--------- beginning of /dev/log/system
I/auditd ( 92): Starting up
I/audit_log( 92): Previous audit logfile not detected
I/Vold ( 89): Vold 2.1 (the revenge) firing up
D/Vold ( 89): Volume sdcard0 state changing -1 (Initializing) -> 0 (No-Media)
D/Vold ( 89): Volume sdcard0 state changing 0 (No-Media) -> 2 (Pending)
D/DirectVolume( 89): DirectVolume::handlePartitionAdded -> MAJOR 179, MINOR 1, PARTN 1
D/DirectVolume( 89): DirectVolume::handlePartitionAdded -> MAJOR 179, MINOR 2, PARTN 2
D/Vold ( 89): Volume sdcard0 state changing 2 (Pending) -> 1 (Idle-Unmounted)
--------- beginning of /dev/log/main
I/DEBUG ( 94): (no map for address)
I/DEBUG ( 94): 456c8000-456fe000 rw- /dev/ashmem/dalvik-aux-structure (deleted)
I/ServiceManager( 88): service 'media.audio_policy' died
I/ServiceManager( 88): service 'media.audio_flinger' died
I/ServiceManager( 88): service 'media.player' died
I/ServiceManager( 88): service 'media.camera' died
I/Netd (23398): Netd 1.0 starting
W/InterfaceController(23398): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/mediaserver(23399): ServiceManager: 0x1e404b8
I/AudioFlinger(23399): Using default 3000 mSec as standby time.
E/MediaPlayerFactory(23399): calling dlopen on FACTORY_LIB
E/MediaPlayerFactory(23399): Failed to open FACTORY_LIB Error : dlopen failed: library "libdashplayer.so" not found
I/CameraService(23399): CameraService started (pid=23399)
E/HAL (23399): load: module=/system/lib/hw/camera.msm7x27.so
E/HAL (23399): dlopen failed: could not load library "libcamera.so" needed by "camera.msm7x27.so"; caused by cannot locate symbol "_ZN7android10VectorImpl19reservedVectorImpl1Ev" referenced by "libcamera.so"...
E/CameraService(23399): Could not load camera HAL module
I/AudioPolicyManagerBase(23399): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
I/AudioHardwareMSM72XX(23399): get_audpp_filter
I/AudioHardwareMSM72XX(23399): open /system/etc/AudioFilter.csv success.
I/AudioHardwareMSM72XX(23399): EQ flag = 00.
I/AudioHardwareMSM72XX(23399): Set master volume to 7.
I/AudioFlinger(23399): loadHwModule() Loaded primary audio interface from QCOM Audio HW HAL (audio) handle 1
I/AudioFlinger(23399): HAL output buffer size 1200 frames, normal mix buffer size 1200 frames
I/AudioMixer(23399): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
I/AudioFlinger(23399): Using module 1 has the primary audio interface
D/AudioHardwareInterface(23399): setMode(NORMAL)
I/AudioFlinger(23399): AudioFlinger's thread 0x40e5a008 ready to run
W/AudioFlinger(23399): Thread AudioOut_2 cannot connect to the power manager service
I/AudioHardwareMSM72XX(23399): Routing audio to Speakerphone
D/AudioHardwareMSM72XX(23399): doAudioRouteOrMute() device 0, mMode 0, mMicMute 1, mBuiltinMicSelected 0, muted
D/AudioHardwareMSM72XX(23399): setVoiceVolume(0.000000)
I/AudioHardwareMSM72XX(23399): Setting in-call volume to 1 (available range is 0 to 7)
I/audio_a2dp_hw(23399): adev_open: adev_open in A2dp_hw module
I/AudioFlinger(23399): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
I/AudioPolicyService(23399): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/AndroidRuntime(23397):
D/AndroidRuntime(23397): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime(23397): CheckJNI is OFF
D/dalvikvm(23397): Trying to load lib libjavacore.so 0x0
D/dalvikvm(23397): Added shared lib libjavacore.so 0x0
D/dalvikvm(23397): Trying to load lib libnativehelper.so 0x0
D/dalvikvm(23397): Added shared lib libnativehelper.so 0x0
D/dalvikvm(23397): No JNI_OnLoad found in libnativehelper.so 0x0, skipping init
D/dalvikvm(23397): Note: class Landroid/app/ActivityManagerNative; has 180 unimplemented (abstract) methods
E/memtrack(23397): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug(23397): failed to load memtrack module: -2
I/SamplingProfilerIntegration(23397): Profiling disabled.
I/Zygote (23397): Preloading classes...
E/cutils-trace(23397): Error opening trace file: No such file or directory (2)
V/NatController(23398): runCmd(/system/bin/iptables -F natctrl_FORWARD) res=0
V/NatController(23398): runCmd(/system/bin/iptables -A natctrl_FORWARD -j DROP) res=0
V/NatController(23398): runCmd(/system/bin/iptables -t nat -F natctrl_nat_POSTROUTING) res=0
V/NatController(23398): runCmd(/system/bin/ip rule flush) res=0
V/NatController(23398): runCmd(/system/bin/ip -6 rule flush) res=0
V/NatController(23398): runCmd(/system/bin/ip rule add from all lookup default prio 32767) res=0
V/NatController(23398): runCmd(/system/bin/ip rule add from all lookup main prio 32766) res=0
V/NatController(23398): runCmd(/system/bin/ip -6 rule add from all lookup default prio 32767) res=0
V/NatController(23398): runCmd(/system/bin/ip -6 rule add from all lookup main prio 32766) res=0
V/NatController(23398): runCmd(/system/bin/ip route flush cache) res=0
V/NatController(23398): runCmd(/system/bin/iptables -F natctrl_tether_counters) res=0
V/NatController(23398): runCmd(/system/bin/iptables -X natctrl_tether_counters) res=0
V/NatController(23398): runCmd(/system/bin/iptables -N natctrl_tether_counters) res=0
D/MDnsDS (23398): MDnsSdListener::Hander starting up
D/MDnsDS (23398): MDnsSdListener starting to monitor
D/MDnsDS (23398): Going to poll with pollCount 1
D/TextLayoutCache(23397): Using debug level = 0 - Debug Enabled = 0
I/dalvikvm(23397): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI(23397): register_android_mtp_MtpDevice
W/dalvikvm(23397): Exception Ljava/lang/UnsatisfiedLinkError; thrown while initializing Landroid/media/videoeditor/MediaArtistNativeHelper;
W/Zygote (23397): Class not found for preloading: android.media.videoeditor.MediaArtistNativeHelper
E/EmojiFactory_jni(23397): Failed to load libemoji.so: dlopen failed: library "libemoji.so" not found
I/LibraryLoader(23397): loading: webviewchromium
W/WebViewFactory(23397): error preloading provider
W/WebViewFactory(23397): java.lang.RuntimeException: Cannot load WebView
W/WebViewFactory(23397): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:32)
W/WebViewFactory(23397): at com.android.webview.chromium.WebViewChromiumFactoryProvider.<init>(WebViewChromiumFactoryProvider.java:82)
W/WebViewFactory(23397): at java.lang.Class.newInstanceImpl(Native Method)
W/WebViewFactory(23397): at java.lang.Class.newInstance(Class.java:1208)
W/WebViewFactory(23397): at android.webkit.WebViewFactory$Preloader.<clinit>(WebViewFactory.java:43)
W/WebViewFactory(23397): at java.lang.Class.classForName(Native Method)
W/WebViewFactory(23397): at java.lang.Class.forName(Class.java:251)
W/WebViewFactory(23397): at java.lang.Class.forName(Class.java:216)
W/WebViewFactory(23397): at com.android.internal.os.ZygoteInit.preloadClasses(ZygoteInit.java:291)
W/WebViewFactory(23397): at com.android.internal.os.ZygoteInit.preload(ZygoteInit.java:231)
W/WebViewFactory(23397): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:566)
W/WebViewFactory(23397): at dalvik.system.NativeStart.main(Native Method)
W/WebViewFactory(23397): Caused by: com.android.org.chromium.content.common.ProcessInitException
W/WebViewFactory(23397): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:111)
W/WebViewFactory(23397): at com.android.org.chromium.content.app.LibraryLoader.loadNow(LibraryLoader.java:79)
W/WebViewFactory(23397): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:30)
W/WebViewFactory(23397): ... 11 more
W/WebViewFactory(23397): Caused by: java.lang.UnsatisfiedLinkError: Library webviewchromium not found; tried [/vendor/lib/libwebviewchromium.so, /system/lib/libwebviewchromium.so]
W/WebViewFactory(23397): at java.lang.Runtime.loadLibrary(Runtime.java:388)
W/WebViewFactory(23397): at java.lang.System.loadLibrary(System.java:526)
W/WebViewFactory(23397): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:105)
W/WebViewFactory(23397): ... 13 more
W/Zygote (23397): Class not found for preloading: java.lang.UnsafeByteSequence
I/System (23397): Loaded time zone names for "" in 296ms (268ms in ICU)
I/System (23397): Loaded time zone names for "en_US" in 204ms (174ms in ICU)
I/Zygote (23397): ...preloaded 2776 classes in 9181ms.
I/Zygote (23397): Preload resources disabled, skipped.
D/libEGL (23397): loaded /system/lib/egl/libEGL_adreno200.so
D/libEGL (23397): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
D/libEGL (23397): loaded /system/lib/egl/libGLESv2_adreno200.so
F/libc (23397): Fatal signal 11 (SIGSEGV) at 0x4194b008 (code=1), thread 23397 (zygote)
I/DEBUG ( 94): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG ( 94): Build fingerprint: 'lge/LS670/LS670:2.3.3/GRI40/LG-LS670-V20g.19C11F164C:user/release-keys'
I/DEBUG ( 94): Revision: '0'
I/DEBUG ( 94): pid: 23397, tid: 23397, name: zygote >>> zygote <<<
I/DEBUG ( 94): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 4194b008
I/DEBUG ( 94): r0 4194b008 r1 00000000 r2 000001c8 r3 80000000
I/DEBUG ( 94): r4 00000000 r5 00000000 r6 00000000 r7 00000000
I/DEBUG ( 94): r8 41626800 r9 00000006 sl 400b9ecc fp bea68a9c
I/DEBUG ( 94): ip 00000000 sp bea68580 lr 00000000 pc 401e82b8 cpsr a0000010
I/DEBUG ( 94): d0 42c393484d78abc4 d1 3f50624d00000061
I/DEBUG ( 94): d2 7e37e43c8800759c d3 7e37e43c8800759c
I/DEBUG ( 94): d4 8000000000000000 d5 3fbc71c71c71c71c
I/DEBUG ( 94): d6 4a1f2640fee00000 d7 42c800004a22c000
I/DEBUG ( 94): d8 0000000000000000 d9 0000000000000000
I/DEBUG ( 94): d10 0000000000000000 d11 0000000000000000
I/DEBUG ( 94): d12 0000000000000000 d13 0000000000000000
I/DEBUG ( 94): d14 0000000000000000 d15 0000000000000000
I/DEBUG ( 94): scr 80000010
I/DEBUG ( 94):
I/DEBUG ( 94): backtrace:
I/DEBUG ( 94): #00 pc 000222b8 /system/lib/libc.so (memset+112)
I/DEBUG ( 94): #01 pc 00071aa9 /system/lib/libdvm.so (create_mspace_with_base+72)
I/DEBUG ( 94): #02 pc 00073af3 /system/lib/libdvm.so
I/DEBUG ( 94): #03 pc 00074257 /system/lib/libdvm.so (dvmHeapSourceStartupBeforeFork()+346)
I/DEBUG ( 94): #04 pc 000564c3 /system/lib/libdvm.so (dvmGcPreZygoteFork()+2)
I/DEBUG ( 94): #05 pc 00067c03 /system/lib/libdvm.so
I/DEBUG ( 94): #06 pc 000681c9 /system/lib/libdvm.so
I/DEBUG ( 94): #07 pc 000504d3 /system/lib/libdvm.so (dvmResolveNativeMethod(unsigned int const*, JValue*, Method const*, Thread*)+114)
I/DEBUG ( 94): #08 pc 00027aa0 /system/lib/libdvm.so
I/DEBUG ( 94): #09 pc 0002e9dc /system/lib/libdvm.so (dvmMterpStd(Thread*)+76)
I/DEBUG ( 94): #10 pc 0002c0bc /system/lib/libdvm.so (dvmInterpret(Thread*, Method const*, JValue*)+184)
I/DEBUG ( 94): #11 pc 00061909 /system/lib/libdvm.so (dvmCallMethodV(Thread*, Method const*, Object*, bool, JValue*, std::__va_list)+320)
I/DEBUG ( 94): #12 pc 0004a623 /system/lib/libdvm.so
I/DEBUG ( 94): #13 pc 0004e51d /system/lib/libandroid_runtime.so
I/DEBUG ( 94): #14 pc 0004f225 /system/lib/libandroid_runtime.so (android::AndroidRuntime::start(char const*, char const*)+364)
I/DEBUG ( 94): #15 pc 00001035 /system/bin/app_process
I/DEBUG ( 94): #16 pc 0000e649 /system/lib/libc.so (__libc_init+52)
I/DEBUG ( 94): #17 pc 00000d44 /system/bin/app_process
I/DEBUG ( 94):
I/DEBUG ( 94): stack:
I/DEBUG ( 94): bea68540 41913cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bea68544 4165a4bb /system/lib/libdvm.so (dvmRemoveFromReferenceTable(ReferenceTable*, Object**, Object*)+8)
I/DEBUG ( 94): bea68548 01998700 [heap]
I/DEBUG ( 94): bea6854c 4165e62f /system/lib/libdvm.so (dvmReleaseTrackedAlloc+38)
I/DEBUG ( 94): bea68550 41913cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bea68554 00000000
I/DEBUG ( 94): bea68558 00000388
I/DEBUG ( 94): bea6855c 4190cb98 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bea68560 41913cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bea68564 00000000
I/DEBUG ( 94): bea68568 00000000
I/DEBUG ( 94): bea6856c 4021631c
I/DEBUG ( 94): bea68570 00000003
I/DEBUG ( 94): bea68574 00000001
I/DEBUG ( 94): bea68578 01ac5750 [heap]
I/DEBUG ( 94): bea6857c 000001bc
I/DEBUG ( 94): #00 bea68580 4194b008
I/DEBUG ( 94): bea68584 4194b000
I/DEBUG ( 94): bea68588 00080000
I/DEBUG ( 94): bea6858c 4194b000
I/DEBUG ( 94): bea68590 4194b008
I/DEBUG ( 94): bea68594 41679aad /system/lib/libdvm.so (create_mspace_with_base+76)
I/DEBUG ( 94): #01 bea68598 ffff0ff0 [vectors]
I/DEBUG ( 94): bea6859c 400fe168
I/DEBUG ( 94): bea685a0 00000000
I/DEBUG ( 94): bea685a4 00080000
I/DEBUG ( 94): bea685a8 4194b000
I/DEBUG ( 94): bea685ac 4167baf7 /system/lib/libdvm.so
I/DEBUG ( 94): #02 bea685b0 4194b000
I/DEBUG ( 94): bea685b4 03d75000
I/DEBUG ( 94): bea685b8 03d75000
I/DEBUG ( 94): bea685bc 01996600 [heap]
I/DEBUG ( 94): bea685c0 bea685e8 [stack]
I/DEBUG ( 94): bea685c4 4194b000
I/DEBUG ( 94): bea685c8 00000080
I/DEBUG ( 94): bea685cc 4167c25b /system/lib/libdvm.so (dvmHeapSourceStartupBeforeFork()+350)
I/DEBUG ( 94):
I/DEBUG ( 94): memory near r0:
I/DEBUG ( 94): 4194afe8 00000000 00000000 00000000 00000000
I/DEBUG ( 94): 4194aff8 00000000 00000000 ffffffff ffffffff
I/DEBUG ( 94): 4194b008 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4194b018 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4194b028 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4194b038 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4194b048 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4194b058 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4194b068 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4194b078 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4194b088 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4194b098 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4194b0a8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4194b0b8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4194b0c8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4194b0d8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94): memory near r3:
I/DEBUG ( 94): 7fffffe0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 7ffffff0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000000 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000010 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000020 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000030 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000040 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000050 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000060 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000070 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000080 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000090 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 800000a0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 800000b0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 800000c0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 800000d0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94): memory near r8:
I/DEBUG ( 94): 416267e0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416267f0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41626800 e1f470b2 e207c0ff e088f30c e92d4ff0
I/DEBUG ( 94): 41626810 e24dd004 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41626820 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41626830 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41626840 e1a01627 e1a00427 e1f470b2 e7952101
I/DEBUG ( 94): 41626850 e200000f e207c0ff e7852100 e088f30c
I/DEBUG ( 94): 41626860 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41626870 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41626880 e1d410b2 e1a00427 e1f470b4 e7952101
I/DEBUG ( 94): 41626890 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94): 416268a0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416268b0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416268c0 e1d410b4 e1d400b2 e1f470b6 e7952101
I/DEBUG ( 94): 416268d0 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94):
I/DEBUG ( 94): memory near sl:
I/DEBUG ( 94): 400b9eac 00000000 7ef0001d 400b9ee4 481b13ee
I/DEBUG ( 94): 400b9ebc 47156d38 481bdb84 00000000 4191b038
I/DEBUG ( 94): 400b9ecc 400b9f18 481b1386 4741a3a0 00000006
I/DEBUG ( 94): 400b9edc 00000000 000003e8 000003e8 4191ae38
I/DEBUG ( 94): 400b9eec 00000001 00000000 07813c20 00000000
I/DEBUG ( 94): 400b9efc 07813c20 00000000 400b9f54 4909730c
I/DEBUG ( 94): 400b9f0c 4741a2f8 481b1386 00000000 400b9f54
I/DEBUG ( 94): 400b9f1c 000003e8 000003e8 4191ae38 00000001
I/DEBUG ( 94): 400b9f2c 00000000 07813c20 00000000 07813c20
I/DEBUG ( 94): 400b9f3c 00000000 400b9fa8 490968de 4720a018
I/DEBUG ( 94): 400b9f4c 4909730c 00000000 000003e8 000003e8
I/DEBUG ( 94): 400b9f5c 4191ae38 00000001 00000000 07813c20
I/DEBUG ( 94): 400b9f6c 00000000 07813c20 00000000 4193c670
I/DEBUG ( 94): 400b9f7c 07813c20 00000000 47205128 00000000
I/DEBUG ( 94): 400b9f8c 41910c80 00000000 400b9fd4 00000000
I/DEBUG ( 94): 400b9f9c 47209c28 490968de 416d8f10 400b9fd4
I/DEBUG ( 94):
I/DEBUG ( 94): memory near fp:
I/DEBUG ( 94): bea68a7c 00000000 00000000 00008d48 0000adf0
I/DEBUG ( 94): bea68a8c 0000adf8 0000ae00 bea68aa0 00000000
I/DEBUG ( 94): bea68a9c 400ed86b 00000005 bea68bb4 bea68bcc
I/DEBUG ( 94): bea68aac bea68bd5 bea68be1 bea68bea 00000000
I/DEBUG ( 94): bea68abc bea68c00 bea68c22 bea68c5f bea68c87
I/DEBUG ( 94): bea68acc bea68c9a bea68caf bea68cca bea68cdd
I/DEBUG ( 94): bea68adc bea68cf6 bea68d10 bea68d29 bea68f23
I/DEBUG ( 94): bea68aec bea68f3c bea68f5b bea68f70 bea68f8e
I/DEBUG ( 94): bea68afc bea68fad 00000000 00000000 00000010
I/DEBUG ( 94): bea68b0c 000001d7 00000006 00001000 00000011
I/DEBUG ( 94): bea68b1c 00000064 00000003 00008034 00000004
I/DEBUG ( 94): bea68b2c 00000020 00000005 00000008 00000007
I/DEBUG ( 94): bea68b3c 400ec000 00000008 00000000 00000009
I/DEBUG ( 94): bea68b4c 00008ce4 0000000b 00000000 0000000c
I/DEBUG ( 94): bea68b5c 00000000 0000000d 00000000 0000000e
I/DEBUG ( 94): bea68b6c 00000000 00000017 00000000 00000019
I/DEBUG ( 94):
I/DEBUG ( 94): memory near sp:
I/DEBUG ( 94): bea68560 41913cc8 00000000 00000000 4021631c
I/DEBUG ( 94): bea68570 00000003 00000001 01ac5750 000001bc
I/DEBUG ( 94): bea68580 4194b008 4194b000 00080000 4194b000
I/DEBUG ( 94): bea68590 4194b008 41679aad ffff0ff0 400fe168
I/DEBUG ( 94): bea685a0 00000000 00080000 4194b000 4167baf7
I/DEBUG ( 94): bea685b0 4194b000 03d75000 03d75000 01996600
I/DEBUG ( 94): bea685c0 bea685e8 4194b000 00000080 4167c25b
I/DEBUG ( 94): bea685d0 0000001f 00000000 03d75000 0028b000
I/DEBUG ( 94): bea685e0 00000001 0000001f 00000000 02175000
I/DEBUG ( 94): bea685f0 00000000 00060000 00000000 4194b000
I/DEBUG ( 94): bea68600 43ac0000 419cb000 01998700 00000000
I/DEBUG ( 94): bea68610 416bb220 00000001 07813c20 4165e4c7
I/DEBUG ( 94): bea68620 fffffe44 4166fc07 00000037 4190cb60
I/DEBUG ( 94): bea68630 01998a6c bea68629 bea68624 01998700
I/DEBUG ( 94): bea68640 07813c20 00000000 00000000 00000000
I/DEBUG ( 94): bea68650 07813c20 00000000 000003e8 00000000
I/DEBUG ( 94):
I/DEBUG ( 94): code around pc:
I/DEBUG ( 94): 401e8298 e1a07001 e2603000 e213301c 0a000008
I/DEBUG ( 94): 401e82a8 e1530002 8202301c e0422003 e1b03e03
I/DEBUG ( 94): 401e82b8 28a04002 28a04002 48a04002 e1b03103
I/DEBUG ( 94): 401e82c8 24801004 e2522020 e1a03001 4a000002
I/DEBUG ( 94): 401e82d8 e2522020 e8a050fa 2afffffc e2822020
I/DEBUG ( 94): 401e82e8 e1b02e02 28a0500a 48a04002 e1b02102
I/DEBUG ( 94): 401e82f8 24801004 40c010b2 e1b02102 25c01000
I/DEBUG ( 94): 401e8308 e8bd40f1 e12fff1e f5d0f000 f5d1f000
I/DEBUG ( 94): 401e8318 e0202001 e3120003 1a000023 e2102003
I/DEBUG ( 94): 401e8328 e3c00003 e3c11003 e490c004 04913004
I/DEBUG ( 94): 401e8338 0a000006 e2222003 e1a02182 e3e034ff
I/DEBUG ( 94): 401e8348 e1a02233 e4913004 e18cc002 e1833002
I/DEBUG ( 94): 401e8358 e52d4004 e3a04001 e1844404 e1844804
I/DEBUG ( 94): 401e8368 f5d0f008 f5d1f008 e04c2004 e15c0003
I/DEBUG ( 94): 401e8378 01c2200c 01120384 0490c004 04913004
I/DEBUG ( 94): 401e8388 0afffff6 e1a00c0c e1a0c42c e3500001
I/DEBUG ( 94):
I/DEBUG ( 94): code around lr:
I/DEBUG ( 94): 00000000 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000010 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000020 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000030 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000040 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000050 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000060 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000070 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000080 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000090 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000a0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000b0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000c0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000d0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000e0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000f0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94): memory map around fault addr 4194b008:
I/DEBUG ( 94): 416c0000-4194b000 rw- /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): 456c0000-456f6000 rw- /dev/ashmem/dalvik-aux-structure (deleted)
I/Netd (23680): Netd 1.0 starting
W/InterfaceController(23680): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/mediaserver(23682): ServiceManager: 0x1ba74b8
I/AudioFlinger(23682): Using default 3000 mSec as standby time.
