Headset and Speaker Problems
Hollowfax
4
I accodentally did something that when I plug in my earphones the sound goes through the external speakers, Im currently using sound about which works but I want to know a permanent solution to this problem and im using galaxy s3 rooted..
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Try setting Sound About to enable wired headset detection. Then (after backing the app up) uninstall Sound About and see if the phone works normally. If not, reinstall it, disable detection, restart the phone, enable it again, then uninstall it.
If the app can recognize the insertion (plugging in the headphone), the jack is okay - if it can't, the jack has to be replaced. If it's a software problem, the above will reset things.
justinedwards
