HTC Backup not working
Legobricke
551
9
Do you see the file on Google Drive?
If so, how is it labeled?
I get "success" when I back up to Google Drive, I just don't see the file on Google drive...
What am I missing?
yassarikhan786
4
What am I missing?
It's kind of obfuscated and even after finding what seems to be the backup you can't see which files have been backed up.
Here's how you can (kind of) see the backup:
In Google Drives settings menu choose the Managing Apps option and you should see an entry called "HTC Services." You can either disconnect from HTC Services or delete the hidden app data.
I guess Google have hidden the data for security purposes, but if someone gains access to your Google Drive data they probably already have access to your Google account, which makes the obfuscation pointless. I'm not too worried about the reasons why the backup is hidden as long as I can successfully restore my device from it.
Legobricke
551
9
Ok.... I see the HTC Services.... Just wonder of there is anyway to unhide the file or folder.....
edusson
For what is worth... Was getting the same error, changing backup server didn't help. I couldn't update the HTC backup app either (was giving me an error, I think 504). So, just de-installed it and install the newest version, and everything works fine now!
Paul P4
What worked for me was...
when I went to settings> accounts and sync >HTC account was missing in the list
I tapped + symbol at the top > HTC account and then I tapped "Sign in with Google"
Then HTC account showed up in the list
Then back to settings> backup and reset>backup now
And it finally worked
Hope this helps someone
cottoneyejoe