E/MediaPlayerFactory(23682): calling dlopen on FACTORY_LIB
E/MediaPlayerFactory(23682): Failed to open FACTORY_LIB Error : dlopen failed: library "libdashplayer.so" not found
I/CameraService(23682): CameraService started (pid=23682)
E/HAL (23682): load: module=/system/lib/hw/camera.msm7x27.so
E/HAL (23682): dlopen failed: could not load library "libcamera.so" needed by "camera.msm7x27.so"; caused by cannot locate symbol "_ZN7android10VectorImpl19reservedVectorImpl1Ev" referenced by "libcamera.so"...
E/CameraService(23682): Could not load camera HAL module
I/AudioPolicyManagerBase(23682): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
I/AudioHardwareMSM72XX(23682): get_audpp_filter
I/AudioHardwareMSM72XX(23682): open /system/etc/AudioFilter.csv success.
I/AudioHardwareMSM72XX(23682): EQ flag = 00.
I/AudioHardwareMSM72XX(23682): Set master volume to 7.
I/AudioFlinger(23682): loadHwModule() Loaded primary audio interface from QCOM Audio HW HAL (audio) handle 1
I/AudioFlinger(23682): HAL output buffer size 1200 frames, normal mix buffer size 1200 frames
I/AudioMixer(23682): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
I/AudioFlinger(23682): Using module 1 has the primary audio interface
D/AudioHardwareInterface(23682): setMode(NORMAL)
I/AudioFlinger(23682): AudioFlinger's thread 0x40d01008 ready to run
W/AudioFlinger(23682): Thread AudioOut_2 cannot connect to the power manager service
I/AudioHardwareMSM72XX(23682): Routing audio to Speakerphone
D/AudioHardwareMSM72XX(23682): doAudioRouteOrMute() device 0, mMode 0, mMicMute 1, mBuiltinMicSelected 0, muted
D/AudioHardwareMSM72XX(23682): setVoiceVolume(0.000000)
I/AudioHardwareMSM72XX(23682): Setting in-call volume to 1 (available range is 0 to 7)
I/audio_a2dp_hw(23682): adev_open: adev_open in A2dp_hw module
I/AudioFlinger(23682): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
I/AudioPolicyService(23682): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/AndroidRuntime(23681):
D/AndroidRuntime(23681): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime(23681): CheckJNI is OFF
D/dalvikvm(23681): Trying to load lib libjavacore.so 0x0
D/dalvikvm(23681): Added shared lib libjavacore.so 0x0
D/dalvikvm(23681): Trying to load lib libnativehelper.so 0x0
D/dalvikvm(23681): Added shared lib libnativehelper.so 0x0
D/dalvikvm(23681): No JNI_OnLoad found in libnativehelper.so 0x0, skipping init
D/dalvikvm(23681): Note: class Landroid/app/ActivityManagerNative; has 180 unimplemented (abstract) methods
E/memtrack(23681): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug(23681): failed to load memtrack module: -2
I/SamplingProfilerIntegration(23681): Profiling disabled.
I/Zygote (23681): Preloading classes...
E/cutils-trace(23681): Error opening trace file: No such file or directory (2)
V/NatController(23680): runCmd(/system/bin/iptables -F natctrl_FORWARD) res=0
V/NatController(23680): runCmd(/system/bin/iptables -A natctrl_FORWARD -j DROP) res=0
V/NatController(23680): runCmd(/system/bin/iptables -t nat -F natctrl_nat_POSTROUTING) res=0
V/NatController(23680): runCmd(/system/bin/ip rule flush) res=0
V/NatController(23680): runCmd(/system/bin/ip -6 rule flush) res=0
V/NatController(23680): runCmd(/system/bin/ip rule add from all lookup default prio 32767) res=0
V/NatController(23680): runCmd(/system/bin/ip rule add from all lookup main prio 32766) res=0
V/NatController(23680): runCmd(/system/bin/ip -6 rule add from all lookup default prio 32767) res=0
V/NatController(23680): runCmd(/system/bin/ip -6 rule add from all lookup main prio 32766) res=0
V/NatController(23680): runCmd(/system/bin/ip route flush cache) res=0
V/NatController(23680): runCmd(/system/bin/iptables -F natctrl_tether_counters) res=0
V/NatController(23680): runCmd(/system/bin/iptables -X natctrl_tether_counters) res=0
V/NatController(23680): runCmd(/system/bin/iptables -N natctrl_tether_counters) res=0
D/MDnsDS (23680): MDnsSdListener::Hander starting up
D/MDnsDS (23680): MDnsSdListener starting to monitor
D/MDnsDS (23680): Going to poll with pollCount 1
D/TextLayoutCache(23681): Using debug level = 0 - Debug Enabled = 0
I/dalvikvm(23681): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI(23681): register_android_mtp_MtpDevice
W/dalvikvm(23681): Exception Ljava/lang/UnsatisfiedLinkError; thrown while initializing Landroid/media/videoeditor/MediaArtistNativeHelper;
W/Zygote (23681): Class not found for preloading: android.media.videoeditor.MediaArtistNativeHelper
E/EmojiFactory_jni(23681): Failed to load libemoji.so: dlopen failed: library "libemoji.so" not found
I/LibraryLoader(23681): loading: webviewchromium
W/WebViewFactory(23681): error preloading provider
W/WebViewFactory(23681): java.lang.RuntimeException: Cannot load WebView
W/WebViewFactory(23681): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:32)
W/WebViewFactory(23681): at com.android.webview.chromium.WebViewChromiumFactoryProvider.<init>(WebViewChromiumFactoryProvider.java:82)
W/WebViewFactory(23681): at java.lang.Class.newInstanceImpl(Native Method)
W/WebViewFactory(23681): at java.lang.Class.newInstance(Class.java:1208)
W/WebViewFactory(23681): at android.webkit.WebViewFactory$Preloader.<clinit>(WebViewFactory.java:43)
W/WebViewFactory(23681): at java.lang.Class.classForName(Native Method)
W/WebViewFactory(23681): at java.lang.Class.forName(Class.java:251)
W/WebViewFactory(23681): at java.lang.Class.forName(Class.java:216)
W/WebViewFactory(23681): at com.android.internal.os.ZygoteInit.preloadClasses(ZygoteInit.java:291)
W/WebViewFactory(23681): at com.android.internal.os.ZygoteInit.preload(ZygoteInit.java:231)
W/WebViewFactory(23681): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:566)
W/WebViewFactory(23681): at dalvik.system.NativeStart.main(Native Method)
W/WebViewFactory(23681): Caused by: com.android.org.chromium.content.common.ProcessInitException
W/WebViewFactory(23681): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:111)
W/WebViewFactory(23681): at com.android.org.chromium.content.app.LibraryLoader.loadNow(LibraryLoader.java:79)
W/WebViewFactory(23681): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:30)
W/WebViewFactory(23681): ... 11 more
W/WebViewFactory(23681): Caused by: java.lang.UnsatisfiedLinkError: Library webviewchromium not found; tried [/vendor/lib/libwebviewchromium.so, /system/lib/libwebviewchromium.so]
W/WebViewFactory(23681): at java.lang.Runtime.loadLibrary(Runtime.java:388)
W/WebViewFactory(23681): at java.lang.System.loadLibrary(System.java:526)
W/WebViewFactory(23681): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:105)
W/WebViewFactory(23681): ... 13 more
W/Zygote (23681): Class not found for preloading: java.lang.UnsafeByteSequence
I/System (23681): Loaded time zone names for "" in 292ms (271ms in ICU)
I/System (23681): Loaded time zone names for "en_US" in 198ms (170ms in ICU)
I/Zygote (23681): ...preloaded 2776 classes in 9338ms.
I/Zygote (23681): Preload resources disabled, skipped.
D/libEGL (23681): loaded /system/lib/egl/libEGL_adreno200.so
D/libEGL (23681): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
D/libEGL (23681): loaded /system/lib/egl/libGLESv2_adreno200.so
F/libc (23681): Fatal signal 11 (SIGSEGV) at 0x41937008 (code=1), thread 23681 (zygote)
I/DEBUG ( 94): pid: 23681, tid: 23681, name: zygote >>> zygote <<<
I/DEBUG ( 94): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 41937008
I/DEBUG ( 94): r0 41937008 r1 00000000 r2 000001c8 r3 80000000
I/DEBUG ( 94): r8 41612800 r9 00000006 sl 400d4ecc fp be852a9c
I/DEBUG ( 94): ip 00000000 sp be852580 lr 00000000 pc 401312b8 cpsr a0000010
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): be852540 418ffcc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be852544 416464bb /system/lib/libdvm.so (dvmRemoveFromReferenceTable(ReferenceTable*, Object**, Object*)+8)
I/DEBUG ( 94): be852548 00bab700 [heap]
I/DEBUG ( 94): be85254c 4164a62f /system/lib/libdvm.so (dvmReleaseTrackedAlloc+38)
I/DEBUG ( 94): be852550 418ffcc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be852554 00000000
I/DEBUG ( 94): be852558 00000388
I/DEBUG ( 94): be85255c 418f8b98 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be852560 418ffcc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be852564 00000000
I/DEBUG ( 94): be852568 00000000
I/DEBUG ( 94): be85256c 4015f31c
I/DEBUG ( 94): be852570 00000003
I/DEBUG ( 94): be852574 00000001
I/DEBUG ( 94): be852578 00cd8690 [heap]
I/DEBUG ( 94): be85257c 000001bc
I/DEBUG ( 94): #00 be852580 41937008
I/DEBUG ( 94): be852584 41937000
I/DEBUG ( 94): be852588 00080000
I/DEBUG ( 94): be85258c 41937000
I/DEBUG ( 94): be852590 41937008
I/DEBUG ( 94): be852594 41665aad /system/lib/libdvm.so (create_mspace_with_base+76)
I/DEBUG ( 94): #01 be852598 ffff0ff0 [vectors]
I/DEBUG ( 94): be85259c 4010e168
I/DEBUG ( 94): be8525a0 00000000
I/DEBUG ( 94): be8525a4 00080000
I/DEBUG ( 94): be8525a8 41937000
I/DEBUG ( 94): be8525ac 41667af7 /system/lib/libdvm.so
I/DEBUG ( 94): #02 be8525b0 41937000
I/DEBUG ( 94): be8525b4 03d75000
I/DEBUG ( 94): be8525b8 03d75000
I/DEBUG ( 94): be8525bc 00ba9600 [heap]
I/DEBUG ( 94): be8525c0 be8525e8 [stack]
I/DEBUG ( 94): be8525c4 41937000
I/DEBUG ( 94): be8525c8 00000080
I/DEBUG ( 94): be8525cc 4166825b /system/lib/libdvm.so (dvmHeapSourceStartupBeforeFork()+350)
I/DEBUG ( 94):
I/DEBUG ( 94): 41936fe8 00000000 00000000 00000000 00000000
I/DEBUG ( 94): 41936ff8 00000000 00000000 ffffffff ffffffff
I/DEBUG ( 94): 41937008 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41937018 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41937028 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41937038 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41937048 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41937058 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41937068 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41937078 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41937088 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41937098 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419370a8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419370b8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419370c8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419370d8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): 416127e0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416127f0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41612800 e1f470b2 e207c0ff e088f30c e92d4ff0
I/DEBUG ( 94): 41612810 e24dd004 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41612820 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41612830 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41612840 e1a01627 e1a00427 e1f470b2 e7952101
I/DEBUG ( 94): 41612850 e200000f e207c0ff e7852100 e088f30c
I/DEBUG ( 94): 41612860 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41612870 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41612880 e1d410b2 e1a00427 e1f470b4 e7952101
I/DEBUG ( 94): 41612890 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94): 416128a0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416128b0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416128c0 e1d410b4 e1d400b2 e1f470b6 e7952101
I/DEBUG ( 94): 416128d0 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94):
I/DEBUG ( 94): 400d4eac 00000000 7ef0001d 400d4ee4 4809d3ee
I/DEBUG ( 94): 400d4ebc 47042d38 480a9b84 00000000 41907038
I/DEBUG ( 94): 400d4ecc 400d4f18 4809d386 473063a0 00000006
I/DEBUG ( 94): 400d4edc 00000000 000003e8 000003e8 41906e38
I/DEBUG ( 94): 400d4eec 00000001 00000000 07813c20 00000000
I/DEBUG ( 94): 400d4efc 07813c20 00000000 400d4f54 4905730c
I/DEBUG ( 94): 400d4f0c 473062f8 4809d386 00000000 400d4f54
I/DEBUG ( 94): 400d4f1c 000003e8 000003e8 41906e38 00000001
I/DEBUG ( 94): 400d4f2c 00000000 07813c20 00000000 07813c20
I/DEBUG ( 94): 400d4f3c 00000000 400d4fa8 490568de 470f6018
I/DEBUG ( 94): 400d4f4c 4905730c 00000000 000003e8 000003e8
I/DEBUG ( 94): 400d4f5c 41906e38 00000001 00000000 07813c20
I/DEBUG ( 94): 400d4f6c 00000000 07813c20 00000000 41928670
I/DEBUG ( 94): 400d4f7c 07813c20 00000000 470f1128 00000000
I/DEBUG ( 94): 400d4f8c 418fcc80 00000000 400d4fd4 00000000
I/DEBUG ( 94): 400d4f9c 470f5c28 490568de 416c4f10 400d4fd4
I/DEBUG ( 94):
I/DEBUG ( 94): be852a7c 00000000 00000000 00008d48 0000adf0
I/DEBUG ( 94): be852a8c 0000adf8 0000ae00 be852aa0 00000000
I/DEBUG ( 94): be852a9c 400fd86b 00000005 be852bb4 be852bcc
I/DEBUG ( 94): be852aac be852bd5 be852be1 be852bea 00000000
I/DEBUG ( 94): be852abc be852c00 be852c22 be852c5f be852c87
I/DEBUG ( 94): be852acc be852c9a be852caf be852cca be852cdd
I/DEBUG ( 94): be852adc be852cf6 be852d10 be852d29 be852f23
I/DEBUG ( 94): be852aec be852f3c be852f5b be852f70 be852f8e
I/DEBUG ( 94): be852afc be852fad 00000000 00000000 00000010
I/DEBUG ( 94): be852b0c 000001d7 00000006 00001000 00000011
I/DEBUG ( 94): be852b1c 00000064 00000003 00008034 00000004
I/DEBUG ( 94): be852b2c 00000020 00000005 00000008 00000007
I/DEBUG ( 94): be852b3c 400fc000 00000008 00000000 00000009
I/DEBUG ( 94): be852b4c 00008ce4 0000000b 00000000 0000000c
I/DEBUG ( 94): be852b5c 00000000 0000000d 00000000 0000000e
I/DEBUG ( 94): be852b6c 00000000 00000017 00000000 00000019
I/DEBUG ( 94):
I/DEBUG ( 94): be852560 418ffcc8 00000000 00000000 4015f31c
I/DEBUG ( 94): be852570 00000003 00000001 00cd8690 000001bc
I/DEBUG ( 94): be852580 41937008 41937000 00080000 41937000
I/DEBUG ( 94): be852590 41937008 41665aad ffff0ff0 4010e168
I/DEBUG ( 94): be8525a0 00000000 00080000 41937000 41667af7
I/DEBUG ( 94): be8525b0 41937000 03d75000 03d75000 00ba9600
I/DEBUG ( 94): be8525c0 be8525e8 41937000 00000080 4166825b
I/DEBUG ( 94): be8525d0 0000001f 00000000 03d75000 0028b000
I/DEBUG ( 94): be8525e0 00000001 0000001f 00000000 02175000
I/DEBUG ( 94): be8525f0 00000000 00060000 00000000 41937000
I/DEBUG ( 94): be852600 43aac000 419b7000 00bab700 00000000
I/DEBUG ( 94): be852610 416a7220 00000001 07813c20 4164a4c7
I/DEBUG ( 94): be852620 fffffe44 4165bc07 00000031 418f8b60
I/DEBUG ( 94): be852630 00baba6c be852629 be852624 00bab700
I/DEBUG ( 94): be852640 07813c20 00000000 00000000 00000000
I/DEBUG ( 94): be852650 07813c20 00000000 000003e8 00000000
I/DEBUG ( 94):
I/DEBUG ( 94): 40131298 e1a07001 e2603000 e213301c 0a000008
I/DEBUG ( 94): 401312a8 e1530002 8202301c e0422003 e1b03e03
I/DEBUG ( 94): 401312b8 28a04002 28a04002 48a04002 e1b03103
I/DEBUG ( 94): 401312c8 24801004 e2522020 e1a03001 4a000002
I/DEBUG ( 94): 401312d8 e2522020 e8a050fa 2afffffc e2822020
I/DEBUG ( 94): 401312e8 e1b02e02 28a0500a 48a04002 e1b02102
I/DEBUG ( 94): 401312f8 24801004 40c010b2 e1b02102 25c01000
I/DEBUG ( 94): 40131308 e8bd40f1 e12fff1e f5d0f000 f5d1f000
I/DEBUG ( 94): 40131318 e0202001 e3120003 1a000023 e2102003
I/DEBUG ( 94): 40131328 e3c00003 e3c11003 e490c004 04913004
I/DEBUG ( 94): 40131338 0a000006 e2222003 e1a02182 e3e034ff
I/DEBUG ( 94): 40131348 e1a02233 e4913004 e18cc002 e1833002
I/DEBUG ( 94): 40131358 e52d4004 e3a04001 e1844404 e1844804
I/DEBUG ( 94): 40131368 f5d0f008 f5d1f008 e04c2004 e15c0003
I/DEBUG ( 94): 40131378 01c2200c 01120384 0490c004 04913004
I/DEBUG ( 94): 40131388 0afffff6 e1a00c0c e1a0c42c e3500001
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): memory map around fault addr 41937008:
I/DEBUG ( 94): 416ac000-41937000 rw- /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): 456ac000-456e2000 rw- /dev/ashmem/dalvik-aux-structure (deleted)
I/Netd (23965): Netd 1.0 starting
W/InterfaceController(23965): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/mediaserver(23966): ServiceManager: 0x7c54b8
I/AudioFlinger(23966): Using default 3000 mSec as standby time.
E/MediaPlayerFactory(23966): calling dlopen on FACTORY_LIB
E/MediaPlayerFactory(23966): Failed to open FACTORY_LIB Error : dlopen failed: library "libdashplayer.so" not found
I/CameraService(23966): CameraService started (pid=23966)
E/HAL (23966): load: module=/system/lib/hw/camera.msm7x27.so
E/HAL (23966): dlopen failed: could not load library "libcamera.so" needed by "camera.msm7x27.so"; caused by cannot locate symbol "_ZN7android10VectorImpl19reservedVectorImpl1Ev" referenced by "libcamera.so"...
E/CameraService(23966): Could not load camera HAL module
I/AudioPolicyManagerBase(23966): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
I/AudioHardwareMSM72XX(23966): get_audpp_filter
I/AudioHardwareMSM72XX(23966): open /system/etc/AudioFilter.csv success.
I/AudioHardwareMSM72XX(23966): EQ flag = 00.
I/AudioHardwareMSM72XX(23966): Set master volume to 7.
I/AudioFlinger(23966): loadHwModule() Loaded primary audio interface from QCOM Audio HW HAL (audio) handle 1
I/AudioFlinger(23966): HAL output buffer size 1200 frames, normal mix buffer size 1200 frames
I/AudioMixer(23966): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
I/AudioFlinger(23966): Using module 1 has the primary audio interface
D/AudioHardwareInterface(23966): setMode(NORMAL)
I/AudioFlinger(23966): AudioFlinger's thread 0x40d2e008 ready to run
W/AudioFlinger(23966): Thread AudioOut_2 cannot connect to the power manager service
I/AudioHardwareMSM72XX(23966): Routing audio to Speakerphone
D/AudioHardwareMSM72XX(23966): doAudioRouteOrMute() device 0, mMode 0, mMicMute 1, mBuiltinMicSelected 0, muted
D/AudioHardwareMSM72XX(23966): setVoiceVolume(0.000000)
I/AudioHardwareMSM72XX(23966): Setting in-call volume to 1 (available range is 0 to 7)
I/audio_a2dp_hw(23966): adev_open: adev_open in A2dp_hw module
I/AudioFlinger(23966): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
I/AudioPolicyService(23966): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/AndroidRuntime(23964):
D/AndroidRuntime(23964): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime(23964): CheckJNI is OFF
D/dalvikvm(23964): Trying to load lib libjavacore.so 0x0
D/dalvikvm(23964): Added shared lib libjavacore.so 0x0
D/dalvikvm(23964): Trying to load lib libnativehelper.so 0x0
D/dalvikvm(23964): Added shared lib libnativehelper.so 0x0
D/dalvikvm(23964): No JNI_OnLoad found in libnativehelper.so 0x0, skipping init
D/dalvikvm(23964): Note: class Landroid/app/ActivityManagerNative; has 180 unimplemented (abstract) methods
E/memtrack(23964): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug(23964): failed to load memtrack module: -2
I/SamplingProfilerIntegration(23964): Profiling disabled.
I/Zygote (23964): Preloading classes...
