jrobinsky
Nm im a dope lol. I never ran setcpu. It doesn't say to do that in the guide, or atleast i didnt see it. Clocked it to 1200 and got a 1880 with NOTHING running. Any ideas why so low?
I've had success so far rooting and installing all the needed apps. I have a Verizon Fascinate and I'm not sure which kernel to choose? How do I know which one I need/want? I didn't understand the voltage options you posted.
Thanks
4th-day Android owner
Please remove the ext2 lagfix if you have it
If you have the lagfix that was posted here installed you should remove the lagfix as it is obsolete now that we have voodoo kernels.
If you are unsure if you have this installed or not please dont attempt anything without checking. If you have a voodoo kernel installed already then you do not need to continue.
[How to check(easy way)]
Download quadrant from the Market(its free)
run full benchmark
If you are getting scores below 1000 then skip ahead to install the new lagfix
If you are getting scores 1200+ there is a 99%+ chance you have the old lagfix installed unless you have already upgraded to the voodoo kernels.
If you are still unsure then you need check using the harder method
[How to check]
Download ConnectBot from the Market(its free) or use adb shell(for adb skip down to the command)
Open connectbot
Select local from the drop down menu should say ssh by default
Press and hold down where it says nickname (Long press)
Choose Input Method and select Android Keyboard (swype does not work very well in this app)
type root in the nickname text box
press done
it should open up an all black screen with a $ symbol at the top.
You are going to type in this command EXACTLY how I put it.
mount | busybox grep ext2
To get the | symbol hit ?123 button then Alt and it is where 3 would be
If you get a result besides the $ symbol then you have it installed. And should uninstall it if you want to use voodoo instead.
[How to uninstall]
Downloading the attached RyanZAEXT2LagFix ALPHA 1.zip
run unlagfix.bat
I'm a newbie to the world of android. The fascinate is my first android phone. I just applied the lag fix and WOW! I'm stunned at my quadrant scores.
This phone is a screamer even without the fix, so it's not very noticeable. Granted I just applied the lag fix moments ago.
Where should I see a performance boost besides my benchmark? And will this deplete the battery faster??
Thanks in advance!
ok so when i try to download the lagfix alpha .zip it takes me to a blank screen and nothing happens...no download no error message no nothing. any hope of a mirror link or someone throwing another link out there? i use google chrome if thats an issue. thx guys!
