mode and then deliberately force RTL (Right to Left) mode by checking the option noted above.
Just curious: was the option checked or unchecked when you first enabled developer mode?
justinedwards