E/cutils-trace(23964): Error opening trace file: No such file or directory (2)
V/NatController(23965): runCmd(/system/bin/iptables -F natctrl_FORWARD) res=0
V/NatController(23965): runCmd(/system/bin/iptables -A natctrl_FORWARD -j DROP) res=0
V/NatController(23965): runCmd(/system/bin/iptables -t nat -F natctrl_nat_POSTROUTING) res=0
V/NatController(23965): runCmd(/system/bin/ip rule flush) res=0
V/NatController(23965): runCmd(/system/bin/ip -6 rule flush) res=0
V/NatController(23965): runCmd(/system/bin/ip rule add from all lookup default prio 32767) res=0
V/NatController(23965): runCmd(/system/bin/ip rule add from all lookup main prio 32766) res=0
V/NatController(23965): runCmd(/system/bin/ip -6 rule add from all lookup default prio 32767) res=0
V/NatController(23965): runCmd(/system/bin/ip -6 rule add from all lookup main prio 32766) res=0
V/NatController(23965): runCmd(/system/bin/ip route flush cache) res=0
V/NatController(23965): runCmd(/system/bin/iptables -F natctrl_tether_counters) res=0
V/NatController(23965): runCmd(/system/bin/iptables -X natctrl_tether_counters) res=0
V/NatController(23965): runCmd(/system/bin/iptables -N natctrl_tether_counters) res=0
D/MDnsDS (23965): MDnsSdListener::Hander starting up
D/MDnsDS (23965): MDnsSdListener starting to monitor
D/MDnsDS (23965): Going to poll with pollCount 1
D/TextLayoutCache(23964): Using debug level = 0 - Debug Enabled = 0
I/dalvikvm(23964): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI(23964): register_android_mtp_MtpDevice
W/dalvikvm(23964): Exception Ljava/lang/UnsatisfiedLinkError; thrown while initializing Landroid/media/videoeditor/MediaArtistNativeHelper;
W/Zygote (23964): Class not found for preloading: android.media.videoeditor.MediaArtistNativeHelper
E/EmojiFactory_jni(23964): Failed to load libemoji.so: dlopen failed: library "libemoji.so" not found
I/LibraryLoader(23964): loading: webviewchromium
W/WebViewFactory(23964): error preloading provider
W/WebViewFactory(23964): java.lang.RuntimeException: Cannot load WebView
W/WebViewFactory(23964): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:32)
W/WebViewFactory(23964): at com.android.webview.chromium.WebViewChromiumFactoryProvider.<init>(WebViewChromiumFactoryProvider.java:82)
W/WebViewFactory(23964): at java.lang.Class.newInstanceImpl(Native Method)
W/WebViewFactory(23964): at java.lang.Class.newInstance(Class.java:1208)
W/WebViewFactory(23964): at android.webkit.WebViewFactory$Preloader.<clinit>(WebViewFactory.java:43)
W/WebViewFactory(23964): at java.lang.Class.classForName(Native Method)
W/WebViewFactory(23964): at java.lang.Class.forName(Class.java:251)
W/WebViewFactory(23964): at java.lang.Class.forName(Class.java:216)
W/WebViewFactory(23964): at com.android.internal.os.ZygoteInit.preloadClasses(ZygoteInit.java:291)
W/WebViewFactory(23964): at com.android.internal.os.ZygoteInit.preload(ZygoteInit.java:231)
W/WebViewFactory(23964): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:566)
W/WebViewFactory(23964): at dalvik.system.NativeStart.main(Native Method)
W/WebViewFactory(23964): Caused by: com.android.org.chromium.content.common.ProcessInitException
W/WebViewFactory(23964): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:111)
W/WebViewFactory(23964): at com.android.org.chromium.content.app.LibraryLoader.loadNow(LibraryLoader.java:79)
W/WebViewFactory(23964): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:30)
W/WebViewFactory(23964): ... 11 more
W/WebViewFactory(23964): Caused by: java.lang.UnsatisfiedLinkError: Library webviewchromium not found; tried [/vendor/lib/libwebviewchromium.so, /system/lib/libwebviewchromium.so]
W/WebViewFactory(23964): at java.lang.Runtime.loadLibrary(Runtime.java:388)
W/WebViewFactory(23964): at java.lang.System.loadLibrary(System.java:526)
W/WebViewFactory(23964): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:105)
W/WebViewFactory(23964): ... 13 more
W/Zygote (23964): Class not found for preloading: java.lang.UnsafeByteSequence
I/System (23964): Loaded time zone names for "" in 287ms (263ms in ICU)
I/System (23964): Loaded time zone names for "en_US" in 202ms (169ms in ICU)
I/Zygote (23964): ...preloaded 2776 classes in 9269ms.
I/Zygote (23964): Preload resources disabled, skipped.
D/libEGL (23964): loaded /system/lib/egl/libEGL_adreno200.so
D/libEGL (23964): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
D/libEGL (23964): loaded /system/lib/egl/libGLESv2_adreno200.so
F/libc (23964): Fatal signal 11 (SIGSEGV) at 0x419fb008 (code=1), thread 23964 (zygote)
I/DEBUG ( 94): pid: 23964, tid: 23964, name: zygote >>> zygote <<<
I/DEBUG ( 94): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 419fb008
I/DEBUG ( 94): r0 419fb008 r1 00000000 r2 000001c8 r3 80000000
I/DEBUG ( 94): r8 416d7800 r9 00000006 sl 416b7ecc fp be9fea9c
I/DEBUG ( 94): ip 00000000 sp be9fe580 lr 00000000 pc 401132b8 cpsr a0000010
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): be9fe540 419c3cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be9fe544 4170b4bb /system/lib/libdvm.so (dvmRemoveFromReferenceTable(ReferenceTable*, Object**, Object*)+8)
I/DEBUG ( 94): be9fe548 01573700 [heap]
I/DEBUG ( 94): be9fe54c 4170f62f /system/lib/libdvm.so (dvmReleaseTrackedAlloc+38)
I/DEBUG ( 94): be9fe550 419c3cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be9fe554 00000000
I/DEBUG ( 94): be9fe558 00000388
I/DEBUG ( 94): be9fe55c 419bcb98 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be9fe560 419c3cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be9fe564 00000000
I/DEBUG ( 94): be9fe568 00000000
I/DEBUG ( 94): be9fe56c 4014131c
I/DEBUG ( 94): be9fe570 00000003
I/DEBUG ( 94): be9fe574 00000001
I/DEBUG ( 94): be9fe578 016a0690 [heap]
I/DEBUG ( 94): be9fe57c 000001bc
I/DEBUG ( 94): #00 be9fe580 419fb008
I/DEBUG ( 94): be9fe584 419fb000
I/DEBUG ( 94): be9fe588 00080000
I/DEBUG ( 94): be9fe58c 419fb000
I/DEBUG ( 94): be9fe590 419fb008
I/DEBUG ( 94): be9fe594 4172aaad /system/lib/libdvm.so (create_mspace_with_base+76)
I/DEBUG ( 94): #01 be9fe598 ffff0ff0 [vectors]
I/DEBUG ( 94): be9fe59c 400a2168
I/DEBUG ( 94): be9fe5a0 00000000
I/DEBUG ( 94): be9fe5a4 00080000
I/DEBUG ( 94): be9fe5a8 419fb000
I/DEBUG ( 94): be9fe5ac 4172caf7 /system/lib/libdvm.so
I/DEBUG ( 94): #02 be9fe5b0 419fb000
I/DEBUG ( 94): be9fe5b4 03d75000
I/DEBUG ( 94): be9fe5b8 03d75000
I/DEBUG ( 94): be9fe5bc 01571600 [heap]
I/DEBUG ( 94): be9fe5c0 be9fe5e8 [stack]
I/DEBUG ( 94): be9fe5c4 419fb000
I/DEBUG ( 94): be9fe5c8 00000080
I/DEBUG ( 94): be9fe5cc 4172d25b /system/lib/libdvm.so (dvmHeapSourceStartupBeforeFork()+350)
I/DEBUG ( 94):
I/DEBUG ( 94): 419fafe8 00000000 00000000 00000000 00000000
I/DEBUG ( 94): 419faff8 00000000 00000000 ffffffff ffffffff
I/DEBUG ( 94): 419fb008 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419fb018 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419fb028 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419fb038 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419fb048 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419fb058 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419fb068 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419fb078 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419fb088 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419fb098 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419fb0a8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419fb0b8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419fb0c8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419fb0d8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): 416d77e0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416d77f0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416d7800 e1f470b2 e207c0ff e088f30c e92d4ff0
I/DEBUG ( 94): 416d7810 e24dd004 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416d7820 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416d7830 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416d7840 e1a01627 e1a00427 e1f470b2 e7952101
I/DEBUG ( 94): 416d7850 e200000f e207c0ff e7852100 e088f30c
I/DEBUG ( 94): 416d7860 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416d7870 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416d7880 e1d410b2 e1a00427 e1f470b4 e7952101
I/DEBUG ( 94): 416d7890 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94): 416d78a0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416d78b0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416d78c0 e1d410b4 e1d400b2 e1f470b6 e7952101
I/DEBUG ( 94): 416d78d0 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94):
I/DEBUG ( 94): 416b7eac 00000000 7ef0001d 416b7ee4 481653ee
I/DEBUG ( 94): 416b7ebc 4710ad38 48171b84 00000000 419cb038
I/DEBUG ( 94): 416b7ecc 416b7f18 48165386 473ce3a0 00000006
I/DEBUG ( 94): 416b7edc 00000000 000003e8 000003e8 419cae38
I/DEBUG ( 94): 416b7eec 00000001 00000000 07813c20 00000000
I/DEBUG ( 94): 416b7efc 07813c20 00000000 416b7f54 491e730c
I/DEBUG ( 94): 416b7f0c 473ce2f8 48165386 00000000 416b7f54
I/DEBUG ( 94): 416b7f1c 000003e8 000003e8 419cae38 00000001
I/DEBUG ( 94): 416b7f2c 00000000 07813c20 00000000 07813c20
I/DEBUG ( 94): 416b7f3c 00000000 416b7fa8 491e68de 471be018
I/DEBUG ( 94): 416b7f4c 491e730c 00000000 000003e8 000003e8
I/DEBUG ( 94): 416b7f5c 419cae38 00000001 00000000 07813c20
I/DEBUG ( 94): 416b7f6c 00000000 07813c20 00000000 419ec670
I/DEBUG ( 94): 416b7f7c 07813c20 00000000 471b9128 00000000
I/DEBUG ( 94): 416b7f8c 419c0c80 00000000 416b7fd4 00000000
I/DEBUG ( 94): 416b7f9c 471bdc28 491e68de 41788f10 416b7fd4
I/DEBUG ( 94):
I/DEBUG ( 94): be9fea7c 00000000 00000000 00008d48 0000adf0
I/DEBUG ( 94): be9fea8c 0000adf8 0000ae00 be9feaa0 00000000
I/DEBUG ( 94): be9fea9c 4009186b 00000005 be9febb4 be9febcc
I/DEBUG ( 94): be9feaac be9febd5 be9febe1 be9febea 00000000
I/DEBUG ( 94): be9feabc be9fec00 be9fec22 be9fec5f be9fec87
I/DEBUG ( 94): be9feacc be9fec9a be9fecaf be9fecca be9fecdd
I/DEBUG ( 94): be9feadc be9fecf6 be9fed10 be9fed29 be9fef23
I/DEBUG ( 94): be9feaec be9fef3c be9fef5b be9fef70 be9fef8e
I/DEBUG ( 94): be9feafc be9fefad 00000000 00000000 00000010
I/DEBUG ( 94): be9feb0c 000001d7 00000006 00001000 00000011
I/DEBUG ( 94): be9feb1c 00000064 00000003 00008034 00000004
I/DEBUG ( 94): be9feb2c 00000020 00000005 00000008 00000007
I/DEBUG ( 94): be9feb3c 40090000 00000008 00000000 00000009
I/DEBUG ( 94): be9feb4c 00008ce4 0000000b 00000000 0000000c
I/DEBUG ( 94): be9feb5c 00000000 0000000d 00000000 0000000e
I/DEBUG ( 94): be9feb6c 00000000 00000017 00000000 00000019
I/DEBUG ( 94):
I/DEBUG ( 94): be9fe560 419c3cc8 00000000 00000000 4014131c
I/DEBUG ( 94): be9fe570 00000003 00000001 016a0690 000001bc
I/DEBUG ( 94): be9fe580 419fb008 419fb000 00080000 419fb000
I/DEBUG ( 94): be9fe590 419fb008 4172aaad ffff0ff0 400a2168
I/DEBUG ( 94): be9fe5a0 00000000 00080000 419fb000 4172caf7
I/DEBUG ( 94): be9fe5b0 419fb000 03d75000 03d75000 01571600
I/DEBUG ( 94): be9fe5c0 be9fe5e8 419fb000 00000080 4172d25b
I/DEBUG ( 94): be9fe5d0 0000001f 00000000 03d75000 0028b000
I/DEBUG ( 94): be9fe5e0 00000001 0000001f 00000000 02175000
I/DEBUG ( 94): be9fe5f0 00000000 00060000 00000000 419fb000
I/DEBUG ( 94): be9fe600 43b70000 41a7b000 01573700 00000000
I/DEBUG ( 94): be9fe610 4176c220 00000001 07813c20 4170f4c7
I/DEBUG ( 94): be9fe620 fffffe44 41720c07 00000034 419bcb60
I/DEBUG ( 94): be9fe630 01573a6c be9fe629 be9fe624 01573700
I/DEBUG ( 94): be9fe640 07813c20 00000000 00000000 00000000
I/DEBUG ( 94): be9fe650 07813c20 00000000 000003e8 00000000
I/DEBUG ( 94):
I/DEBUG ( 94): 40113298 e1a07001 e2603000 e213301c 0a000008
I/DEBUG ( 94): 401132a8 e1530002 8202301c e0422003 e1b03e03
I/DEBUG ( 94): 401132b8 28a04002 28a04002 48a04002 e1b03103
I/DEBUG ( 94): 401132c8 24801004 e2522020 e1a03001 4a000002
I/DEBUG ( 94): 401132d8 e2522020 e8a050fa 2afffffc e2822020
I/DEBUG ( 94): 401132e8 e1b02e02 28a0500a 48a04002 e1b02102
I/DEBUG ( 94): 401132f8 24801004 40c010b2 e1b02102 25c01000
I/DEBUG ( 94): 40113308 e8bd40f1 e12fff1e f5d0f000 f5d1f000
I/DEBUG ( 94): 40113318 e0202001 e3120003 1a000023 e2102003
I/DEBUG ( 94): 40113328 e3c00003 e3c11003 e490c004 04913004
I/DEBUG ( 94): 40113338 0a000006 e2222003 e1a02182 e3e034ff
I/DEBUG ( 94): 40113348 e1a02233 e4913004 e18cc002 e1833002
I/DEBUG ( 94): 40113358 e52d4004 e3a04001 e1844404 e1844804
I/DEBUG ( 94): 40113368 f5d0f008 f5d1f008 e04c2004 e15c0003
I/DEBUG ( 94): 40113378 01c2200c 01120384 0490c004 04913004
I/DEBUG ( 94): 40113388 0afffff6 e1a00c0c e1a0c42c e3500001
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): memory map around fault addr 419fb008:
I/DEBUG ( 94): 41770000-419fb000 rw- /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): 45770000-457a6000 rw- /dev/ashmem/dalvik-aux-structure (deleted)
I/Netd (24248): Netd 1.0 starting
W/InterfaceController(24248): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/mediaserver(24249): ServiceManager: 0x70b4b8
I/AudioFlinger(24249): Using default 3000 mSec as standby time.
E/MediaPlayerFactory(24249): calling dlopen on FACTORY_LIB
E/MediaPlayerFactory(24249): Failed to open FACTORY_LIB Error : dlopen failed: library "libdashplayer.so" not found
I/CameraService(24249): CameraService started (pid=24249)
E/HAL (24249): load: module=/system/lib/hw/camera.msm7x27.so
E/HAL (24249): dlopen failed: could not load library "libcamera.so" needed by "camera.msm7x27.so"; caused by cannot locate symbol "_ZN7android10VectorImpl19reservedVectorImpl1Ev" referenced by "libcamera.so"...
E/CameraService(24249): Could not load camera HAL module
I/AudioPolicyManagerBase(24249): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
I/AudioHardwareMSM72XX(24249): get_audpp_filter
I/AudioHardwareMSM72XX(24249): open /system/etc/AudioFilter.csv success.
I/AudioHardwareMSM72XX(24249): EQ flag = 00.
I/AudioHardwareMSM72XX(24249): Set master volume to 7.
I/AudioFlinger(24249): loadHwModule() Loaded primary audio interface from QCOM Audio HW HAL (audio) handle 1
I/AudioFlinger(24249): HAL output buffer size 1200 frames, normal mix buffer size 1200 frames
I/AudioMixer(24249): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
I/AudioFlinger(24249): Using module 1 has the primary audio interface
D/AudioHardwareInterface(24249): setMode(NORMAL)
I/AudioFlinger(24249): AudioFlinger's thread 0x40d48008 ready to run
W/AudioFlinger(24249): Thread AudioOut_2 cannot connect to the power manager service
I/AudioHardwareMSM72XX(24249): Routing audio to Speakerphone
D/AudioHardwareMSM72XX(24249): doAudioRouteOrMute() device 0, mMode 0, mMicMute 1, mBuiltinMicSelected 0, muted
D/AudioHardwareMSM72XX(24249): setVoiceVolume(0.000000)
I/AudioHardwareMSM72XX(24249): Setting in-call volume to 1 (available range is 0 to 7)
I/audio_a2dp_hw(24249): adev_open: adev_open in A2dp_hw module
I/AudioFlinger(24249): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
I/AudioPolicyService(24249): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/AndroidRuntime(24247):
D/AndroidRuntime(24247): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime(24247): CheckJNI is OFF
D/dalvikvm(24247): Trying to load lib libjavacore.so 0x0
D/dalvikvm(24247): Added shared lib libjavacore.so 0x0
D/dalvikvm(24247): Trying to load lib libnativehelper.so 0x0
D/dalvikvm(24247): Added shared lib libnativehelper.so 0x0
D/dalvikvm(24247): No JNI_OnLoad found in libnativehelper.so 0x0, skipping init
D/dalvikvm(24247): Note: class Landroid/app/ActivityManagerNative; has 180 unimplemented (abstract) methods
E/memtrack(24247): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug(24247): failed to load memtrack module: -2
I/SamplingProfilerIntegration(24247): Profiling disabled.
I/Zygote (24247): Preloading classes...
E/cutils-trace(24247): Error opening trace file: No such file or directory (2)
V/NatController(24248): runCmd(/system/bin/iptables -F natctrl_FORWARD) res=0
V/NatController(24248): runCmd(/system/bin/iptables -A natctrl_FORWARD -j DROP) res=0
V/NatController(24248): runCmd(/system/bin/iptables -t nat -F natctrl_nat_POSTROUTING) res=0
V/NatController(24248): runCmd(/system/bin/ip rule flush) res=0
V/NatController(24248): runCmd(/system/bin/ip -6 rule flush) res=0
V/NatController(24248): runCmd(/system/bin/ip rule add from all lookup default prio 32767) res=0
V/NatController(24248): runCmd(/system/bin/ip rule add from all lookup main prio 32766) res=0
V/NatController(24248): runCmd(/system/bin/ip -6 rule add from all lookup default prio 32767) res=0
V/NatController(24248): runCmd(/system/bin/ip -6 rule add from all lookup main prio 32766) res=0
V/NatController(24248): runCmd(/system/bin/ip route flush cache) res=0
V/NatController(24248): runCmd(/system/bin/iptables -F natctrl_tether_counters) res=0
V/NatController(24248): runCmd(/system/bin/iptables -X natctrl_tether_counters) res=0
V/NatController(24248): runCmd(/system/bin/iptables -N natctrl_tether_counters) res=0
D/MDnsDS (24248): MDnsSdListener::Hander starting up
D/MDnsDS (24248): MDnsSdListener starting to monitor
D/MDnsDS (24248): Going to poll with pollCount 1
D/TextLayoutCache(24247): Using debug level = 0 - Debug Enabled = 0
I/dalvikvm(24247): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI(24247): register_android_mtp_MtpDevice
W/dalvikvm(24247): Exception Ljava/lang/UnsatisfiedLinkError; thrown while initializing Landroid/media/videoeditor/MediaArtistNativeHelper;
W/Zygote (24247): Class not found for preloading: android.media.videoeditor.MediaArtistNativeHelper
E/EmojiFactory_jni(24247): Failed to load libemoji.so: dlopen failed: library "libemoji.so" not found
I/LibraryLoader(24247): loading: webviewchromium
W/WebViewFactory(24247): error preloading provider
W/WebViewFactory(24247): java.lang.RuntimeException: Cannot load WebView
W/WebViewFactory(24247): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:32)
W/WebViewFactory(24247): at com.android.webview.chromium.WebViewChromiumFactoryProvider.<init>(WebViewChromiumFactoryProvider.java:82)
W/WebViewFactory(24247): at java.lang.Class.newInstanceImpl(Native Method)
W/WebViewFactory(24247): at java.lang.Class.newInstance(Class.java:1208)
W/WebViewFactory(24247): at android.webkit.WebViewFactory$Preloader.<clinit>(WebViewFactory.java:43)
W/WebViewFactory(24247): at java.lang.Class.classForName(Native Method)
W/WebViewFactory(24247): at java.lang.Class.forName(Class.java:251)
W/WebViewFactory(24247): at java.lang.Class.forName(Class.java:216)
W/WebViewFactory(24247): at com.android.internal.os.ZygoteInit.preloadClasses(ZygoteInit.java:291)
W/WebViewFactory(24247): at com.android.internal.os.ZygoteInit.preload(ZygoteInit.java:231)
W/WebViewFactory(24247): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:566)
W/WebViewFactory(24247): at dalvik.system.NativeStart.main(Native Method)
W/WebViewFactory(24247): Caused by: com.android.org.chromium.content.common.ProcessInitException
W/WebViewFactory(24247): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:111)
W/WebViewFactory(24247): at com.android.org.chromium.content.app.LibraryLoader.loadNow(LibraryLoader.java:79)
W/WebViewFactory(24247): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:30)
W/WebViewFactory(24247): ... 11 more
W/WebViewFactory(24247): Caused by: java.lang.UnsatisfiedLinkError: Library webviewchromium not found; tried [/vendor/lib/libwebviewchromium.so, /system/lib/libwebviewchromium.so]
W/WebViewFactory(24247): at java.lang.Runtime.loadLibrary(Runtime.java:388)
W/WebViewFactory(24247): at java.lang.System.loadLibrary(System.java:526)
W/WebViewFactory(24247): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:105)
W/WebViewFactory(24247): ... 13 more
W/Zygote (24247): Class not found for preloading: java.lang.UnsafeByteSequence
I/System (24247): Loaded time zone names for "" in 284ms (259ms in ICU)
I/System (24247): Loaded time zone names for "en_US" in 196ms (165ms in ICU)
I/Zygote (24247): ...preloaded 2776 classes in 9413ms.
I/Zygote (24247): Preload resources disabled, skipped.
