SFGiants 2010
100
17
Please I need some help here!
After reading about the bricked GB phones....I downloaded a Froyo radio and went into hboot to flash it and now I'm stuck in hboot! The radio will not flash! and everytime i click on reboot or power down i get the HTC screen and it just sends me right back into hboot!
Also there is a "Security Warning" at the top of the screen in purple!
Did I brick the phone?
SFGiants 2010
100
17
Thanks, I'm downloading the file as we speak.
So I would rename this file to PG051MG.zip, put it on the root of my sd card and then flash it through hboot?
nate44
812
206
The zip will download as: PG05IMG_MR1_upgrade.zip Just delete the bolded part. There is no 1 in the filename, and make sure you verify the md5 before you flash
Reactions: SoDev
SoDev
1,033
171
You are awesome for catching that (the 1). You're always helping everyone. You're the man.
Reactions: nate44
SFGiants 2010
100
17
Thanks for the help guys...once the file finishes downloading I'll try flashing it.
One quick question though, how do I confirm the md5 before I flash?
SFGiants 2010
100
17
Okay, I've tried flashing the PG05IMG_MR1_upgrade.zip with no luck.....it says checking PG05IMG.zip, then when the little gold bar to the left gets full, it reverts right back to the hboot screen.
Any thoughts?
nate44
812
206
ukfred
