Please remove the ext2 lagfix if you have it
If you have the lagfix that was posted here installed you should remove the lagfix as it is obsolete now that we have voodoo kernels.
If you are unsure if you have this installed or not please dont attempt anything without checking. If you have a voodoo kernel installed already then you do not need to continue.
[How to check(easy way)]
Download quadrant from the Market(its free)
run full benchmark
If you are getting scores below 1000 then skip ahead to install the new lagfix
If you are getting scores 1200+ there is a 99%+ chance you have the old lagfix installed unless you have already upgraded to the voodoo kernels.
If you are still unsure then you need check using the harder method
[How to check]
Download ConnectBot from the Market(its free) or use adb shell(for adb skip down to the command)
Open connectbot
Select local from the drop down menu should say ssh by default
Press and hold down where it says nickname (Long press)
Choose Input Method and select Android Keyboard (swype does not work very well in this app)
type root in the nickname text box
press done
it should open up an all black screen with a $ symbol at the top.
You are going to type in this command EXACTLY how I put it.
mount | busybox grep ext2
To get the | symbol hit ?123 button then Alt and it is where 3 would be
If you get a result besides the $ symbol then you have it installed. And should uninstall it if you want to use voodoo instead.
[How to uninstall]
Downloading the attached RyanZAEXT2LagFix ALPHA 1.zip
run unlagfix.bat
[How to install the new lagfix]
1. Root your phone. (Link in my signature)
2. Install ClockworkMod Recovery
http://forum.androidcentral.com/fascinate-roms-hacks/35726-clockworkmod-recovery.html#post353417
3. Get the Voodoo Kernel
To help figure out which Kernel is for you! Look here first
LV = Low Voltage
SV = Standard Voltage
Versions D02 Include bootanimations and allow you to use your own animation.
Versions D01 and D012 Do not allow for animations
Download a voodoo Kernel
https://docs.google.com/leaf?id=0BxkJ4zVcE6f_ODVkMjZmMzYtNjE5ZS00Y2RmLTgwZWEtOTIxNGQyNTliNTQ4&hl=en
And place it on your sdcard
You will need to download setcpu, and you should download it from the market and pay the $1 for the app because you paid $200 for the phone so dont pretend to be a cheap ***.
Boot into recovery (Volume Up + Down + Power)
You will see the samsung screen, let go.
It will open into the regular recovery
Click Apply update.zip (or something like that)
It will say verifying bs blah blah blah and magically clockworkmod opens (thanks koush)
Go to install zip from sdcard > Choose zip > Scroll down to the kernel you chose ie. D02-Kernel-LV-1250.zip and click on it. It will update and then you just need to restart your phone.
When restarting for the first time you will hear voices(not in your head) and it will take a
full 10 minutes. Just walk away after you hear the voice say step1
FAQ:
What is voodoo?
Project Voodoo, Galaxy S improvements | Open Source project homepage
Why are my scores lower when comparred to the original lagfix and why should I use the new voodoo lagfix instead?
Because it uses ext2 instead of ext4, which tricks benchmarks into over rating the filesystem. You will not notice a difference in real use speeds but ext4 is used because it is very stable and is less likely to loose your data. This lagfix unlike the other is an actual fix to how the kernel sets up the filesystem when it is started.
How do I uninstall it?
Make a new folder/file named disable_lagfix inside your voodoo folder on your sdcard. Then restart your phone.
Command: adb shell mkdir /sdcard/Voodoo/disable_lagfix
adb reboot