D/libEGL (24247): loaded /system/lib/egl/libEGL_adreno200.so
D/libEGL (24247): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
D/libEGL (24247): loaded /system/lib/egl/libGLESv2_adreno200.so
F/libc (24247): Fatal signal 11 (SIGSEGV) at 0x4196b008 (code=1), thread 24247 (zygote)
I/DEBUG ( 94): pid: 24247, tid: 24247, name: zygote >>> zygote <<<
I/DEBUG ( 94): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 4196b008
I/DEBUG ( 94): r0 4196b008 r1 00000000 r2 000001c8 r3 80000000
I/DEBUG ( 94): r8 41646800 r9 00000006 sl 40040ecc fp beffda9c
I/DEBUG ( 94): ip 00000000 sp beffd580 lr 00000000 pc 401462b8 cpsr a0000010
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): beffd540 41933cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): beffd544 4167a4bb /system/lib/libdvm.so (dvmRemoveFromReferenceTable(ReferenceTable*, Object**, Object*)+8)
I/DEBUG ( 94): beffd548 01290700 [heap]
I/DEBUG ( 94): beffd54c 4167e62f /system/lib/libdvm.so (dvmReleaseTrackedAlloc+38)
I/DEBUG ( 94): beffd550 41933cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): beffd554 00000000
I/DEBUG ( 94): beffd558 00000388
I/DEBUG ( 94): beffd55c 4192cb98 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): beffd560 41933cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): beffd564 00000000
I/DEBUG ( 94): beffd568 00000000
I/DEBUG ( 94): beffd56c 4017431c
I/DEBUG ( 94): beffd570 00000003
I/DEBUG ( 94): beffd574 00000001
I/DEBUG ( 94): beffd578 013bd690 [heap]
I/DEBUG ( 94): beffd57c 000001bc
I/DEBUG ( 94): #00 beffd580 4196b008
I/DEBUG ( 94): beffd584 4196b000
I/DEBUG ( 94): beffd588 00080000
I/DEBUG ( 94): beffd58c 4196b000
I/DEBUG ( 94): beffd590 4196b008
I/DEBUG ( 94): beffd594 41699aad /system/lib/libdvm.so (create_mspace_with_base+76)
I/DEBUG ( 94): #01 beffd598 ffff0ff0 [vectors]
I/DEBUG ( 94): beffd59c 4009e168
I/DEBUG ( 94): beffd5a0 00000000
I/DEBUG ( 94): beffd5a4 00080000
I/DEBUG ( 94): beffd5a8 4196b000
I/DEBUG ( 94): beffd5ac 4169baf7 /system/lib/libdvm.so
I/DEBUG ( 94): #02 beffd5b0 4196b000
I/DEBUG ( 94): beffd5b4 03d75000
I/DEBUG ( 94): beffd5b8 03d75000
I/DEBUG ( 94): beffd5bc 0128e600 [heap]
I/DEBUG ( 94): beffd5c0 beffd5e8 [stack]
I/DEBUG ( 94): beffd5c4 4196b000
I/DEBUG ( 94): beffd5c8 00000080
I/DEBUG ( 94): beffd5cc 4169c25b /system/lib/libdvm.so (dvmHeapSourceStartupBeforeFork()+350)
I/DEBUG ( 94):
I/DEBUG ( 94): 4196afe8 00000000 00000000 00000000 00000000
I/DEBUG ( 94): 4196aff8 00000000 00000000 ffffffff ffffffff
I/DEBUG ( 94): 4196b008 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4196b018 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4196b028 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4196b038 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4196b048 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4196b058 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4196b068 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4196b078 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4196b088 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4196b098 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4196b0a8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4196b0b8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4196b0c8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4196b0d8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): 416467e0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416467f0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41646800 e1f470b2 e207c0ff e088f30c e92d4ff0
I/DEBUG ( 94): 41646810 e24dd004 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41646820 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41646830 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41646840 e1a01627 e1a00427 e1f470b2 e7952101
I/DEBUG ( 94): 41646850 e200000f e207c0ff e7852100 e088f30c
I/DEBUG ( 94): 41646860 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41646870 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41646880 e1d410b2 e1a00427 e1f470b4 e7952101
I/DEBUG ( 94): 41646890 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94): 416468a0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416468b0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416468c0 e1d410b4 e1d400b2 e1f470b6 e7952101
I/DEBUG ( 94): 416468d0 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94):
I/DEBUG ( 94): 40040eac 00000000 7ef0001d 40040ee4 482013ee
I/DEBUG ( 94): 40040ebc 471a6d38 4820db84 00000000 4193b038
I/DEBUG ( 94): 40040ecc 40040f18 48201386 4746a3a0 00000006
I/DEBUG ( 94): 40040edc 00000000 000003e8 000003e8 4193ae38
I/DEBUG ( 94): 40040eec 00000001 00000000 07813c20 00000000
I/DEBUG ( 94): 40040efc 07813c20 00000000 40040f54 490e730c
I/DEBUG ( 94): 40040f0c 4746a2f8 48201386 00000000 40040f54
I/DEBUG ( 94): 40040f1c 000003e8 000003e8 4193ae38 00000001
I/DEBUG ( 94): 40040f2c 00000000 07813c20 00000000 07813c20
I/DEBUG ( 94): 40040f3c 00000000 40040fa8 490e68de 4725a018
I/DEBUG ( 94): 40040f4c 490e730c 00000000 000003e8 000003e8
I/DEBUG ( 94): 40040f5c 4193ae38 00000001 00000000 07813c20
I/DEBUG ( 94): 40040f6c 00000000 07813c20 00000000 4195c670
I/DEBUG ( 94): 40040f7c 07813c20 00000000 47255128 00000000
I/DEBUG ( 94): 40040f8c 41930c80 00000000 40040fd4 00000000
I/DEBUG ( 94): 40040f9c 47259c28 490e68de 416f8f10 40040fd4
I/DEBUG ( 94):
I/DEBUG ( 94): beffda7c 00000000 00000000 00008d48 0000adf0
I/DEBUG ( 94): beffda8c 0000adf8 0000ae00 beffdaa0 00000000
I/DEBUG ( 94): beffda9c 4008d86b 00000005 beffdbb4 beffdbcc
I/DEBUG ( 94): beffdaac beffdbd5 beffdbe1 beffdbea 00000000
I/DEBUG ( 94): beffdabc beffdc00 beffdc22 beffdc5f beffdc87
I/DEBUG ( 94): beffdacc beffdc9a beffdcaf beffdcca beffdcdd
I/DEBUG ( 94): beffdadc beffdcf6 beffdd10 beffdd29 beffdf23
I/DEBUG ( 94): beffdaec beffdf3c beffdf5b beffdf70 beffdf8e
I/DEBUG ( 94): beffdafc beffdfad 00000000 00000000 00000010
I/DEBUG ( 94): beffdb0c 000001d7 00000006 00001000 00000011
I/DEBUG ( 94): beffdb1c 00000064 00000003 00008034 00000004
I/DEBUG ( 94): beffdb2c 00000020 00000005 00000008 00000007
I/DEBUG ( 94): beffdb3c 4008c000 00000008 00000000 00000009
I/DEBUG ( 94): beffdb4c 00008ce4 0000000b 00000000 0000000c
I/DEBUG ( 94): beffdb5c 00000000 0000000d 00000000 0000000e
I/DEBUG ( 94): beffdb6c 00000000 00000017 00000000 00000019
I/DEBUG ( 94):
I/DEBUG ( 94): beffd560 41933cc8 00000000 00000000 4017431c
I/DEBUG ( 94): beffd570 00000003 00000001 013bd690 000001bc
I/DEBUG ( 94): beffd580 4196b008 4196b000 00080000 4196b000
I/DEBUG ( 94): beffd590 4196b008 41699aad ffff0ff0 4009e168
I/DEBUG ( 94): beffd5a0 00000000 00080000 4196b000 4169baf7
I/DEBUG ( 94): beffd5b0 4196b000 03d75000 03d75000 0128e600
I/DEBUG ( 94): beffd5c0 beffd5e8 4196b000 00000080 4169c25b
I/DEBUG ( 94): beffd5d0 0000001f 00000000 03d75000 0028b000
I/DEBUG ( 94): beffd5e0 00000001 0000001f 00000000 02175000
I/DEBUG ( 94): beffd5f0 00000000 00060000 00000000 4196b000
I/DEBUG ( 94): beffd600 43ae0000 419eb000 01290700 00000000
I/DEBUG ( 94): beffd610 416db220 00000001 07813c20 4167e4c7
I/DEBUG ( 94): beffd620 fffffe44 4168fc07 00000037 4192cb60
I/DEBUG ( 94): beffd630 01290a6c beffd629 beffd624 01290700
I/DEBUG ( 94): beffd640 07813c20 00000000 00000000 00000000
I/DEBUG ( 94): beffd650 07813c20 00000000 000003e8 00000000
I/DEBUG ( 94):
I/DEBUG ( 94): 40146298 e1a07001 e2603000 e213301c 0a000008
I/DEBUG ( 94): 401462a8 e1530002 8202301c e0422003 e1b03e03
I/DEBUG ( 94): 401462b8 28a04002 28a04002 48a04002 e1b03103
I/DEBUG ( 94): 401462c8 24801004 e2522020 e1a03001 4a000002
I/DEBUG ( 94): 401462d8 e2522020 e8a050fa 2afffffc e2822020
I/DEBUG ( 94): 401462e8 e1b02e02 28a0500a 48a04002 e1b02102
I/DEBUG ( 94): 401462f8 24801004 40c010b2 e1b02102 25c01000
I/DEBUG ( 94): 40146308 e8bd40f1 e12fff1e f5d0f000 f5d1f000
I/DEBUG ( 94): 40146318 e0202001 e3120003 1a000023 e2102003
I/DEBUG ( 94): 40146328 e3c00003 e3c11003 e490c004 04913004
I/DEBUG ( 94): 40146338 0a000006 e2222003 e1a02182 e3e034ff
I/DEBUG ( 94): 40146348 e1a02233 e4913004 e18cc002 e1833002
I/DEBUG ( 94): 40146358 e52d4004 e3a04001 e1844404 e1844804
I/DEBUG ( 94): 40146368 f5d0f008 f5d1f008 e04c2004 e15c0003
I/DEBUG ( 94): 40146378 01c2200c 01120384 0490c004 04913004
I/DEBUG ( 94): 40146388 0afffff6 e1a00c0c e1a0c42c e3500001
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): memory map around fault addr 4196b008:
I/DEBUG ( 94): 416e0000-4196b000 rw- /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): (no map for address)
I/DEBUG ( 94): 456e0000-45716000 rw- /dev/ashmem/dalvik-aux-structure (deleted)
I/ServiceManager( 88): service 'media.audio_policy' died
I/ServiceManager( 88): service 'media.audio_flinger' died
I/ServiceManager( 88): service 'media.player' died
I/ServiceManager( 88): service 'media.camera' died
I/Netd (24530): Netd 1.0 starting
W/InterfaceController(24530): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/mediaserver(24532): ServiceManager: 0xd5f4b8
I/AudioFlinger(24532): Using default 3000 mSec as standby time.
E/MediaPlayerFactory(24532): calling dlopen on FACTORY_LIB
E/MediaPlayerFactory(24532): Failed to open FACTORY_LIB Error : dlopen failed: library "libdashplayer.so" not found
I/CameraService(24532): CameraService started (pid=24532)
E/HAL (24532): load: module=/system/lib/hw/camera.msm7x27.so
E/HAL (24532): dlopen failed: could not load library "libcamera.so" needed by "camera.msm7x27.so"; caused by cannot locate symbol "_ZN7android10VectorImpl19reservedVectorImpl1Ev" referenced by "libcamera.so"...
E/CameraService(24532): Could not load camera HAL module
I/AudioPolicyManagerBase(24532): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
I/AudioHardwareMSM72XX(24532): get_audpp_filter
I/AudioHardwareMSM72XX(24532): open /system/etc/AudioFilter.csv success.
I/AudioHardwareMSM72XX(24532): EQ flag = 00.
I/AudioHardwareMSM72XX(24532): Set master volume to 7.
I/AudioFlinger(24532): loadHwModule() Loaded primary audio interface from QCOM Audio HW HAL (audio) handle 1
I/AudioFlinger(24532): HAL output buffer size 1200 frames, normal mix buffer size 1200 frames
I/AudioMixer(24532): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
I/AudioFlinger(24532): Using module 1 has the primary audio interface
D/AudioHardwareInterface(24532): setMode(NORMAL)
I/AudioFlinger(24532): AudioFlinger's thread 0x40e51008 ready to run
W/AudioFlinger(24532): Thread AudioOut_2 cannot connect to the power manager service
I/AudioHardwareMSM72XX(24532): Routing audio to Speakerphone
D/AudioHardwareMSM72XX(24532): doAudioRouteOrMute() device 0, mMode 0, mMicMute 1, mBuiltinMicSelected 0, muted
D/AudioHardwareMSM72XX(24532): setVoiceVolume(0.000000)
I/AudioHardwareMSM72XX(24532): Setting in-call volume to 1 (available range is 0 to 7)
I/audio_a2dp_hw(24532): adev_open: adev_open in A2dp_hw module
I/AudioFlinger(24532): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
I/AudioPolicyService(24532): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/AndroidRuntime(24531):
D/AndroidRuntime(24531): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime(24531): CheckJNI is OFF
D/dalvikvm(24531): Trying to load lib libjavacore.so 0x0
D/dalvikvm(24531): Added shared lib libjavacore.so 0x0
D/dalvikvm(24531): Trying to load lib libnativehelper.so 0x0
D/dalvikvm(24531): Added shared lib libnativehelper.so 0x0
D/dalvikvm(24531): No JNI_OnLoad found in libnativehelper.so 0x0, skipping init
D/dalvikvm(24531): Note: class Landroid/app/ActivityManagerNative; has 180 unimplemented (abstract) methods
E/memtrack(24531): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug(24531): failed to load memtrack module: -2
I/SamplingProfilerIntegration(24531): Profiling disabled.
I/Zygote (24531): Preloading classes...
E/cutils-trace(24531): Error opening trace file: No such file or directory (2)
V/NatController(24530): runCmd(/system/bin/iptables -F natctrl_FORWARD) res=0
V/NatController(24530): runCmd(/system/bin/iptables -A natctrl_FORWARD -j DROP) res=0
V/NatController(24530): runCmd(/system/bin/iptables -t nat -F natctrl_nat_POSTROUTING) res=0
V/NatController(24530): runCmd(/system/bin/ip rule flush) res=0
V/NatController(24530): runCmd(/system/bin/ip -6 rule flush) res=0
V/NatController(24530): runCmd(/system/bin/ip rule add from all lookup default prio 32767) res=0
V/NatController(24530): runCmd(/system/bin/ip rule add from all lookup main prio 32766) res=0
V/NatController(24530): runCmd(/system/bin/ip -6 rule add from all lookup default prio 32767) res=0
V/NatController(24530): runCmd(/system/bin/ip -6 rule add from all lookup main prio 32766) res=0
V/NatController(24530): runCmd(/system/bin/ip route flush cache) res=0
V/NatController(24530): runCmd(/system/bin/iptables -F natctrl_tether_counters) res=0
V/NatController(24530): runCmd(/system/bin/iptables -X natctrl_tether_counters) res=0
V/NatController(24530): runCmd(/system/bin/iptables -N natctrl_tether_counters) res=0
D/MDnsDS (24530): MDnsSdListener::Hander starting up
D/MDnsDS (24530): MDnsSdListener starting to monitor
D/MDnsDS (24530): Going to poll with pollCount 1
D/TextLayoutCache(24531): Using debug level = 0 - Debug Enabled = 0
I/dalvikvm(24531): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI(24531): register_android_mtp_MtpDevice
W/dalvikvm(24531): Exception Ljava/lang/UnsatisfiedLinkError; thrown while initializing Landroid/media/videoeditor/MediaArtistNativeHelper;
W/Zygote (24531): Class not found for preloading: android.media.videoeditor.MediaArtistNativeHelper
E/EmojiFactory_jni(24531): Failed to load libemoji.so: dlopen failed: library "libemoji.so" not found
I/LibraryLoader(24531): loading: webviewchromium
W/WebViewFactory(24531): error preloading provider
W/WebViewFactory(24531): java.lang.RuntimeException: Cannot load WebView
W/WebViewFactory(24531): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:32)
W/WebViewFactory(24531): at com.android.webview.chromium.WebViewChromiumFactoryProvider.<init>(WebViewChromiumFactoryProvider.java:82)
W/WebViewFactory(24531): at java.lang.Class.newInstanceImpl(Native Method)
W/WebViewFactory(24531): at java.lang.Class.newInstance(Class.java:1208)
W/WebViewFactory(24531): at android.webkit.WebViewFactory$Preloader.<clinit>(WebViewFactory.java:43)
W/WebViewFactory(24531): at java.lang.Class.classForName(Native Method)
W/WebViewFactory(24531): at java.lang.Class.forName(Class.java:251)
W/WebViewFactory(24531): at java.lang.Class.forName(Class.java:216)
W/WebViewFactory(24531): at com.android.internal.os.ZygoteInit.preloadClasses(ZygoteInit.java:291)
W/WebViewFactory(24531): at com.android.internal.os.ZygoteInit.preload(ZygoteInit.java:231)
W/WebViewFactory(24531): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:566)
W/WebViewFactory(24531): at dalvik.system.NativeStart.main(Native Method)
W/WebViewFactory(24531): Caused by: com.android.org.chromium.content.common.ProcessInitException
W/WebViewFactory(24531): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:111)
W/WebViewFactory(24531): at com.android.org.chromium.content.app.LibraryLoader.loadNow(LibraryLoader.java:79)
W/WebViewFactory(24531): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:30)
W/WebViewFactory(24531): ... 11 more
W/WebViewFactory(24531): Caused by: java.lang.UnsatisfiedLinkError: Library webviewchromium not found; tried [/vendor/lib/libwebviewchromium.so, /system/lib/libwebviewchromium.so]
W/WebViewFactory(24531): at java.lang.Runtime.loadLibrary(Runtime.java:388)
W/WebViewFactory(24531): at java.lang.System.loadLibrary(System.java:526)
W/WebViewFactory(24531): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:105)
W/WebViewFactory(24531): ... 13 more
W/Zygote (24531): Class not found for preloading: java.lang.UnsafeByteSequence
I/System (24531): Loaded time zone names for "" in 296ms (267ms in ICU)
I/System (24531): Loaded time zone names for "en_US" in 206ms (171ms in ICU)
I/Zygote (24531): ...preloaded 2776 classes in 9253ms.
I/Zygote (24531): Preload resources disabled, skipped.
D/libEGL (24531): loaded /system/lib/egl/libEGL_adreno200.so
D/libEGL (24531): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
D/libEGL (24531): loaded /system/lib/egl/libGLESv2_adreno200.so
F/libc (24531): Fatal signal 11 (SIGSEGV) at 0x4199b008 (code=1), thread 24531 (zygote)
I/DEBUG ( 94): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG ( 94): Build fingerprint: 'lge/LS670/LS670:2.3.3/GRI40/LG-LS670-V20g.19C11F164C:user/release-keys'
I/DEBUG ( 94): Revision: '0'
I/DEBUG ( 94): pid: 24531, tid: 24531, name: zygote >>> zygote <<<
I/DEBUG ( 94): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 4199b008
I/DEBUG ( 94): r0 4199b008 r1 00000000 r2 000001c8 r3 80000000
I/DEBUG ( 94): r4 00000000 r5 00000000 r6 00000000 r7 00000000
I/DEBUG ( 94): r8 41676800 r9 00000006 sl 4009decc fp beb95a9c
I/DEBUG ( 94): ip 00000000 sp beb95580 lr 00000000 pc 4019b2b8 cpsr a0000010
I/DEBUG ( 94): d0 42c393484d78abc4 d1 3f50624d00000061
I/DEBUG ( 94): d2 7e37e43c8800759c d3 7e37e43c8800759c
I/DEBUG ( 94): d4 8000000000000000 d5 3fbc71c71c71c71c
I/DEBUG ( 94): d6 4a1f2640fee00000 d7 42c800004a22c000
I/DEBUG ( 94): d8 0000000000000000 d9 0000000000000000
I/DEBUG ( 94): d10 0000000000000000 d11 0000000000000000
I/DEBUG ( 94): d12 0000000000000000 d13 0000000000000000
I/DEBUG ( 94): d14 0000000000000000 d15 0000000000000000
I/DEBUG ( 94): scr 80000010
I/DEBUG ( 94):
I/DEBUG ( 94): backtrace:
I/DEBUG ( 94): #00 pc 000222b8 /system/lib/libc.so (memset+112)
I/DEBUG ( 94): #01 pc 00071aa9 /system/lib/libdvm.so (create_mspace_with_base+72)
I/DEBUG ( 94): #02 pc 00073af3 /system/lib/libdvm.so
I/DEBUG ( 94): #03 pc 00074257 /system/lib/libdvm.so (dvmHeapSourceStartupBeforeFork()+346)
I/DEBUG ( 94): #04 pc 000564c3 /system/lib/libdvm.so (dvmGcPreZygoteFork()+2)
I/DEBUG ( 94): #05 pc 00067c03 /system/lib/libdvm.so
I/DEBUG ( 94): #06 pc 000681c9 /system/lib/libdvm.so
I/DEBUG ( 94): #07 pc 000504d3 /system/lib/libdvm.so (dvmResolveNativeMethod(unsigned int const*, JValue*, Method const*, Thread*)+114)
I/DEBUG ( 94): #08 pc 00027aa0 /system/lib/libdvm.so
I/DEBUG ( 94): #09 pc 0002e9dc /system/lib/libdvm.so (dvmMterpStd(Thread*)+76)
I/DEBUG ( 94): #10 pc 0002c0bc /system/lib/libdvm.so (dvmInterpret(Thread*, Method const*, JValue*)+184)
I/DEBUG ( 94): #11 pc 00061909 /system/lib/libdvm.so (dvmCallMethodV(Thread*, Method const*, Object*, bool, JValue*, std::__va_list)+320)
I/DEBUG ( 94): #12 pc 0004a623 /system/lib/libdvm.so
I/DEBUG ( 94): #13 pc 0004e51d /system/lib/libandroid_runtime.so
I/DEBUG ( 94): #14 pc 0004f225 /system/lib/libandroid_runtime.so (android::AndroidRuntime::start(char const*, char const*)+364)
I/DEBUG ( 94): #15 pc 00001035 /system/bin/app_process
I/DEBUG ( 94): #16 pc 0000e649 /system/lib/libc.so (__libc_init+52)
I/DEBUG ( 94): #17 pc 00000d44 /system/bin/app_process
I/DEBUG ( 94):
I/DEBUG ( 94): stack:
I/DEBUG ( 94): beb95540 41963cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): beb95544 416aa4bb /system/lib/libdvm.so (dvmRemoveFromReferenceTable(ReferenceTable*, Object**, Object*)+8)
I/DEBUG ( 94): beb95548 00b22700 [heap]
I/DEBUG ( 94): beb9554c 416ae62f /system/lib/libdvm.so (dvmReleaseTrackedAlloc+38)
I/DEBUG ( 94): beb95550 41963cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): beb95554 00000000
I/DEBUG ( 94): beb95558 00000388
I/DEBUG ( 94): beb9555c 4195cb98 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): beb95560 41963cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): beb95564 00000000
I/DEBUG ( 94): beb95568 00000000
I/DEBUG ( 94): beb9556c 401c931c
I/DEBUG ( 94): beb95570 00000003
I/DEBUG ( 94): beb95574 00000001
I/DEBUG ( 94): beb95578 00c4f690 [heap]
I/DEBUG ( 94): beb9557c 000001bc
I/DEBUG ( 94): #00 beb95580 4199b008
I/DEBUG ( 94): beb95584 4199b000
I/DEBUG ( 94): beb95588 00080000
I/DEBUG ( 94): beb9558c 4199b000
I/DEBUG ( 94): beb95590 4199b008
I/DEBUG ( 94): beb95594 416c9aad /system/lib/libdvm.so (create_mspace_with_base+76)
I/DEBUG ( 94): #01 beb95598 ffff0ff0 [vectors]
I/DEBUG ( 94): beb9559c 40026168
I/DEBUG ( 94): beb955a0 00000000
I/DEBUG ( 94): beb955a4 00080000
I/DEBUG ( 94): beb955a8 4199b000
I/DEBUG ( 94): beb955ac 416cbaf7 /system/lib/libdvm.so
I/DEBUG ( 94): #02 beb955b0 4199b000
I/DEBUG ( 94): beb955b4 03d75000
I/DEBUG ( 94): beb955b8 03d75000
I/DEBUG ( 94): beb955bc 00b20600 [heap]
I/DEBUG ( 94): beb955c0 beb955e8 [stack]
I/DEBUG ( 94): beb955c4 4199b000
I/DEBUG ( 94): beb955c8 00000080
I/DEBUG ( 94): beb955cc 416cc25b /system/lib/libdvm.so (dvmHeapSourceStartupBeforeFork()+350)
I/DEBUG ( 94):
I/DEBUG ( 94): memory near r0:
I/DEBUG ( 94): 4199afe8 00000000 00000000 00000000 00000000
I/DEBUG ( 94): 4199aff8 00000000 00000000 ffffffff ffffffff
I/DEBUG ( 94): 4199b008 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4199b018 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4199b028 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4199b038 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4199b048 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4199b058 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4199b068 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4199b078 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4199b088 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4199b098 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4199b0a8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4199b0b8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4199b0c8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4199b0d8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94): memory near r3:
I/DEBUG ( 94): 7fffffe0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 7ffffff0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000000 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000010 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000020 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000030 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000040 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000050 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000060 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000070 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000080 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000090 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 800000a0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 800000b0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 800000c0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 800000d0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94): memory near r8:
