dss2000
Re: [Instruction]How to Keep Unlimited Data on Verizon
This is where some have had a slight hiccup. When some have put their dumb phone back on line 3 sometimes it seems like the SIM is still associated with line 3 and when you try to put that now free'd phone on line 1 it says it is still associated with another account. Usually a call to Verizon tech support and they will quickly free it up and you can put it on line #1. Others have resolved the problem by taking the SIM out of the line #1 phone and putting it in the new phone or another SIM they happen to have. But then others have had no such problem.
My theory and it's only speculation, nothing confirmed, is that there is kind of a bug in the system. When you put a smartphone on line #3 both the CDMA part and LTE part are associated with the line. The LTE part is associated with the SIM. If you put a dumb phone on the line #3 replacing the smartphone the CDMA part is free'd from line #3 but the LTE/SIM is still associated with line #3 and that is why if it has that SIM it has a problem being activated on line #1. When you call tech support they disassociated line #3 from the SIM which is how it gets free'd up to activate on line #1. To test my theory I would predict that if you put a 4G LTE back on line #3 instead of a dumb phone (not sure which iPhone you have but if it is a 4S I predict it would work) it would free up the CDMA part and the 4G part and that phone would have no problem activating on line #1. EIther way it's not a big problem, never had a problem calling Verizon to free up the new phone at this step if the problem occurs.
Okay, so I've researched this topic a bit more and I think I got it for the most part. Let me reiterate:
Line 1: Unlimited - Galaxy Nexus - (with upgrade)
Line 2: Unlimited (no upgrade)
Line 3: iPhone with 2 GB plan (mom's phone)
- First, I transfer the upgrade from Line 1 to Line 3. I upgrade the iPhone to the Moto X.
- When it gets here, I activate it on Line 3. Make sure a call goes through.
- Then, reactivate the iPhone.
This is where I'm concerned:
Then I go online, and go to the Switch Device page. I select the device on Line 1 and then click next. I then see a section entitled "Replace your current device by activating one without service." and select the bubble with "I am activating a device that I previously used with this account." The new Moto X should appear on the device history drop down box.
Now, after going through all that, will the SIM in the Moto X be linked to Line 1 or Line 3? I think I'll need to get a new SIM from Verizon or cut my SIM down to a Nano manually somehow. Is this correct?
Any help would be appreciated. Thanks guys.
