MannieInches
This has been the biggest peeve since the update. How am I supposed to take naughty pics of my lady friends and put them in Vaulty with shutter sounds all over the place !!! -_-
Perhaps it's this?
Sent from the cockpit of Gurren Lagann
That's wired although I had mine set before the update so wonder if that makes any difference.
Has anyone figured out a fix to the proximity issue when dealing with calls? It's beginning to become annoying...
Yes! hey, this is pretty decent for right now. I'm happy.
Sent from my EVO using Android Central Forums
Interesting, was messing around disabling apps. Disabled "Friend Stream" with no problem. Went back later to turn it back on to try something and the enable button is grayed out. Won't let you enable it again.
That is also a possibility. I can't recall which exact apps I had disabled prior to the update but I can tell you that AFTER the update, NO application was disabled.
Hmm did you do a reset, because the one ones I had selected remained disabled after update.
As I'm driving around, there's a notification pop up that shows drive time to home/work and distance...what is that?
Settings--Personalize--Skin..It changes with the skin you have selected.
Went back, took it off, then turned it back on (every time requires a pattern, fresh), still acts the same way. I am pressing "cancel" to prevent it from blocking text previews and such... I don't need it THAT secure.
I guess I will just have to add two more unlocking sessions to my routine every day to set the ringer up and then off. There are far more annoying things out there to deal with than this.
Was Internet Pass Through Available before? It allows you to use the Internet connection on the computer when you are connected via USB.
You can change your lock screen wallpaper to make it different from your main wallpaper.
You can block text messages and phone calls.
Sent from my EVO 4G LTE
I have to make some more corrections to your post. You *CAN* disable Stocks, and Mail (as well as Friend Stream, as I previously noted). I have not tried the others. So far, the only ones I cannot disable that I tried are Sprint Zone (like before the update), Flikr, and FM Radio.