I/DEBUG ( 94): 416767e0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416767f0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41676800 e1f470b2 e207c0ff e088f30c e92d4ff0
I/DEBUG ( 94): 41676810 e24dd004 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41676820 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41676830 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41676840 e1a01627 e1a00427 e1f470b2 e7952101
I/DEBUG ( 94): 41676850 e200000f e207c0ff e7852100 e088f30c
I/DEBUG ( 94): 41676860 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41676870 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41676880 e1d410b2 e1a00427 e1f470b4 e7952101
I/DEBUG ( 94): 41676890 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94): 416768a0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416768b0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416768c0 e1d410b4 e1d400b2 e1f470b6 e7952101
I/DEBUG ( 94): 416768d0 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94):
I/DEBUG ( 94): memory near sl:
I/DEBUG ( 94): 4009deac 00000000 7ef0001d 4009dee4 4810d3ee
I/DEBUG ( 94): 4009debc 470b2d38 48119b84 00000000 4196b038
I/DEBUG ( 94): 4009decc 4009df18 4810d386 473763a0 00000006
I/DEBUG ( 94): 4009dedc 00000000 000003e8 000003e8 4196ae38
I/DEBUG ( 94): 4009deec 00000001 00000000 07813c20 00000000
I/DEBUG ( 94): 4009defc 07813c20 00000000 4009df54 4918b30c
I/DEBUG ( 94): 4009df0c 473762f8 4810d386 00000000 4009df54
I/DEBUG ( 94): 4009df1c 000003e8 000003e8 4196ae38 00000001
I/DEBUG ( 94): 4009df2c 00000000 07813c20 00000000 07813c20
I/DEBUG ( 94): 4009df3c 00000000 4009dfa8 4918a8de 47166018
I/DEBUG ( 94): 4009df4c 4918b30c 00000000 000003e8 000003e8
I/DEBUG ( 94): 4009df5c 4196ae38 00000001 00000000 07813c20
I/DEBUG ( 94): 4009df6c 00000000 07813c20 00000000 4198c670
I/DEBUG ( 94): 4009df7c 07813c20 00000000 47161128 00000000
I/DEBUG ( 94): 4009df8c 41960c80 00000000 4009dfd4 00000000
I/DEBUG ( 94): 4009df9c 47165c28 4918a8de 41728f10 4009dfd4
I/DEBUG ( 94):
I/DEBUG ( 94): memory near fp:
I/DEBUG ( 94): beb95a7c 00000000 00000000 00008d48 0000adf0
I/DEBUG ( 94): beb95a8c 0000adf8 0000ae00 beb95aa0 00000000
I/DEBUG ( 94): beb95a9c 4001586b 00000005 beb95bb4 beb95bcc
I/DEBUG ( 94): beb95aac beb95bd5 beb95be1 beb95bea 00000000
I/DEBUG ( 94): beb95abc beb95c00 beb95c22 beb95c5f beb95c87
I/DEBUG ( 94): beb95acc beb95c9a beb95caf beb95cca beb95cdd
I/DEBUG ( 94): beb95adc beb95cf6 beb95d10 beb95d29 beb95f23
I/DEBUG ( 94): beb95aec beb95f3c beb95f5b beb95f70 beb95f8e
I/DEBUG ( 94): beb95afc beb95fad 00000000 00000000 00000010
I/DEBUG ( 94): beb95b0c 000001d7 00000006 00001000 00000011
I/DEBUG ( 94): beb95b1c 00000064 00000003 00008034 00000004
I/DEBUG ( 94): beb95b2c 00000020 00000005 00000008 00000007
I/DEBUG ( 94): beb95b3c 40014000 00000008 00000000 00000009
I/DEBUG ( 94): beb95b4c 00008ce4 0000000b 00000000 0000000c
I/DEBUG ( 94): beb95b5c 00000000 0000000d 00000000 0000000e
I/DEBUG ( 94): beb95b6c 00000000 00000017 00000000 00000019
I/DEBUG ( 94):
I/DEBUG ( 94): memory near sp:
I/DEBUG ( 94): beb95560 41963cc8 00000000 00000000 401c931c
I/DEBUG ( 94): beb95570 00000003 00000001 00c4f690 000001bc
I/DEBUG ( 94): beb95580 4199b008 4199b000 00080000 4199b000
I/DEBUG ( 94): beb95590 4199b008 416c9aad ffff0ff0 40026168
I/DEBUG ( 94): beb955a0 00000000 00080000 4199b000 416cbaf7
I/DEBUG ( 94): beb955b0 4199b000 03d75000 03d75000 00b20600
I/DEBUG ( 94): beb955c0 beb955e8 4199b000 00000080 416cc25b
I/DEBUG ( 94): beb955d0 0000001f 00000000 03d75000 0028b000
I/DEBUG ( 94): beb955e0 00000001 0000001f 00000000 02175000
I/DEBUG ( 94): beb955f0 00000000 00060000 00000000 4199b000
I/DEBUG ( 94): beb95600 43b10000 41a1b000 00b22700 00000000
I/DEBUG ( 94): beb95610 4170b220 00000001 07813c20 416ae4c7
I/DEBUG ( 94): beb95620 fffffe44 416bfc07 00000031 4195cb60
I/DEBUG ( 94): beb95630 00b22a6c beb95629 beb95624 00b22700
I/DEBUG ( 94): beb95640 07813c20 00000000 00000000 00000000
I/DEBUG ( 94): beb95650 07813c20 00000000 000003e8 00000000
I/DEBUG ( 94):
I/DEBUG ( 94): code around pc:
I/DEBUG ( 94): 4019b298 e1a07001 e2603000 e213301c 0a000008
I/DEBUG ( 94): 4019b2a8 e1530002 8202301c e0422003 e1b03e03
I/DEBUG ( 94): 4019b2b8 28a04002 28a04002 48a04002 e1b03103
I/DEBUG ( 94): 4019b2c8 24801004 e2522020 e1a03001 4a000002
I/DEBUG ( 94): 4019b2d8 e2522020 e8a050fa 2afffffc e2822020
I/DEBUG ( 94): 4019b2e8 e1b02e02 28a0500a 48a04002 e1b02102
I/DEBUG ( 94): 4019b2f8 24801004 40c010b2 e1b02102 25c01000
I/DEBUG ( 94): 4019b308 e8bd40f1 e12fff1e f5d0f000 f5d1f000
I/DEBUG ( 94): 4019b318 e0202001 e3120003 1a000023 e2102003
I/DEBUG ( 94): 4019b328 e3c00003 e3c11003 e490c004 04913004
I/DEBUG ( 94): 4019b338 0a000006 e2222003 e1a02182 e3e034ff
I/DEBUG ( 94): 4019b348 e1a02233 e4913004 e18cc002 e1833002
I/DEBUG ( 94): 4019b358 e52d4004 e3a04001 e1844404 e1844804
I/DEBUG ( 94): 4019b368 f5d0f008 f5d1f008 e04c2004 e15c0003
I/DEBUG ( 94): 4019b378 01c2200c 01120384 0490c004 04913004
I/DEBUG ( 94): 4019b388 0afffff6 e1a00c0c e1a0c42c e3500001
I/DEBUG ( 94):
I/DEBUG ( 94): code around lr:
I/DEBUG ( 94): 00000000 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000010 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000020 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000030 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000040 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000050 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000060 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000070 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000080 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000090 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000a0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000b0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000c0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000d0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000e0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000f0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94): memory map around fault addr 4199b008:
I/DEBUG ( 94): 41710000-4199b000 rw- /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): 45710000-45715000 rw- /dev/ashmem/dalvik-aux-structure (deleted)
I/Netd (24814): Netd 1.0 starting
W/InterfaceController(24814): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/mediaserver(24815): ServiceManager: 0x15274b8
I/AudioFlinger(24815): Using default 3000 mSec as standby time.
E/MediaPlayerFactory(24815): calling dlopen on FACTORY_LIB
E/MediaPlayerFactory(24815): Failed to open FACTORY_LIB Error : dlopen failed: library "libdashplayer.so" not found
I/CameraService(24815): CameraService started (pid=24815)
E/HAL (24815): load: module=/system/lib/hw/camera.msm7x27.so
E/HAL (24815): dlopen failed: could not load library "libcamera.so" needed by "camera.msm7x27.so"; caused by cannot locate symbol "_ZN7android10VectorImpl19reservedVectorImpl1Ev" referenced by "libcamera.so"...
E/CameraService(24815): Could not load camera HAL module
I/AudioPolicyManagerBase(24815): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
I/AudioHardwareMSM72XX(24815): get_audpp_filter
I/AudioHardwareMSM72XX(24815): open /system/etc/AudioFilter.csv success.
I/AudioHardwareMSM72XX(24815): EQ flag = 00.
I/AudioHardwareMSM72XX(24815): Set master volume to 7.
I/AudioFlinger(24815): loadHwModule() Loaded primary audio interface from QCOM Audio HW HAL (audio) handle 1
I/AudioFlinger(24815): HAL output buffer size 1200 frames, normal mix buffer size 1200 frames
I/AudioMixer(24815): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
I/AudioFlinger(24815): Using module 1 has the primary audio interface
D/AudioHardwareInterface(24815): setMode(NORMAL)
I/AudioFlinger(24815): AudioFlinger's thread 0x40e20008 ready to run
W/AudioFlinger(24815): Thread AudioOut_2 cannot connect to the power manager service
I/AudioHardwareMSM72XX(24815): Routing audio to Speakerphone
D/AudioHardwareMSM72XX(24815): doAudioRouteOrMute() device 0, mMode 0, mMicMute 1, mBuiltinMicSelected 0, muted
D/AudioHardwareMSM72XX(24815): setVoiceVolume(0.000000)
I/AudioHardwareMSM72XX(24815): Setting in-call volume to 1 (available range is 0 to 7)
I/audio_a2dp_hw(24815): adev_open: adev_open in A2dp_hw module
I/AudioFlinger(24815): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
I/AudioPolicyService(24815): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/AndroidRuntime(24813):
D/AndroidRuntime(24813): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime(24813): CheckJNI is OFF
D/dalvikvm(24813): Trying to load lib libjavacore.so 0x0
D/dalvikvm(24813): Added shared lib libjavacore.so 0x0
D/dalvikvm(24813): Trying to load lib libnativehelper.so 0x0
D/dalvikvm(24813): Added shared lib libnativehelper.so 0x0
D/dalvikvm(24813): No JNI_OnLoad found in libnativehelper.so 0x0, skipping init
D/dalvikvm(24813): Note: class Landroid/app/ActivityManagerNative; has 180 unimplemented (abstract) methods
E/memtrack(24813): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug(24813): failed to load memtrack module: -2
I/SamplingProfilerIntegration(24813): Profiling disabled.
I/Zygote (24813): Preloading classes...
E/cutils-trace(24813): Error opening trace file: No such file or directory (2)
V/NatController(24814): runCmd(/system/bin/iptables -F natctrl_FORWARD) res=0
V/NatController(24814): runCmd(/system/bin/iptables -A natctrl_FORWARD -j DROP) res=0
V/NatController(24814): runCmd(/system/bin/iptables -t nat -F natctrl_nat_POSTROUTING) res=0
V/NatController(24814): runCmd(/system/bin/ip rule flush) res=0
V/NatController(24814): runCmd(/system/bin/ip -6 rule flush) res=0
V/NatController(24814): runCmd(/system/bin/ip rule add from all lookup default prio 32767) res=0
V/NatController(24814): runCmd(/system/bin/ip rule add from all lookup main prio 32766) res=0
V/NatController(24814): runCmd(/system/bin/ip -6 rule add from all lookup default prio 32767) res=0
V/NatController(24814): runCmd(/system/bin/ip -6 rule add from all lookup main prio 32766) res=0
V/NatController(24814): runCmd(/system/bin/ip route flush cache) res=0
V/NatController(24814): runCmd(/system/bin/iptables -F natctrl_tether_counters) res=0
V/NatController(24814): runCmd(/system/bin/iptables -X natctrl_tether_counters) res=0
V/NatController(24814): runCmd(/system/bin/iptables -N natctrl_tether_counters) res=0
D/MDnsDS (24814): MDnsSdListener::Hander starting up
D/MDnsDS (24814): MDnsSdListener starting to monitor
D/MDnsDS (24814): Going to poll with pollCount 1
D/TextLayoutCache(24813): Using debug level = 0 - Debug Enabled = 0
I/dalvikvm(24813): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI(24813): register_android_mtp_MtpDevice
W/dalvikvm(24813): Exception Ljava/lang/UnsatisfiedLinkError; thrown while initializing Landroid/media/videoeditor/MediaArtistNativeHelper;
W/Zygote (24813): Class not found for preloading: android.media.videoeditor.MediaArtistNativeHelper
E/EmojiFactory_jni(24813): Failed to load libemoji.so: dlopen failed: library "libemoji.so" not found
I/LibraryLoader(24813): loading: webviewchromium
W/WebViewFactory(24813): error preloading provider
W/WebViewFactory(24813): java.lang.RuntimeException: Cannot load WebView
W/WebViewFactory(24813): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:32)
W/WebViewFactory(24813): at com.android.webview.chromium.WebViewChromiumFactoryProvider.<init>(WebViewChromiumFactoryProvider.java:82)
W/WebViewFactory(24813): at java.lang.Class.newInstanceImpl(Native Method)
W/WebViewFactory(24813): at java.lang.Class.newInstance(Class.java:1208)
W/WebViewFactory(24813): at android.webkit.WebViewFactory$Preloader.<clinit>(WebViewFactory.java:43)
W/WebViewFactory(24813): at java.lang.Class.classForName(Native Method)
W/WebViewFactory(24813): at java.lang.Class.forName(Class.java:251)
W/WebViewFactory(24813): at java.lang.Class.forName(Class.java:216)
W/WebViewFactory(24813): at com.android.internal.os.ZygoteInit.preloadClasses(ZygoteInit.java:291)
W/WebViewFactory(24813): at com.android.internal.os.ZygoteInit.preload(ZygoteInit.java:231)
W/WebViewFactory(24813): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:566)
W/WebViewFactory(24813): at dalvik.system.NativeStart.main(Native Method)
W/WebViewFactory(24813): Caused by: com.android.org.chromium.content.common.ProcessInitException
W/WebViewFactory(24813): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:111)
W/WebViewFactory(24813): at com.android.org.chromium.content.app.LibraryLoader.loadNow(LibraryLoader.java:79)
W/WebViewFactory(24813): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:30)
W/WebViewFactory(24813): ... 11 more
W/WebViewFactory(24813): Caused by: java.lang.UnsatisfiedLinkError: Library webviewchromium not found; tried [/vendor/lib/libwebviewchromium.so, /system/lib/libwebviewchromium.so]
W/WebViewFactory(24813): at java.lang.Runtime.loadLibrary(Runtime.java:388)
W/WebViewFactory(24813): at java.lang.System.loadLibrary(System.java:526)
W/WebViewFactory(24813): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:105)
W/WebViewFactory(24813): ... 13 more
W/Zygote (24813): Class not found for preloading: java.lang.UnsafeByteSequence
I/System (24813): Loaded time zone names for "" in 300ms (274ms in ICU)
I/System (24813): Loaded time zone names for "en_US" in 209ms (176ms in ICU)
I/Zygote (24813): ...preloaded 2776 classes in 9271ms.
I/Zygote (24813): Preload resources disabled, skipped.
D/libEGL (24813): loaded /system/lib/egl/libEGL_adreno200.so
D/libEGL (24813): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
D/libEGL (24813): loaded /system/lib/egl/libGLESv2_adreno200.so
F/libc (24813): Fatal signal 11 (SIGSEGV) at 0x419bb008 (code=1), thread 24813 (zygote)
I/DEBUG ( 94): pid: 24813, tid: 24813, name: zygote >>> zygote <<<
I/DEBUG ( 94): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 419bb008
I/DEBUG ( 94): r0 419bb008 r1 00000000 r2 000001c8 r3 80000000
I/DEBUG ( 94): r8 41698800 r9 00000006 sl 45735ecc fp bef86a9c
I/DEBUG ( 94): ip 00000000 sp bef86580 lr 00000000 pc 400772b8 cpsr a0000010
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): bef86540 41983cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bef86544 416cc4bb /system/lib/libdvm.so (dvmRemoveFromReferenceTable(ReferenceTable*, Object**, Object*)+8)
I/DEBUG ( 94): bef86548 00295700 [heap]
I/DEBUG ( 94): bef8654c 416d062f /system/lib/libdvm.so (dvmReleaseTrackedAlloc+38)
I/DEBUG ( 94): bef86550 41983cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bef86554 00000000
I/DEBUG ( 94): bef86558 00000388
I/DEBUG ( 94): bef8655c 4197cb98 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bef86560 41983cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bef86564 00000000
I/DEBUG ( 94): bef86568 00000000
I/DEBUG ( 94): bef8656c 400a531c
I/DEBUG ( 94): bef86570 00000003
I/DEBUG ( 94): bef86574 00000001
I/DEBUG ( 94): bef86578 003c26b8 [heap]
I/DEBUG ( 94): bef8657c 000001bc
I/DEBUG ( 94): #00 bef86580 419bb008
I/DEBUG ( 94): bef86584 419bb000
I/DEBUG ( 94): bef86588 00080000
I/DEBUG ( 94): bef8658c 419bb000
I/DEBUG ( 94): bef86590 419bb008
I/DEBUG ( 94): bef86594 416ebaad /system/lib/libdvm.so (create_mspace_with_base+76)
I/DEBUG ( 94): #01 bef86598 ffff0ff0 [vectors]
I/DEBUG ( 94): bef8659c 400d2168
I/DEBUG ( 94): bef865a0 00000000
I/DEBUG ( 94): bef865a4 00080000
I/DEBUG ( 94): bef865a8 419bb000
I/DEBUG ( 94): bef865ac 416edaf7 /system/lib/libdvm.so
I/DEBUG ( 94): #02 bef865b0 419bb000
I/DEBUG ( 94): bef865b4 03d75000
I/DEBUG ( 94): bef865b8 03d75000
I/DEBUG ( 94): bef865bc 00293600 [heap]
I/DEBUG ( 94): bef865c0 bef865e8 [stack]
I/DEBUG ( 94): bef865c4 419bb000
I/DEBUG ( 94): bef865c8 00000080
I/DEBUG ( 94): bef865cc 416ee25b /system/lib/libdvm.so (dvmHeapSourceStartupBeforeFork()+350)
I/DEBUG ( 94):
I/DEBUG ( 94): 419bafe8 00000000 00000000 00000000 00000000
I/DEBUG ( 94): 419baff8 00000000 00000000 ffffffff ffffffff
I/DEBUG ( 94): 419bb008 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419bb018 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419bb028 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419bb038 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419bb048 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419bb058 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419bb068 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419bb078 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419bb088 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419bb098 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419bb0a8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419bb0b8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419bb0c8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419bb0d8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): 416987e0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416987f0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41698800 e1f470b2 e207c0ff e088f30c e92d4ff0
I/DEBUG ( 94): 41698810 e24dd004 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41698820 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41698830 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41698840 e1a01627 e1a00427 e1f470b2 e7952101
I/DEBUG ( 94): 41698850 e200000f e207c0ff e7852100 e088f30c
I/DEBUG ( 94): 41698860 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41698870 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41698880 e1d410b2 e1a00427 e1f470b4 e7952101
I/DEBUG ( 94): 41698890 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94): 416988a0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416988b0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416988c0 e1d410b4 e1d400b2 e1f470b6 e7952101
I/DEBUG ( 94): 416988d0 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94):
I/DEBUG ( 94): 45735eac 00000000 7ef0001d 45735ee4 481853ee
I/DEBUG ( 94): 45735ebc 4712ad38 48191b84 00000000 4198b038
I/DEBUG ( 94): 45735ecc 45735f18 48185386 473ee3a0 00000006
I/DEBUG ( 94): 45735edc 00000000 000003e8 000003e8 4198ae38
I/DEBUG ( 94): 45735eec 00000001 00000000 07813c20 00000000
I/DEBUG ( 94): 45735efc 07813c20 00000000 45735f54 4906b30c
I/DEBUG ( 94): 45735f0c 473ee2f8 48185386 00000000 45735f54
I/DEBUG ( 94): 45735f1c 000003e8 000003e8 4198ae38 00000001
I/DEBUG ( 94): 45735f2c 00000000 07813c20 00000000 07813c20
I/DEBUG ( 94): 45735f3c 00000000 45735fa8 4906a8de 471de018
I/DEBUG ( 94): 45735f4c 4906b30c 00000000 000003e8 000003e8
I/DEBUG ( 94): 45735f5c 4198ae38 00000001 00000000 07813c20
I/DEBUG ( 94): 45735f6c 00000000 07813c20 00000000 419ac670
I/DEBUG ( 94): 45735f7c 07813c20 00000000 471d9128 00000000
I/DEBUG ( 94): 45735f8c 41980c80 00000000 45735fd4 00000000
I/DEBUG ( 94): 45735f9c 471ddc28 4906a8de 41748f10 45735fd4
I/DEBUG ( 94):
I/DEBUG ( 94): bef86a7c 00000000 00000000 00008d48 0000adf0
I/DEBUG ( 94): bef86a8c 0000adf8 0000ae00 bef86aa0 00000000
I/DEBUG ( 94): bef86a9c 400c186b 00000005 bef86bb4 bef86bcc
I/DEBUG ( 94): bef86aac bef86bd5 bef86be1 bef86bea 00000000
I/DEBUG ( 94): bef86abc bef86c00 bef86c22 bef86c5f bef86c87
I/DEBUG ( 94): bef86acc bef86c9a bef86caf bef86cca bef86cdd
I/DEBUG ( 94): bef86adc bef86cf6 bef86d10 bef86d29 bef86f23
I/DEBUG ( 94): bef86aec bef86f3c bef86f5b bef86f70 bef86f8e
I/DEBUG ( 94): bef86afc bef86fad 00000000 00000000 00000010
I/DEBUG ( 94): bef86b0c 000001d7 00000006 00001000 00000011
I/DEBUG ( 94): bef86b1c 00000064 00000003 00008034 00000004
I/DEBUG ( 94): bef86b2c 00000020 00000005 00000008 00000007
I/DEBUG ( 94): bef86b3c 400c0000 00000008 00000000 00000009
I/DEBUG ( 94): bef86b4c 00008ce4 0000000b 00000000 0000000c
I/DEBUG ( 94): bef86b5c 00000000 0000000d 00000000 0000000e
I/DEBUG ( 94): bef86b6c 00000000 00000017 00000000 00000019
I/DEBUG ( 94):
I/DEBUG ( 94): bef86560 41983cc8 00000000 00000000 400a531c
I/DEBUG ( 94): bef86570 00000003 00000001 003c26b8 000001bc
I/DEBUG ( 94): bef86580 419bb008 419bb000 00080000 419bb000
I/DEBUG ( 94): bef86590 419bb008 416ebaad ffff0ff0 400d2168
I/DEBUG ( 94): bef865a0 00000000 00080000 419bb000 416edaf7
I/DEBUG ( 94): bef865b0 419bb000 03d75000 03d75000 00293600
I/DEBUG ( 94): bef865c0 bef865e8 419bb000 00000080 416ee25b
I/DEBUG ( 94): bef865d0 0000001f 00000000 03d75000 0028b000
I/DEBUG ( 94): bef865e0 00000001 0000001f 00000000 02175000
I/DEBUG ( 94): bef865f0 00000000 00060000 00000000 419bb000
I/DEBUG ( 94): bef86600 43b30000 41a3b000 00295700 00000000
I/DEBUG ( 94): bef86610 4172d220 00000001 07813c20 416d04c7
I/DEBUG ( 94): bef86620 fffffe44 416e1c07 00000033 4197cb60
I/DEBUG ( 94): bef86630 00295a6c bef86629 bef86624 00295700
I/DEBUG ( 94): bef86640 07813c20 00000000 00000000 00000000
I/DEBUG ( 94): bef86650 07813c20 00000000 000003e8 00000000
I/DEBUG ( 94):
I/DEBUG ( 94): 40077298 e1a07001 e2603000 e213301c 0a000008
I/DEBUG ( 94): 400772a8 e1530002 8202301c e0422003 e1b03e03
I/DEBUG ( 94): 400772b8 28a04002 28a04002 48a04002 e1b03103
I/DEBUG ( 94): 400772c8 24801004 e2522020 e1a03001 4a000002
I/DEBUG ( 94): 400772d8 e2522020 e8a050fa 2afffffc e2822020
I/DEBUG ( 94): 400772e8 e1b02e02 28a0500a 48a04002 e1b02102
I/DEBUG ( 94): 400772f8 24801004 40c010b2 e1b02102 25c01000
I/DEBUG ( 94): 40077308 e8bd40f1 e12fff1e f5d0f000 f5d1f000
I/DEBUG ( 94): 40077318 e0202001 e3120003 1a000023 e2102003
I/DEBUG ( 94): 40077328 e3c00003 e3c11003 e490c004 04913004
I/DEBUG ( 94): 40077338 0a000006 e2222003 e1a02182 e3e034ff
I/DEBUG ( 94): 40077348 e1a02233 e4913004 e18cc002 e1833002
I/DEBUG ( 94): 40077358 e52d4004 e3a04001 e1844404 e1844804
I/DEBUG ( 94): 40077368 f5d0f008 f5d1f008 e04c2004 e15c0003
I/DEBUG ( 94): 40077378 01c2200c 01120384 0490c004 04913004
I/DEBUG ( 94): 40077388 0afffff6 e1a00c0c e1a0c42c e3500001
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): memory map around fault addr 419bb008:
I/DEBUG ( 94): 41730000-419bb000 rw- /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): 45730000-45736000 rw-
I/Netd (25097): Netd 1.0 starting
W/InterfaceController(25097): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/mediaserver(25098): ServiceManager: 0x1a464b8
I/AudioFlinger(25098): Using default 3000 mSec as standby time.
E/MediaPlayerFactory(25098): calling dlopen on FACTORY_LIB
E/MediaPlayerFactory(25098): Failed to open FACTORY_LIB Error : dlopen failed: library "libdashplayer.so" not found
I/CameraService(25098): CameraService started (pid=25098)
E/HAL (25098): load: module=/system/lib/hw/camera.msm7x27.so
E/HAL (25098): dlopen failed: could not load library "libcamera.so" needed by "camera.msm7x27.so"; caused by cannot locate symbol "_ZN7android10VectorImpl19reservedVectorImpl1Ev" referenced by "libcamera.so"...
E/CameraService(25098): Could not load camera HAL module
I/AudioPolicyManagerBase(25098): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
I/AudioHardwareMSM72XX(25098): get_audpp_filter
I/AudioHardwareMSM72XX(25098): open /system/etc/AudioFilter.csv success.
I/AudioHardwareMSM72XX(25098): EQ flag = 00.
I/AudioHardwareMSM72XX(25098): Set master volume to 7.
I/AudioFlinger(25098): loadHwModule() Loaded primary audio interface from QCOM Audio HW HAL (audio) handle 1
I/AudioFlinger(25098): HAL output buffer size 1200 frames, normal mix buffer size 1200 frames
I/AudioMixer(25098): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
I/AudioFlinger(25098): Using module 1 has the primary audio interface
D/AudioHardwareInterface(25098): setMode(NORMAL)
I/AudioFlinger(25098): AudioFlinger's thread 0x40e90008 ready to run
W/AudioFlinger(25098): Thread AudioOut_2 cannot connect to the power manager service
I/AudioHardwareMSM72XX(25098): Routing audio to Speakerphone
D/AudioHardwareMSM72XX(25098): doAudioRouteOrMute() device 0, mMode 0, mMicMute 1, mBuiltinMicSelected 0, muted
D/AudioHardwareMSM72XX(25098): setVoiceVolume(0.000000)
I/AudioHardwareMSM72XX(25098): Setting in-call volume to 1 (available range is 0 to 7)
I/audio_a2dp_hw(25098): adev_open: adev_open in A2dp_hw module
I/AudioFlinger(25098): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
I/AudioPolicyService(25098): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/AndroidRuntime(25096):
D/AndroidRuntime(25096): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime(25096): CheckJNI is OFF
D/dalvikvm(25096): Trying to load lib libjavacore.so 0x0
D/dalvikvm(25096): Added shared lib libjavacore.so 0x0
D/dalvikvm(25096): Trying to load lib libnativehelper.so 0x0
D/dalvikvm(25096): Added shared lib libnativehelper.so 0x0
D/dalvikvm(25096): No JNI_OnLoad found in libnativehelper.so 0x0, skipping init
D/dalvikvm(25096): Note: class Landroid/app/ActivityManagerNative; has 180 unimplemented (abstract) methods
E/memtrack(25096): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug(25096): failed to load memtrack module: -2
I/SamplingProfilerIntegration(25096): Profiling disabled.
I/Zygote (25096): Preloading classes...
E/cutils-trace(25096): Error opening trace file: No such file or directory (2)
V/NatController(25097): runCmd(/system/bin/iptables -F natctrl_FORWARD) res=0
V/NatController(25097): runCmd(/system/bin/iptables -A natctrl_FORWARD -j DROP) res=0
V/NatController(25097): runCmd(/system/bin/iptables -t nat -F natctrl_nat_POSTROUTING) res=0
V/NatController(25097): runCmd(/system/bin/ip rule flush) res=0
V/NatController(25097): runCmd(/system/bin/ip -6 rule flush) res=0
V/NatController(25097): runCmd(/system/bin/ip rule add from all lookup default prio 32767) res=0
V/NatController(25097): runCmd(/system/bin/ip rule add from all lookup main prio 32766) res=0
V/NatController(25097): runCmd(/system/bin/ip -6 rule add from all lookup default prio 32767) res=0
V/NatController(25097): runCmd(/system/bin/ip -6 rule add from all lookup main prio 32766) res=0
V/NatController(25097): runCmd(/system/bin/ip route flush cache) res=0
V/NatController(25097): runCmd(/system/bin/iptables -F natctrl_tether_counters) res=0
V/NatController(25097): runCmd(/system/bin/iptables -X natctrl_tether_counters) res=0
V/NatController(25097): runCmd(/system/bin/iptables -N natctrl_tether_counters) res=0
D/MDnsDS (25097): MDnsSdListener::Hander starting up
D/MDnsDS (25097): MDnsSdListener starting to monitor
D/MDnsDS (25097): Going to poll with pollCount 1
D/TextLayoutCache(25096): Using debug level = 0 - Debug Enabled = 0
I/dalvikvm(25096): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI(25096): register_android_mtp_MtpDevice
W/dalvikvm(25096): Exception Ljava/lang/UnsatisfiedLinkError; thrown while initializing Landroid/media/videoeditor/MediaArtistNativeHelper;
W/Zygote (25096): Class not found for preloading: android.media.videoeditor.MediaArtistNativeHelper
E/EmojiFactory_jni(25096): Failed to load libemoji.so: dlopen failed: library "libemoji.so" not found
I/LibraryLoader(25096): loading: webviewchromium
W/WebViewFactory(25096): error preloading provider
W/WebViewFactory(25096): java.lang.RuntimeException: Cannot load WebView
W/WebViewFactory(25096): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:32)
W/WebViewFactory(25096): at com.android.webview.chromium.WebViewChromiumFactoryProvider.<init>(WebViewChromiumFactoryProvider.java:82)
W/WebViewFactory(25096): at java.lang.Class.newInstanceImpl(Native Method)
W/WebViewFactory(25096): at java.lang.Class.newInstance(Class.java:1208)
W/WebViewFactory(25096): at android.webkit.WebViewFactory$Preloader.<clinit>(WebViewFactory.java:43)
W/WebViewFactory(25096): at java.lang.Class.classForName(Native Method)
W/WebViewFactory(25096): at java.lang.Class.forName(Class.java:251)
W/WebViewFactory(25096): at java.lang.Class.forName(Class.java:216)
W/WebViewFactory(25096): at com.android.internal.os.ZygoteInit.preloadClasses(ZygoteInit.java:291)
W/WebViewFactory(25096): at com.android.internal.os.ZygoteInit.preload(ZygoteInit.java:231)
W/WebViewFactory(25096): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:566)
W/WebViewFactory(25096): at dalvik.system.NativeStart.main(Native Method)
W/WebViewFactory(25096): Caused by: com.android.org.chromium.content.common.ProcessInitException
W/WebViewFactory(25096): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:111)
W/WebViewFactory(25096): at com.android.org.chromium.content.app.LibraryLoader.loadNow(LibraryLoader.java:79)
W/WebViewFactory(25096): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:30)
W/WebViewFactory(25096): ... 11 more
W/WebViewFactory(25096): Caused by: java.lang.UnsatisfiedLinkError: Library webviewchromium not found; tried [/vendor/lib/libwebviewchromium.so, /system/lib/libwebviewchromium.so]
W/WebViewFactory(25096): at java.lang.Runtime.loadLibrary(Runtime.java:388)
W/WebViewFactory(25096): at java.lang.System.loadLibrary(System.java:526)
W/WebViewFactory(25096): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:105)
W/WebViewFactory(25096): ... 13 more
W/Zygote (25096): Class not found for preloading: java.lang.UnsafeByteSequence
I/System (25096): Loaded time zone names for "" in 292ms (263ms in ICU)
I/System (25096): Loaded time zone names for "en_US" in 202ms (171ms in ICU)
I/Zygote (25096): ...preloaded 2776 classes in 9427ms.
I/Zygote (25096): Preload resources disabled, skipped.
D/libEGL (25096): loaded /system/lib/egl/libEGL_adreno200.so
D/libEGL (25096): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
D/libEGL (25096): loaded /system/lib/egl/libGLESv2_adreno200.so
F/libc (25096): Fatal signal 11 (SIGSEGV) at 0x4190b008 (code=1), thread 25096 (zygote)
I/DEBUG ( 94): pid: 25096, tid: 25096, name: zygote >>> zygote <<<
I/DEBUG ( 94): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 4190b008
I/DEBUG ( 94): r0 4190b008 r1 00000000 r2 000001c8 r3 80000000
I/DEBUG ( 94): r8 415e6800 r9 00000006 sl 45685ecc fp beddba9c
I/DEBUG ( 94): ip 00000000 sp beddb580 lr 00000000 pc 401082b8 cpsr a0000010
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): beddb540 418d3cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): beddb544 4161a4bb /system/lib/libdvm.so (dvmRemoveFromReferenceTable(ReferenceTable*, Object**, Object*)+8)
I/DEBUG ( 94): beddb548 00c3e700 [heap]
I/DEBUG ( 94): beddb54c 4161e62f /system/lib/libdvm.so (dvmReleaseTrackedAlloc+38)
I/DEBUG ( 94): beddb550 418d3cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): beddb554 00000000
I/DEBUG ( 94): beddb558 00000388
I/DEBUG ( 94): beddb55c 418ccb98 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): beddb560 418d3cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): beddb564 00000000
I/DEBUG ( 94): beddb568 00000000
I/DEBUG ( 94): beddb56c 4013631c
I/DEBUG ( 94): beddb570 00000003
I/DEBUG ( 94): beddb574 00000001
I/DEBUG ( 94): beddb578 00d6b690 [heap]
I/DEBUG ( 94): beddb57c 000001bc
I/DEBUG ( 94): #00 beddb580 4190b008
I/DEBUG ( 94): beddb584 4190b000
I/DEBUG ( 94): beddb588 00080000
I/DEBUG ( 94): beddb58c 4190b000
I/DEBUG ( 94): beddb590 4190b008
I/DEBUG ( 94): beddb594 41639aad /system/lib/libdvm.so (create_mspace_with_base+76)
I/DEBUG ( 94): #01 beddb598 ffff0ff0 [vectors]
I/DEBUG ( 94): beddb59c 40036168
I/DEBUG ( 94): beddb5a0 00000000
I/DEBUG ( 94): beddb5a4 00080000
I/DEBUG ( 94): beddb5a8 4190b000
I/DEBUG ( 94): beddb5ac 4163baf7 /system/lib/libdvm.so
I/DEBUG ( 94): #02 beddb5b0 4190b000
I/DEBUG ( 94): beddb5b4 03d75000
I/DEBUG ( 94): beddb5b8 03d75000
I/DEBUG ( 94): beddb5bc 00c3c600 [heap]
I/DEBUG ( 94): beddb5c0 beddb5e8 [stack]
I/DEBUG ( 94): beddb5c4 4190b000
I/DEBUG ( 94): beddb5c8 00000080
I/DEBUG ( 94): beddb5cc 4163c25b /system/lib/libdvm.so (dvmHeapSourceStartupBeforeFork()+350)
I/DEBUG ( 94):
I/DEBUG ( 94): 4190afe8 00000000 00000000 00000000 00000000
I/DEBUG ( 94): 4190aff8 00000000 00000000 ffffffff ffffffff
I/DEBUG ( 94): 4190b008 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4190b018 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4190b028 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4190b038 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4190b048 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4190b058 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4190b068 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4190b078 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4190b088 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4190b098 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4190b0a8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4190b0b8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4190b0c8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4190b0d8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): 415e67e0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415e67f0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415e6800 e1f470b2 e207c0ff e088f30c e92d4ff0
I/DEBUG ( 94): 415e6810 e24dd004 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415e6820 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415e6830 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415e6840 e1a01627 e1a00427 e1f470b2 e7952101
I/DEBUG ( 94): 415e6850 e200000f e207c0ff e7852100 e088f30c
I/DEBUG ( 94): 415e6860 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415e6870 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415e6880 e1d410b2 e1a00427 e1f470b4 e7952101
I/DEBUG ( 94): 415e6890 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94): 415e68a0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415e68b0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415e68c0 e1d410b4 e1d400b2 e1f470b6 e7952101
I/DEBUG ( 94): 415e68d0 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94):
I/DEBUG ( 94): 45685eac 00000000 7ef0001d 45685ee4 481b53ee
I/DEBUG ( 94): 45685ebc 4715ad38 481c1b84 00000000 418db038
I/DEBUG ( 94): 45685ecc 45685f18 481b5386 4741e3a0 00000006
I/DEBUG ( 94): 45685edc 00000000 000003e8 000003e8 418dae38
I/DEBUG ( 94): 45685eec 00000001 00000000 07813c20 00000000
I/DEBUG ( 94): 45685efc 07813c20 00000000 45685f54 4909b30c
I/DEBUG ( 94): 45685f0c 4741e2f8 481b5386 00000000 45685f54
I/DEBUG ( 94): 45685f1c 000003e8 000003e8 418dae38 00000001
I/DEBUG ( 94): 45685f2c 00000000 07813c20 00000000 07813c20
I/DEBUG ( 94): 45685f3c 00000000 45685fa8 4909a8de 4720e018
I/DEBUG ( 94): 45685f4c 4909b30c 00000000 000003e8 000003e8
I/DEBUG ( 94): 45685f5c 418dae38 00000001 00000000 07813c20
I/DEBUG ( 94): 45685f6c 00000000 07813c20 00000000 418fc670
I/DEBUG ( 94): 45685f7c 07813c20 00000000 47209128 00000000
I/DEBUG ( 94): 45685f8c 418d0c80 00000000 45685fd4 00000000
I/DEBUG ( 94): 45685f9c 4720dc28 4909a8de 41698f10 45685fd4
I/DEBUG ( 94):
I/DEBUG ( 94): beddba7c 00000000 00000000 00008d48 0000adf0
I/DEBUG ( 94): beddba8c 0000adf8 0000ae00 beddbaa0 00000000
I/DEBUG ( 94): beddba9c 4002586b 00000005 beddbbb4 beddbbcc
I/DEBUG ( 94): beddbaac beddbbd5 beddbbe1 beddbbea 00000000
I/DEBUG ( 94): beddbabc beddbc00 beddbc22 beddbc5f beddbc87
I/DEBUG ( 94): beddbacc beddbc9a beddbcaf beddbcca beddbcdd
I/DEBUG ( 94): beddbadc beddbcf6 beddbd10 beddbd29 beddbf23
I/DEBUG ( 94): beddbaec beddbf3c beddbf5b beddbf70 beddbf8e
I/DEBUG ( 94): beddbafc beddbfad 00000000 00000000 00000010
I/DEBUG ( 94): beddbb0c 000001d7 00000006 00001000 00000011
I/DEBUG ( 94): beddbb1c 00000064 00000003 00008034 00000004
I/DEBUG ( 94): beddbb2c 00000020 00000005 00000008 00000007
I/DEBUG ( 94): beddbb3c 40024000 00000008 00000000 00000009
I/DEBUG ( 94): beddbb4c 00008ce4 0000000b 00000000 0000000c
I/DEBUG ( 94): beddbb5c 00000000 0000000d 00000000 0000000e
I/DEBUG ( 94): beddbb6c 00000000 00000017 00000000 00000019
I/DEBUG ( 94):
I/DEBUG ( 94): beddb560 418d3cc8 00000000 00000000 4013631c
I/DEBUG ( 94): beddb570 00000003 00000001 00d6b690 000001bc
I/DEBUG ( 94): beddb580 4190b008 4190b000 00080000 4190b000
I/DEBUG ( 94): beddb590 4190b008 41639aad ffff0ff0 40036168
I/DEBUG ( 94): beddb5a0 00000000 00080000 4190b000 4163baf7
I/DEBUG ( 94): beddb5b0 4190b000 03d75000 03d75000 00c3c600
I/DEBUG ( 94): beddb5c0 beddb5e8 4190b000 00000080 4163c25b
I/DEBUG ( 94): beddb5d0 0000001f 00000000 03d75000 0028b000
I/DEBUG ( 94): beddb5e0 00000001 0000001f 00000000 02175000
I/DEBUG ( 94): beddb5f0 00000000 00060000 00000000 4190b000
I/DEBUG ( 94): beddb600 43a80000 4198b000 00c3e700 00000000
I/DEBUG ( 94): beddb610 4167b220 00000001 07813c20 4161e4c7
I/DEBUG ( 94): beddb620 fffffe44 4162fc07 00000036 418ccb60
I/DEBUG ( 94): beddb630 00c3ea6c beddb629 beddb624 00c3e700
I/DEBUG ( 94): beddb640 07813c20 00000000 00000000 00000000
I/DEBUG ( 94): beddb650 07813c20 00000000 000003e8 00000000
I/DEBUG ( 94):
I/DEBUG ( 94): 40108298 e1a07001 e2603000 e213301c 0a000008
I/DEBUG ( 94): 401082a8 e1530002 8202301c e0422003 e1b03e03
I/DEBUG ( 94): 401082b8 28a04002 28a04002 48a04002 e1b03103
I/DEBUG ( 94): 401082c8 24801004 e2522020 e1a03001 4a000002
I/DEBUG ( 94): 401082d8 e2522020 e8a050fa 2afffffc e2822020
I/DEBUG ( 94): 401082e8 e1b02e02 28a0500a 48a04002 e1b02102
I/DEBUG ( 94): 401082f8 24801004 40c010b2 e1b02102 25c01000
I/DEBUG ( 94): 40108308 e8bd40f1 e12fff1e f5d0f000 f5d1f000
I/DEBUG ( 94): 40108318 e0202001 e3120003 1a000023 e2102003
I/DEBUG ( 94): 40108328 e3c00003 e3c11003 e490c004 04913004
I/DEBUG ( 94): 40108338 0a000006 e2222003 e1a02182 e3e034ff
I/DEBUG ( 94): 40108348 e1a02233 e4913004 e18cc002 e1833002
I/DEBUG ( 94): 40108358 e52d4004 e3a04001 e1844404 e1844804
I/DEBUG ( 94): 40108368 f5d0f008 f5d1f008 e04c2004 e15c0003
I/DEBUG ( 94): 40108378 01c2200c 01120384 0490c004 04913004
I/DEBUG ( 94): 40108388 0afffff6 e1a00c0c e1a0c42c e3500001
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): memory map around fault addr 4190b008:
I/DEBUG ( 94): 41680000-4190b000 rw- /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): 45680000-45686000 rw-
I/Netd (25382): Netd 1.0 starting
W/InterfaceController(25382): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/mediaserver(25383): ServiceManager: 0x1b684b8
I/AudioFlinger(25383): Using default 3000 mSec as standby time.
E/MediaPlayerFactory(25383): calling dlopen on FACTORY_LIB
E/MediaPlayerFactory(25383): Failed to open FACTORY_LIB Error : dlopen failed: library "libdashplayer.so" not found
I/CameraService(25383): CameraService started (pid=25383)
E/HAL (25383): load: module=/system/lib/hw/camera.msm7x27.so
E/HAL (25383): dlopen failed: could not load library "libcamera.so" needed by "camera.msm7x27.so"; caused by cannot locate symbol "_ZN7android10VectorImpl19reservedVectorImpl1Ev" referenced by "libcamera.so"...
E/CameraService(25383): Could not load camera HAL module
I/AudioPolicyManagerBase(25383): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
I/AudioHardwareMSM72XX(25383): get_audpp_filter
I/AudioHardwareMSM72XX(25383): open /system/etc/AudioFilter.csv success.
I/AudioHardwareMSM72XX(25383): EQ flag = 00.
I/AudioHardwareMSM72XX(25383): Set master volume to 7.
I/AudioFlinger(25383): loadHwModule() Loaded primary audio interface from QCOM Audio HW HAL (audio) handle 1
I/AudioFlinger(25383): HAL output buffer size 1200 frames, normal mix buffer size 1200 frames
I/AudioMixer(25383): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
I/AudioFlinger(25383): Using module 1 has the primary audio interface
D/AudioHardwareInterface(25383): setMode(NORMAL)
I/AudioFlinger(25383): AudioFlinger's thread 0x40b37008 ready to run
W/AudioFlinger(25383): Thread AudioOut_2 cannot connect to the power manager service
I/AudioHardwareMSM72XX(25383): Routing audio to Speakerphone
D/AudioHardwareMSM72XX(25383): doAudioRouteOrMute() device 0, mMode 0, mMicMute 1, mBuiltinMicSelected 0, muted
D/AudioHardwareMSM72XX(25383): setVoiceVolume(0.000000)
I/AudioHardwareMSM72XX(25383): Setting in-call volume to 1 (available range is 0 to 7)
I/audio_a2dp_hw(25383): adev_open: adev_open in A2dp_hw module
I/AudioFlinger(25383): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
I/AudioPolicyService(25383): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/AndroidRuntime(25381):
D/AndroidRuntime(25381): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime(25381): CheckJNI is OFF
D/dalvikvm(25381): Trying to load lib libjavacore.so 0x0
D/dalvikvm(25381): Added shared lib libjavacore.so 0x0
D/dalvikvm(25381): Trying to load lib libnativehelper.so 0x0
D/dalvikvm(25381): Added shared lib libnativehelper.so 0x0
D/dalvikvm(25381): No JNI_OnLoad found in libnativehelper.so 0x0, skipping init
D/dalvikvm(25381): Note: class Landroid/app/ActivityManagerNative; has 180 unimplemented (abstract) methods
E/memtrack(25381): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug(25381): failed to load memtrack module: -2
I/SamplingProfilerIntegration(25381): Profiling disabled.
I/Zygote (25381): Preloading classes...
E/cutils-trace(25381): Error opening trace file: No such file or directory (2)
V/NatController(25382): runCmd(/system/bin/iptables -F natctrl_FORWARD) res=0
V/NatController(25382): runCmd(/system/bin/iptables -A natctrl_FORWARD -j DROP) res=0
V/NatController(25382): runCmd(/system/bin/iptables -t nat -F natctrl_nat_POSTROUTING) res=0
V/NatController(25382): runCmd(/system/bin/ip rule flush) res=0
V/NatController(25382): runCmd(/system/bin/ip -6 rule flush) res=0
V/NatController(25382): runCmd(/system/bin/ip rule add from all lookup default prio 32767) res=0
V/NatController(25382): runCmd(/system/bin/ip rule add from all lookup main prio 32766) res=0
V/NatController(25382): runCmd(/system/bin/ip -6 rule add from all lookup default prio 32767) res=0
V/NatController(25382): runCmd(/system/bin/ip -6 rule add from all lookup main prio 32766) res=0
V/NatController(25382): runCmd(/system/bin/ip route flush cache) res=0
V/NatController(25382): runCmd(/system/bin/iptables -F natctrl_tether_counters) res=0
V/NatController(25382): runCmd(/system/bin/iptables -X natctrl_tether_counters) res=0
V/NatController(25382): runCmd(/system/bin/iptables -N natctrl_tether_counters) res=0
D/MDnsDS (25382): MDnsSdListener::Hander starting up
D/MDnsDS (25382): MDnsSdListener starting to monitor
D/MDnsDS (25382): Going to poll with pollCount 1
D/TextLayoutCache(25381): Using debug level = 0 - Debug Enabled = 0
I/dalvikvm(25381): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI(25381): register_android_mtp_MtpDevice
W/dalvikvm(25381): Exception Ljava/lang/UnsatisfiedLinkError; thrown while initializing Landroid/media/videoeditor/MediaArtistNativeHelper;
W/Zygote (25381): Class not found for preloading: android.media.videoeditor.MediaArtistNativeHelper
E/EmojiFactory_jni(25381): Failed to load libemoji.so: dlopen failed: library "libemoji.so" not found
I/LibraryLoader(25381): loading: webviewchromium
W/WebViewFactory(25381): error preloading provider
W/WebViewFactory(25381): java.lang.RuntimeException: Cannot load WebView
W/WebViewFactory(25381): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:32)
W/WebViewFactory(25381): at com.android.webview.chromium.WebViewChromiumFactoryProvider.<init>(WebViewChromiumFactoryProvider.java:82)
W/WebViewFactory(25381): at java.lang.Class.newInstanceImpl(Native Method)
W/WebViewFactory(25381): at java.lang.Class.newInstance(Class.java:1208)
W/WebViewFactory(25381): at android.webkit.WebViewFactory$Preloader.<clinit>(WebViewFactory.java:43)
W/WebViewFactory(25381): at java.lang.Class.classForName(Native Method)
W/WebViewFactory(25381): at java.lang.Class.forName(Class.java:251)
W/WebViewFactory(25381): at java.lang.Class.forName(Class.java:216)
W/WebViewFactory(25381): at com.android.internal.os.ZygoteInit.preloadClasses(ZygoteInit.java:291)
W/WebViewFactory(25381): at com.android.internal.os.ZygoteInit.preload(ZygoteInit.java:231)
W/WebViewFactory(25381): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:566)
W/WebViewFactory(25381): at dalvik.system.NativeStart.main(Native Method)
W/WebViewFactory(25381): Caused by: com.android.org.chromium.content.common.ProcessInitException
W/WebViewFactory(25381): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:111)
W/WebViewFactory(25381): at com.android.org.chromium.content.app.LibraryLoader.loadNow(LibraryLoader.java:79)
W/WebViewFactory(25381): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:30)
W/WebViewFactory(25381): ... 11 more
W/WebViewFactory(25381): Caused by: java.lang.UnsatisfiedLinkError: Library webviewchromium not found; tried [/vendor/lib/libwebviewchromium.so, /system/lib/libwebviewchromium.so]
W/WebViewFactory(25381): at java.lang.Runtime.loadLibrary(Runtime.java:388)
W/WebViewFactory(25381): at java.lang.System.loadLibrary(System.java:526)
W/WebViewFactory(25381): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:105)
W/WebViewFactory(25381): ... 13 more
W/Zygote (25381): Class not found for preloading: java.lang.UnsafeByteSequence
I/System (25381): Loaded time zone names for "" in 301ms (275ms in ICU)
I/System (25381): Loaded time zone names for "en_US" in 206ms (175ms in ICU)
I/Zygote (25381): ...preloaded 2776 classes in 9353ms.
I/Zygote (25381): Preload resources disabled, skipped.
D/libEGL (25381): loaded /system/lib/egl/libEGL_adreno200.so
D/libEGL (25381): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
D/libEGL (25381): loaded /system/lib/egl/libGLESv2_adreno200.so
F/libc (25381): Fatal signal 11 (SIGSEGV) at 0x41917008 (code=1), thread 25381 (zygote)
I/DEBUG ( 94): pid: 25381, tid: 25381, name: zygote >>> zygote <<<
I/DEBUG ( 94): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 41917008
I/DEBUG ( 94): r0 41917008 r1 00000000 r2 000001c8 r3 80000000
I/DEBUG ( 94): r8 415f1800 r9 00000006 sl 400f5ecc fp bee18a9c
I/DEBUG ( 94): ip 00000000 sp bee18580 lr 00000000 pc 400a92b8 cpsr a0000010
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): bee18540 418dfcc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bee18544 416254bb /system/lib/libdvm.so (dvmRemoveFromReferenceTable(ReferenceTable*, Object**, Object*)+8)
I/DEBUG ( 94): bee18548 00f24700 [heap]
I/DEBUG ( 94): bee1854c 4162962f /system/lib/libdvm.so (dvmReleaseTrackedAlloc+38)
I/DEBUG ( 94): bee18550 418dfcc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bee18554 00000000
I/DEBUG ( 94): bee18558 00000388
I/DEBUG ( 94): bee1855c 418d8b98 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bee18560 418dfcc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bee18564 00000000
I/DEBUG ( 94): bee18568 00000000
I/DEBUG ( 94): bee1856c 400d731c
I/DEBUG ( 94): bee18570 00000003
I/DEBUG ( 94): bee18574 00000001
I/DEBUG ( 94): bee18578 01051730 [heap]
I/DEBUG ( 94): bee1857c 000001bc
I/DEBUG ( 94): #00 bee18580 41917008
I/DEBUG ( 94): bee18584 41917000
I/DEBUG ( 94): bee18588 00080000
I/DEBUG ( 94): bee1858c 41917000
I/DEBUG ( 94): bee18590 41917008
I/DEBUG ( 94): bee18594 41644aad /system/lib/libdvm.so (create_mspace_with_base+76)
I/DEBUG ( 94): #01 bee18598 ffff0ff0 [vectors]
I/DEBUG ( 94): bee1859c 40066168
I/DEBUG ( 94): bee185a0 00000000
I/DEBUG ( 94): bee185a4 00080000
I/DEBUG ( 94): bee185a8 41917000
I/DEBUG ( 94): bee185ac 41646af7 /system/lib/libdvm.so
I/DEBUG ( 94): #02 bee185b0 41917000
I/DEBUG ( 94): bee185b4 03d75000
I/DEBUG ( 94): bee185b8 03d75000
I/DEBUG ( 94): bee185bc 00f22600 [heap]
I/DEBUG ( 94): bee185c0 bee185e8 [stack]
I/DEBUG ( 94): bee185c4 41917000
I/DEBUG ( 94): bee185c8 00000080
I/DEBUG ( 94): bee185cc 4164725b /system/lib/libdvm.so (dvmHeapSourceStartupBeforeFork()+350)
I/DEBUG ( 94):
I/DEBUG ( 94): 41916fe8 00000000 00000000 00000000 00000000
I/DEBUG ( 94): 41916ff8 00000000 00000000 ffffffff ffffffff
I/DEBUG ( 94): 41917008 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41917018 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41917028 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41917038 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41917048 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41917058 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41917068 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41917078 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41917088 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41917098 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419170a8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419170b8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419170c8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419170d8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): 415f17e0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415f17f0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415f1800 e1f470b2 e207c0ff e088f30c e92d4ff0
I/DEBUG ( 94): 415f1810 e24dd004 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415f1820 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415f1830 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415f1840 e1a01627 e1a00427 e1f470b2 e7952101
I/DEBUG ( 94): 415f1850 e200000f e207c0ff e7852100 e088f30c
I/DEBUG ( 94): 415f1860 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415f1870 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415f1880 e1d410b2 e1a00427 e1f470b4 e7952101
I/DEBUG ( 94): 415f1890 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94): 415f18a0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415f18b0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 415f18c0 e1d410b4 e1d400b2 e1f470b6 e7952101
I/DEBUG ( 94): 415f18d0 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94):
I/DEBUG ( 94): 400f5eac 00000000 7ef0001d 400f5ee4 481a53ee
I/DEBUG ( 94): 400f5ebc 4714ad38 481b1b84 00000000 418e7038
I/DEBUG ( 94): 400f5ecc 400f5f18 481a5386 4740e3a0 00000006
I/DEBUG ( 94): 400f5edc 00000000 000003e8 000003e8 418e6e38
I/DEBUG ( 94): 400f5eec 00000001 00000000 07813c20 00000000
I/DEBUG ( 94): 400f5efc 07813c20 00000000 400f5f54 4908b30c
I/DEBUG ( 94): 400f5f0c 4740e2f8 481a5386 00000000 400f5f54
I/DEBUG ( 94): 400f5f1c 000003e8 000003e8 418e6e38 00000001
I/DEBUG ( 94): 400f5f2c 00000000 07813c20 00000000 07813c20
I/DEBUG ( 94): 400f5f3c 00000000 400f5fa8 4908a8de 471fe018
I/DEBUG ( 94): 400f5f4c 4908b30c 00000000 000003e8 000003e8
I/DEBUG ( 94): 400f5f5c 418e6e38 00000001 00000000 07813c20
I/DEBUG ( 94): 400f5f6c 00000000 07813c20 00000000 41908670
I/DEBUG ( 94): 400f5f7c 07813c20 00000000 471f9128 00000000
I/DEBUG ( 94): 400f5f8c 418dcc80 00000000 400f5fd4 00000000
I/DEBUG ( 94): 400f5f9c 471fdc28 4908a8de 416a4f10 400f5fd4
I/DEBUG ( 94):
I/DEBUG ( 94): bee18a7c 00000000 00000000 00008d48 0000adf0
I/DEBUG ( 94): bee18a8c 0000adf8 0000ae00 bee18aa0 00000000
I/DEBUG ( 94): bee18a9c 4005586b 00000005 bee18bb4 bee18bcc
I/DEBUG ( 94): bee18aac bee18bd5 bee18be1 bee18bea 00000000
I/DEBUG ( 94): bee18abc bee18c00 bee18c22 bee18c5f bee18c87
I/DEBUG ( 94): bee18acc bee18c9a bee18caf bee18cca bee18cdd
I/DEBUG ( 94): bee18adc bee18cf6 bee18d10 bee18d29 bee18f23
I/DEBUG ( 94): bee18aec bee18f3c bee18f5b bee18f70 bee18f8e
I/DEBUG ( 94): bee18afc bee18fad 00000000 00000000 00000010
I/DEBUG ( 94): bee18b0c 000001d7 00000006 00001000 00000011
I/DEBUG ( 94): bee18b1c 00000064 00000003 00008034 00000004
I/DEBUG ( 94): bee18b2c 00000020 00000005 00000008 00000007
I/DEBUG ( 94): bee18b3c 40054000 00000008 00000000 00000009
I/DEBUG ( 94): bee18b4c 00008ce4 0000000b 00000000 0000000c
I/DEBUG ( 94): bee18b5c 00000000 0000000d 00000000 0000000e
I/DEBUG ( 94): bee18b6c 00000000 00000017 00000000 00000019
I/DEBUG ( 94):
I/DEBUG ( 94): bee18560 418dfcc8 00000000 00000000 400d731c
I/DEBUG ( 94): bee18570 00000003 00000001 01051730 000001bc
I/DEBUG ( 94): bee18580 41917008 41917000 00080000 41917000
I/DEBUG ( 94): bee18590 41917008 41644aad ffff0ff0 40066168
I/DEBUG ( 94): bee185a0 00000000 00080000 41917000 41646af7
I/DEBUG ( 94): bee185b0 41917000 03d75000 03d75000 00f22600
I/DEBUG ( 94): bee185c0 bee185e8 41917000 00000080 4164725b
I/DEBUG ( 94): bee185d0 0000001f 00000000 03d75000 0028b000
I/DEBUG ( 94): bee185e0 00000001 0000001f 00000000 02175000
I/DEBUG ( 94): bee185f0 00000000 00060000 00000000 41917000
I/DEBUG ( 94): bee18600 43a8c000 41997000 00f24700 00000000
I/DEBUG ( 94): bee18610 41686220 00000001 07813c20 416294c7
I/DEBUG ( 94): bee18620 fffffe44 4163ac07 00000031 418d8b60
I/DEBUG ( 94): bee18630 00f24a6c bee18629 bee18624 00f24700
I/DEBUG ( 94): bee18640 07813c20 00000000 00000000 00000000
I/DEBUG ( 94): bee18650 07813c20 00000000 000003e8 00000000
I/DEBUG ( 94):
I/DEBUG ( 94): 400a9298 e1a07001 e2603000 e213301c 0a000008
I/DEBUG ( 94): 400a92a8 e1530002 8202301c e0422003 e1b03e03
I/DEBUG ( 94): 400a92b8 28a04002 28a04002 48a04002 e1b03103
I/DEBUG ( 94): 400a92c8 24801004 e2522020 e1a03001 4a000002
I/DEBUG ( 94): 400a92d8 e2522020 e8a050fa 2afffffc e2822020
I/DEBUG ( 94): 400a92e8 e1b02e02 28a0500a 48a04002 e1b02102
I/DEBUG ( 94): 400a92f8 24801004 40c010b2 e1b02102 25c01000
I/DEBUG ( 94): 400a9308 e8bd40f1 e12fff1e f5d0f000 f5d1f000
I/DEBUG ( 94): 400a9318 e0202001 e3120003 1a000023 e2102003
I/DEBUG ( 94): 400a9328 e3c00003 e3c11003 e490c004 04913004
I/DEBUG ( 94): 400a9338 0a000006 e2222003 e1a02182 e3e034ff
I/DEBUG ( 94): 400a9348 e1a02233 e4913004 e18cc002 e1833002
I/DEBUG ( 94): 400a9358 e52d4004 e3a04001 e1844404 e1844804
I/DEBUG ( 94): 400a9368 f5d0f008 f5d1f008 e04c2004 e15c0003
I/DEBUG ( 94): 400a9378 01c2200c 01120384 0490c004 04913004
I/DEBUG ( 94): 400a9388 0afffff6 e1a00c0c e1a0c42c e3500001
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): memory map around fault addr 41917008:
I/DEBUG ( 94): 4168c000-41917000 rw- /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): (no map for address)
I/DEBUG ( 94): 4568c000-456c2000 rw- /dev/ashmem/dalvik-aux-structure (deleted)
I/ServiceManager( 88): service 'media.audio_policy' died
I/ServiceManager( 88): service 'media.audio_flinger' died
I/ServiceManager( 88): service 'media.player' died
I/ServiceManager( 88): service 'media.camera' died
I/Netd (25666): Netd 1.0 starting
W/InterfaceController(25666): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/mediaserver(25667): ServiceManager: 0x19d44b8
I/AudioFlinger(25667): Using default 3000 mSec as standby time.
E/MediaPlayerFactory(25667): calling dlopen on FACTORY_LIB
E/MediaPlayerFactory(25667): Failed to open FACTORY_LIB Error : dlopen failed: library "libdashplayer.so" not found
I/CameraService(25667): CameraService started (pid=25667)
E/HAL (25667): load: module=/system/lib/hw/camera.msm7x27.so
E/HAL (25667): dlopen failed: could not load library "libcamera.so" needed by "camera.msm7x27.so"; caused by cannot locate symbol "_ZN7android10VectorImpl19reservedVectorImpl1Ev" referenced by "libcamera.so"...
E/CameraService(25667): Could not load camera HAL module
I/AudioPolicyManagerBase(25667): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
I/AudioHardwareMSM72XX(25667): get_audpp_filter
I/AudioHardwareMSM72XX(25667): open /system/etc/AudioFilter.csv success.
I/AudioHardwareMSM72XX(25667): EQ flag = 00.
I/AudioHardwareMSM72XX(25667): Set master volume to 7.
I/AudioFlinger(25667): loadHwModule() Loaded primary audio interface from QCOM Audio HW HAL (audio) handle 1
I/AudioFlinger(25667): HAL output buffer size 1200 frames, normal mix buffer size 1200 frames
I/AudioMixer(25667): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
I/AudioFlinger(25667): Using module 1 has the primary audio interface
D/AudioHardwareInterface(25667): setMode(NORMAL)
I/AudioFlinger(25667): AudioFlinger's thread 0x40b4c008 ready to run
W/AudioFlinger(25667): Thread AudioOut_2 cannot connect to the power manager service
I/AudioHardwareMSM72XX(25667): Routing audio to Speakerphone
D/AudioHardwareMSM72XX(25667): doAudioRouteOrMute() device 0, mMode 0, mMicMute 1, mBuiltinMicSelected 0, muted
D/AudioHardwareMSM72XX(25667): setVoiceVolume(0.000000)
I/AudioHardwareMSM72XX(25667): Setting in-call volume to 1 (available range is 0 to 7)
I/audio_a2dp_hw(25667): adev_open: adev_open in A2dp_hw module
I/AudioFlinger(25667): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
I/AudioPolicyService(25667): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/AndroidRuntime(25665):
D/AndroidRuntime(25665): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime(25665): CheckJNI is OFF
D/dalvikvm(25665): Trying to load lib libjavacore.so 0x0
D/dalvikvm(25665): Added shared lib libjavacore.so 0x0
D/dalvikvm(25665): Trying to load lib libnativehelper.so 0x0
D/dalvikvm(25665): Added shared lib libnativehelper.so 0x0
D/dalvikvm(25665): No JNI_OnLoad found in libnativehelper.so 0x0, skipping init
D/dalvikvm(25665): Note: class Landroid/app/ActivityManagerNative; has 180 unimplemented (abstract) methods
E/memtrack(25665): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug(25665): failed to load memtrack module: -2
I/SamplingProfilerIntegration(25665): Profiling disabled.
I/Zygote (25665): Preloading classes...
E/cutils-trace(25665): Error opening trace file: No such file or directory (2)
V/NatController(25666): runCmd(/system/bin/iptables -F natctrl_FORWARD) res=0
V/NatController(25666): runCmd(/system/bin/iptables -A natctrl_FORWARD -j DROP) res=0
V/NatController(25666): runCmd(/system/bin/iptables -t nat -F natctrl_nat_POSTROUTING) res=0
V/NatController(25666): runCmd(/system/bin/ip rule flush) res=0
V/NatController(25666): runCmd(/system/bin/ip -6 rule flush) res=0
V/NatController(25666): runCmd(/system/bin/ip rule add from all lookup default prio 32767) res=0
V/NatController(25666): runCmd(/system/bin/ip rule add from all lookup main prio 32766) res=0
V/NatController(25666): runCmd(/system/bin/ip -6 rule add from all lookup default prio 32767) res=0
V/NatController(25666): runCmd(/system/bin/ip -6 rule add from all lookup main prio 32766) res=0
V/NatController(25666): runCmd(/system/bin/ip route flush cache) res=0
V/NatController(25666): runCmd(/system/bin/iptables -F natctrl_tether_counters) res=0
V/NatController(25666): runCmd(/system/bin/iptables -X natctrl_tether_counters) res=0
V/NatController(25666): runCmd(/system/bin/iptables -N natctrl_tether_counters) res=0
D/MDnsDS (25666): MDnsSdListener::Hander starting up
D/MDnsDS (25666): MDnsSdListener starting to monitor
D/MDnsDS (25666): Going to poll with pollCount 1
D/TextLayoutCache(25665): Using debug level = 0 - Debug Enabled = 0
I/dalvikvm(25665): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI(25665): register_android_mtp_MtpDevice
W/dalvikvm(25665): Exception Ljava/lang/UnsatisfiedLinkError; thrown while initializing Landroid/media/videoeditor/MediaArtistNativeHelper;
W/Zygote (25665): Class not found for preloading: android.media.videoeditor.MediaArtistNativeHelper
E/EmojiFactory_jni(25665): Failed to load libemoji.so: dlopen failed: library "libemoji.so" not found
I/LibraryLoader(25665): loading: webviewchromium
W/WebViewFactory(25665): error preloading provider
W/WebViewFactory(25665): java.lang.RuntimeException: Cannot load WebView
W/WebViewFactory(25665): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:32)
W/WebViewFactory(25665): at com.android.webview.chromium.WebViewChromiumFactoryProvider.<init>(WebViewChromiumFactoryProvider.java:82)
W/WebViewFactory(25665): at java.lang.Class.newInstanceImpl(Native Method)
W/WebViewFactory(25665): at java.lang.Class.newInstance(Class.java:1208)
W/WebViewFactory(25665): at android.webkit.WebViewFactory$Preloader.<clinit>(WebViewFactory.java:43)
W/WebViewFactory(25665): at java.lang.Class.classForName(Native Method)
W/WebViewFactory(25665): at java.lang.Class.forName(Class.java:251)
W/WebViewFactory(25665): at java.lang.Class.forName(Class.java:216)
W/WebViewFactory(25665): at com.android.internal.os.ZygoteInit.preloadClasses(ZygoteInit.java:291)
W/WebViewFactory(25665): at com.android.internal.os.ZygoteInit.preload(ZygoteInit.java:231)
W/WebViewFactory(25665): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:566)
W/WebViewFactory(25665): at dalvik.system.NativeStart.main(Native Method)
W/WebViewFactory(25665): Caused by: com.android.org.chromium.content.common.ProcessInitException
W/WebViewFactory(25665): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:111)
W/WebViewFactory(25665): at com.android.org.chromium.content.app.LibraryLoader.loadNow(LibraryLoader.java:79)
W/WebViewFactory(25665): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:30)
W/WebViewFactory(25665): ... 11 more
W/WebViewFactory(25665): Caused by: java.lang.UnsatisfiedLinkError: Library webviewchromium not found; tried [/vendor/lib/libwebviewchromium.so, /system/lib/libwebviewchromium.so]
W/WebViewFactory(25665): at java.lang.Runtime.loadLibrary(Runtime.java:388)
W/WebViewFactory(25665): at java.lang.System.loadLibrary(System.java:526)
W/WebViewFactory(25665): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:105)
W/WebViewFactory(25665): ... 13 more
W/Zygote (25665): Class not found for preloading: java.lang.UnsafeByteSequence
I/System (25665): Loaded time zone names for "" in 290ms (268ms in ICU)
I/System (25665): Loaded time zone names for "en_US" in 198ms (169ms in ICU)
I/Zygote (25665): ...preloaded 2776 classes in 9201ms.
I/Zygote (25665): Preload resources disabled, skipped.
D/libEGL (25665): loaded /system/lib/egl/libEGL_adreno200.so
D/libEGL (25665): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
D/libEGL (25665): loaded /system/lib/egl/libGLESv2_adreno200.so
F/libc (25665): Fatal signal 11 (SIGSEGV) at 0x419a7008 (code=1), thread 25665 (zygote)
I/DEBUG ( 94): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG ( 94): Build fingerprint: 'lge/LS670/LS670:2.3.3/GRI40/LG-LS670-V20g.19C11F164C:user/release-keys'
I/DEBUG ( 94): Revision: '0'
I/DEBUG ( 94): pid: 25665, tid: 25665, name: zygote >>> zygote <<<
I/DEBUG ( 94): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 419a7008
I/DEBUG ( 94): r0 419a7008 r1 00000000 r2 000001c8 r3 80000000
I/DEBUG ( 94): r4 00000000 r5 00000000 r6 00000000 r7 00000000
I/DEBUG ( 94): r8 41682800 r9 00000006 sl 400dbecc fp be8cfa9c
I/DEBUG ( 94): ip 00000000 sp be8cf580 lr 00000000 pc 4020d2b8 cpsr a0000010
I/DEBUG ( 94): d0 42c393484d78abc4 d1 3f50624d00000061
I/DEBUG ( 94): d2 7e37e43c8800759c d3 7e37e43c8800759c
I/DEBUG ( 94): d4 8000000000000000 d5 3fbc71c71c71c71c
I/DEBUG ( 94): d6 4a1f2640fee00000 d7 42c800004a22c000
I/DEBUG ( 94): d8 0000000000000000 d9 0000000000000000
I/DEBUG ( 94): d10 0000000000000000 d11 0000000000000000
I/DEBUG ( 94): d12 0000000000000000 d13 0000000000000000
I/DEBUG ( 94): d14 0000000000000000 d15 0000000000000000
I/DEBUG ( 94): scr 80000010
I/DEBUG ( 94):
I/DEBUG ( 94): backtrace:
I/DEBUG ( 94): #00 pc 000222b8 /system/lib/libc.so (memset+112)
I/DEBUG ( 94): #01 pc 00071aa9 /system/lib/libdvm.so (create_mspace_with_base+72)
I/DEBUG ( 94): #02 pc 00073af3 /system/lib/libdvm.so
I/DEBUG ( 94): #03 pc 00074257 /system/lib/libdvm.so (dvmHeapSourceStartupBeforeFork()+346)
I/DEBUG ( 94): #04 pc 000564c3 /system/lib/libdvm.so (dvmGcPreZygoteFork()+2)
I/DEBUG ( 94): #05 pc 00067c03 /system/lib/libdvm.so
I/DEBUG ( 94): #06 pc 000681c9 /system/lib/libdvm.so
I/DEBUG ( 94): #07 pc 000504d3 /system/lib/libdvm.so (dvmResolveNativeMethod(unsigned int const*, JValue*, Method const*, Thread*)+114)
I/DEBUG ( 94): #08 pc 00027aa0 /system/lib/libdvm.so
I/DEBUG ( 94): #09 pc 0002e9dc /system/lib/libdvm.so (dvmMterpStd(Thread*)+76)
I/DEBUG ( 94): #10 pc 0002c0bc /system/lib/libdvm.so (dvmInterpret(Thread*, Method const*, JValue*)+184)
I/DEBUG ( 94): #11 pc 00061909 /system/lib/libdvm.so (dvmCallMethodV(Thread*, Method const*, Object*, bool, JValue*, std::__va_list)+320)
I/DEBUG ( 94): #12 pc 0004a623 /system/lib/libdvm.so
I/DEBUG ( 94): #13 pc 0004e51d /system/lib/libandroid_runtime.so
I/DEBUG ( 94): #14 pc 0004f225 /system/lib/libandroid_runtime.so (android::AndroidRuntime::start(char const*, char const*)+364)
I/DEBUG ( 94): #15 pc 00001035 /system/bin/app_process
I/DEBUG ( 94): #16 pc 0000e649 /system/lib/libc.so (__libc_init+52)
I/DEBUG ( 94): #17 pc 00000d44 /system/bin/app_process
I/DEBUG ( 94):
I/DEBUG ( 94): stack:
I/DEBUG ( 94): be8cf540 4196fcc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be8cf544 416b64bb /system/lib/libdvm.so (dvmRemoveFromReferenceTable(ReferenceTable*, Object**, Object*)+8)
I/DEBUG ( 94): be8cf548 00374700 [heap]
I/DEBUG ( 94): be8cf54c 416ba62f /system/lib/libdvm.so (dvmReleaseTrackedAlloc+38)
I/DEBUG ( 94): be8cf550 4196fcc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be8cf554 00000000
I/DEBUG ( 94): be8cf558 00000388
I/DEBUG ( 94): be8cf55c 41968b98 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be8cf560 4196fcc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be8cf564 00000000
I/DEBUG ( 94): be8cf568 00000000
I/DEBUG ( 94): be8cf56c 4023b31c
I/DEBUG ( 94): be8cf570 00000003
I/DEBUG ( 94): be8cf574 00000001
I/DEBUG ( 94): be8cf578 004a1690 [heap]
I/DEBUG ( 94): be8cf57c 000001bc
I/DEBUG ( 94): #00 be8cf580 419a7008
I/DEBUG ( 94): be8cf584 419a7000
I/DEBUG ( 94): be8cf588 00080000
I/DEBUG ( 94): be8cf58c 419a7000
I/DEBUG ( 94): be8cf590 419a7008
I/DEBUG ( 94): be8cf594 416d5aad /system/lib/libdvm.so (create_mspace_with_base+76)
I/DEBUG ( 94): #01 be8cf598 ffff0ff0 [vectors]
I/DEBUG ( 94): be8cf59c 400ba168
I/DEBUG ( 94): be8cf5a0 00000000
I/DEBUG ( 94): be8cf5a4 00080000
I/DEBUG ( 94): be8cf5a8 419a7000
I/DEBUG ( 94): be8cf5ac 416d7af7 /system/lib/libdvm.so
I/DEBUG ( 94): #02 be8cf5b0 419a7000
I/DEBUG ( 94): be8cf5b4 03d75000
I/DEBUG ( 94): be8cf5b8 03d75000
I/DEBUG ( 94): be8cf5bc 00372600 [heap]
I/DEBUG ( 94): be8cf5c0 be8cf5e8 [stack]
I/DEBUG ( 94): be8cf5c4 419a7000
I/DEBUG ( 94): be8cf5c8 00000080
I/DEBUG ( 94): be8cf5cc 416d825b /system/lib/libdvm.so (dvmHeapSourceStartupBeforeFork()+350)
I/DEBUG ( 94):
I/DEBUG ( 94): memory near r0:
I/DEBUG ( 94): 419a6fe8 00000000 00000000 00000000 00000000
I/DEBUG ( 94): 419a6ff8 00000000 00000000 ffffffff ffffffff
I/DEBUG ( 94): 419a7008 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419a7018 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419a7028 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419a7038 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419a7048 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419a7058 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419a7068 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419a7078 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419a7088 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419a7098 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419a70a8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419a70b8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419a70c8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 419a70d8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94): memory near r3:
I/DEBUG ( 94): 7fffffe0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 7ffffff0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000000 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000010 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000020 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000030 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000040 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000050 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000060 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000070 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000080 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 80000090 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 800000a0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 800000b0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 800000c0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 800000d0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94): memory near r8:
I/DEBUG ( 94): 416827e0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416827f0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41682800 e1f470b2 e207c0ff e088f30c e92d4ff0
I/DEBUG ( 94): 41682810 e24dd004 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41682820 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41682830 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41682840 e1a01627 e1a00427 e1f470b2 e7952101
I/DEBUG ( 94): 41682850 e200000f e207c0ff e7852100 e088f30c
I/DEBUG ( 94): 41682860 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41682870 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41682880 e1d410b2 e1a00427 e1f470b4 e7952101
I/DEBUG ( 94): 41682890 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94): 416828a0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416828b0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416828c0 e1d410b4 e1d400b2 e1f470b6 e7952101
I/DEBUG ( 94): 416828d0 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94):
I/DEBUG ( 94): memory near sl:
I/DEBUG ( 94): 400dbeac 00000000 7ef0001d 400dbee4 481893ee
I/DEBUG ( 94): 400dbebc 4712ed38 48195b84 00000000 41977038
I/DEBUG ( 94): 400dbecc 400dbf18 48189386 473f23a0 00000006
I/DEBUG ( 94): 400dbedc 00000000 000003e8 000003e8 41976e38
I/DEBUG ( 94): 400dbeec 00000001 00000000 07813c20 00000000
I/DEBUG ( 94): 400dbefc 07813c20 00000000 400dbf54 491b330c
I/DEBUG ( 94): 400dbf0c 473f22f8 48189386 00000000 400dbf54
I/DEBUG ( 94): 400dbf1c 000003e8 000003e8 41976e38 00000001
I/DEBUG ( 94): 400dbf2c 00000000 07813c20 00000000 07813c20
I/DEBUG ( 94): 400dbf3c 00000000 400dbfa8 491b28de 471e2018
I/DEBUG ( 94): 400dbf4c 491b330c 00000000 000003e8 000003e8
I/DEBUG ( 94): 400dbf5c 41976e38 00000001 00000000 07813c20
I/DEBUG ( 94): 400dbf6c 00000000 07813c20 00000000 41998670
I/DEBUG ( 94): 400dbf7c 07813c20 00000000 471dd128 00000000
I/DEBUG ( 94): 400dbf8c 4196cc80 00000000 400dbfd4 00000000
I/DEBUG ( 94): 400dbf9c 471e1c28 491b28de 41734f10 400dbfd4
I/DEBUG ( 94):
I/DEBUG ( 94): memory near fp:
I/DEBUG ( 94): be8cfa7c 00000000 00000000 00008d48 0000adf0
I/DEBUG ( 94): be8cfa8c 0000adf8 0000ae00 be8cfaa0 00000000
I/DEBUG ( 94): be8cfa9c 400a986b 00000005 be8cfbb4 be8cfbcc
I/DEBUG ( 94): be8cfaac be8cfbd5 be8cfbe1 be8cfbea 00000000
I/DEBUG ( 94): be8cfabc be8cfc00 be8cfc22 be8cfc5f be8cfc87
I/DEBUG ( 94): be8cfacc be8cfc9a be8cfcaf be8cfcca be8cfcdd
I/DEBUG ( 94): be8cfadc be8cfcf6 be8cfd10 be8cfd29 be8cff23
I/DEBUG ( 94): be8cfaec be8cff3c be8cff5b be8cff70 be8cff8e
I/DEBUG ( 94): be8cfafc be8cffad 00000000 00000000 00000010
I/DEBUG ( 94): be8cfb0c 000001d7 00000006 00001000 00000011
I/DEBUG ( 94): be8cfb1c 00000064 00000003 00008034 00000004
I/DEBUG ( 94): be8cfb2c 00000020 00000005 00000008 00000007
I/DEBUG ( 94): be8cfb3c 400a8000 00000008 00000000 00000009
I/DEBUG ( 94): be8cfb4c 00008ce4 0000000b 00000000 0000000c
I/DEBUG ( 94): be8cfb5c 00000000 0000000d 00000000 0000000e
I/DEBUG ( 94): be8cfb6c 00000000 00000017 00000000 00000019
I/DEBUG ( 94):
I/DEBUG ( 94): memory near sp:
I/DEBUG ( 94): be8cf560 4196fcc8 00000000 00000000 4023b31c
I/DEBUG ( 94): be8cf570 00000003 00000001 004a1690 000001bc
I/DEBUG ( 94): be8cf580 419a7008 419a7000 00080000 419a7000
I/DEBUG ( 94): be8cf590 419a7008 416d5aad ffff0ff0 400ba168
I/DEBUG ( 94): be8cf5a0 00000000 00080000 419a7000 416d7af7
I/DEBUG ( 94): be8cf5b0 419a7000 03d75000 03d75000 00372600
I/DEBUG ( 94): be8cf5c0 be8cf5e8 419a7000 00000080 416d825b
I/DEBUG ( 94): be8cf5d0 0000001f 00000000 03d75000 0028b000
I/DEBUG ( 94): be8cf5e0 00000001 0000001f 00000000 02175000
I/DEBUG ( 94): be8cf5f0 00000000 00060000 00000000 419a7000
I/DEBUG ( 94): be8cf600 43b1c000 41a27000 00374700 00000000
I/DEBUG ( 94): be8cf610 41717220 00000001 07813c20 416ba4c7
I/DEBUG ( 94): be8cf620 fffffe44 416cbc07 00000035 41968b60
I/DEBUG ( 94): be8cf630 00374a6c be8cf629 be8cf624 00374700
I/DEBUG ( 94): be8cf640 07813c20 00000000 00000000 00000000
I/DEBUG ( 94): be8cf650 07813c20 00000000 000003e8 00000000
I/DEBUG ( 94):
I/DEBUG ( 94): code around pc:
I/DEBUG ( 94): 4020d298 e1a07001 e2603000 e213301c 0a000008
I/DEBUG ( 94): 4020d2a8 e1530002 8202301c e0422003 e1b03e03
I/DEBUG ( 94): 4020d2b8 28a04002 28a04002 48a04002 e1b03103
I/DEBUG ( 94): 4020d2c8 24801004 e2522020 e1a03001 4a000002
I/DEBUG ( 94): 4020d2d8 e2522020 e8a050fa 2afffffc e2822020
I/DEBUG ( 94): 4020d2e8 e1b02e02 28a0500a 48a04002 e1b02102
I/DEBUG ( 94): 4020d2f8 24801004 40c010b2 e1b02102 25c01000
I/DEBUG ( 94): 4020d308 e8bd40f1 e12fff1e f5d0f000 f5d1f000
I/DEBUG ( 94): 4020d318 e0202001 e3120003 1a000023 e2102003
I/DEBUG ( 94): 4020d328 e3c00003 e3c11003 e490c004 04913004
I/DEBUG ( 94): 4020d338 0a000006 e2222003 e1a02182 e3e034ff
I/DEBUG ( 94): 4020d348 e1a02233 e4913004 e18cc002 e1833002
I/DEBUG ( 94): 4020d358 e52d4004 e3a04001 e1844404 e1844804
I/DEBUG ( 94): 4020d368 f5d0f008 f5d1f008 e04c2004 e15c0003
I/DEBUG ( 94): 4020d378 01c2200c 01120384 0490c004 04913004
I/DEBUG ( 94): 4020d388 0afffff6 e1a00c0c e1a0c42c e3500001
I/DEBUG ( 94):
I/DEBUG ( 94): code around lr:
I/DEBUG ( 94): 00000000 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000010 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000020 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000030 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000040 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000050 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000060 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000070 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000080 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 00000090 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000a0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000b0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000c0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000d0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000e0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 000000f0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94): memory map around fault addr 419a7008:
I/DEBUG ( 94): 4171c000-419a7000 rw- /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): 4571c000-45778000 r-- /data/dalvik-cache/system@framework@conscrypt.jar@classes.dex
I/Netd (25949): Netd 1.0 starting
W/InterfaceController(25949): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/mediaserver(25950): ServiceManager: 0xa494b8
I/AudioFlinger(25950): Using default 3000 mSec as standby time.
E/MediaPlayerFactory(25950): calling dlopen on FACTORY_LIB
E/MediaPlayerFactory(25950): Failed to open FACTORY_LIB Error : dlopen failed: library "libdashplayer.so" not found
I/CameraService(25950): CameraService started (pid=25950)
E/HAL (25950): load: module=/system/lib/hw/camera.msm7x27.so
E/HAL (25950): dlopen failed: could not load library "libcamera.so" needed by "camera.msm7x27.so"; caused by cannot locate symbol "_ZN7android10VectorImpl19reservedVectorImpl1Ev" referenced by "libcamera.so"...
E/CameraService(25950): Could not load camera HAL module
I/AudioPolicyManagerBase(25950): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
I/AudioHardwareMSM72XX(25950): get_audpp_filter
I/AudioHardwareMSM72XX(25950): open /system/etc/AudioFilter.csv success.
I/AudioHardwareMSM72XX(25950): EQ flag = 00.
I/AudioHardwareMSM72XX(25950): Set master volume to 7.
I/AudioFlinger(25950): loadHwModule() Loaded primary audio interface from QCOM Audio HW HAL (audio) handle 1
I/AudioFlinger(25950): HAL output buffer size 1200 frames, normal mix buffer size 1200 frames
I/AudioMixer(25950): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
I/AudioFlinger(25950): Using module 1 has the primary audio interface
D/AudioHardwareInterface(25950): setMode(NORMAL)
I/AudioFlinger(25950): AudioFlinger's thread 0x40d56008 ready to run
W/AudioFlinger(25950): Thread AudioOut_2 cannot connect to the power manager service
I/AudioHardwareMSM72XX(25950): Routing audio to Speakerphone
D/AudioHardwareMSM72XX(25950): doAudioRouteOrMute() device 0, mMode 0, mMicMute 1, mBuiltinMicSelected 0, muted
D/AudioHardwareMSM72XX(25950): setVoiceVolume(0.000000)
I/AudioHardwareMSM72XX(25950): Setting in-call volume to 1 (available range is 0 to 7)
I/audio_a2dp_hw(25950): adev_open: adev_open in A2dp_hw module
I/AudioFlinger(25950): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
I/AudioPolicyService(25950): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/AndroidRuntime(25948):
D/AndroidRuntime(25948): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime(25948): CheckJNI is OFF
D/dalvikvm(25948): Trying to load lib libjavacore.so 0x0
D/dalvikvm(25948): Added shared lib libjavacore.so 0x0
D/dalvikvm(25948): Trying to load lib libnativehelper.so 0x0
D/dalvikvm(25948): Added shared lib libnativehelper.so 0x0
D/dalvikvm(25948): No JNI_OnLoad found in libnativehelper.so 0x0, skipping init
D/dalvikvm(25948): Note: class Landroid/app/ActivityManagerNative; has 180 unimplemented (abstract) methods
E/memtrack(25948): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug(25948): failed to load memtrack module: -2
I/SamplingProfilerIntegration(25948): Profiling disabled.
I/Zygote (25948): Preloading classes...
E/cutils-trace(25948): Error opening trace file: No such file or directory (2)
V/NatController(25949): runCmd(/system/bin/iptables -F natctrl_FORWARD) res=0
V/NatController(25949): runCmd(/system/bin/iptables -A natctrl_FORWARD -j DROP) res=0
V/NatController(25949): runCmd(/system/bin/iptables -t nat -F natctrl_nat_POSTROUTING) res=0
V/NatController(25949): runCmd(/system/bin/ip rule flush) res=0
V/NatController(25949): runCmd(/system/bin/ip -6 rule flush) res=0
V/NatController(25949): runCmd(/system/bin/ip rule add from all lookup default prio 32767) res=0
V/NatController(25949): runCmd(/system/bin/ip rule add from all lookup main prio 32766) res=0
V/NatController(25949): runCmd(/system/bin/ip -6 rule add from all lookup default prio 32767) res=0
V/NatController(25949): runCmd(/system/bin/ip -6 rule add from all lookup main prio 32766) res=0
V/NatController(25949): runCmd(/system/bin/ip route flush cache) res=0
V/NatController(25949): runCmd(/system/bin/iptables -F natctrl_tether_counters) res=0
V/NatController(25949): runCmd(/system/bin/iptables -X natctrl_tether_counters) res=0
V/NatController(25949): runCmd(/system/bin/iptables -N natctrl_tether_counters) res=0
D/MDnsDS (25949): MDnsSdListener::Hander starting up
D/MDnsDS (25949): MDnsSdListener starting to monitor
D/MDnsDS (25949): Going to poll with pollCount 1
D/TextLayoutCache(25948): Using debug level = 0 - Debug Enabled = 0
I/dalvikvm(25948): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI(25948): register_android_mtp_MtpDevice
W/dalvikvm(25948): Exception Ljava/lang/UnsatisfiedLinkError; thrown while initializing Landroid/media/videoeditor/MediaArtistNativeHelper;
W/Zygote (25948): Class not found for preloading: android.media.videoeditor.MediaArtistNativeHelper
E/EmojiFactory_jni(25948): Failed to load libemoji.so: dlopen failed: library "libemoji.so" not found
I/LibraryLoader(25948): loading: webviewchromium
W/WebViewFactory(25948): error preloading provider
W/WebViewFactory(25948): java.lang.RuntimeException: Cannot load WebView
W/WebViewFactory(25948): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:32)
W/WebViewFactory(25948): at com.android.webview.chromium.WebViewChromiumFactoryProvider.<init>(WebViewChromiumFactoryProvider.java:82)
W/WebViewFactory(25948): at java.lang.Class.newInstanceImpl(Native Method)
W/WebViewFactory(25948): at java.lang.Class.newInstance(Class.java:1208)
W/WebViewFactory(25948): at android.webkit.WebViewFactory$Preloader.<clinit>(WebViewFactory.java:43)
W/WebViewFactory(25948): at java.lang.Class.classForName(Native Method)
W/WebViewFactory(25948): at java.lang.Class.forName(Class.java:251)
W/WebViewFactory(25948): at java.lang.Class.forName(Class.java:216)
W/WebViewFactory(25948): at com.android.internal.os.ZygoteInit.preloadClasses(ZygoteInit.java:291)
W/WebViewFactory(25948): at com.android.internal.os.ZygoteInit.preload(ZygoteInit.java:231)
W/WebViewFactory(25948): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:566)
W/WebViewFactory(25948): at dalvik.system.NativeStart.main(Native Method)
W/WebViewFactory(25948): Caused by: com.android.org.chromium.content.common.ProcessInitException
W/WebViewFactory(25948): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:111)
W/WebViewFactory(25948): at com.android.org.chromium.content.app.LibraryLoader.loadNow(LibraryLoader.java:79)
W/WebViewFactory(25948): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:30)
W/WebViewFactory(25948): ... 11 more
W/WebViewFactory(25948): Caused by: java.lang.UnsatisfiedLinkError: Library webviewchromium not found; tried [/vendor/lib/libwebviewchromium.so, /system/lib/libwebviewchromium.so]
W/WebViewFactory(25948): at java.lang.Runtime.loadLibrary(Runtime.java:388)
W/WebViewFactory(25948): at java.lang.System.loadLibrary(System.java:526)
W/WebViewFactory(25948): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:105)
W/WebViewFactory(25948): ... 13 more
W/Zygote (25948): Class not found for preloading: java.lang.UnsafeByteSequence
I/System (25948): Loaded time zone names for "" in 289ms (264ms in ICU)
I/System (25948): Loaded time zone names for "en_US" in 212ms (180ms in ICU)
I/Zygote (25948): ...preloaded 2776 classes in 12100ms.
I/Zygote (25948): Preload resources disabled, skipped.
D/libEGL (25948): loaded /system/lib/egl/libEGL_adreno200.so
D/libEGL (25948): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
D/libEGL (25948): loaded /system/lib/egl/libGLESv2_adreno200.so
F/libc (25948): Fatal signal 11 (SIGSEGV) at 0x41ac3008 (code=1), thread 25948 (zygote)
I/DEBUG ( 94): pid: 25948, tid: 25948, name: zygote >>> zygote <<<
I/DEBUG ( 94): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 41ac3008
I/DEBUG ( 94): r0 41ac3008 r1 00000000 r2 000001c8 r3 80000000
I/DEBUG ( 94): r8 4179f800 r9 00000006 sl 470f8ecc fp bea25a9c
I/DEBUG ( 94): ip 00000000 sp bea25580 lr 00000000 pc 400d32b8 cpsr a0000010
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): bea25540 41a8bcc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bea25544 417d34bb /system/lib/libdvm.so (dvmRemoveFromReferenceTable(ReferenceTable*, Object**, Object*)+8)
I/DEBUG ( 94): bea25548 007f4700 [heap]
I/DEBUG ( 94): bea2554c 417d762f /system/lib/libdvm.so (dvmReleaseTrackedAlloc+38)
I/DEBUG ( 94): bea25550 41a8bcc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bea25554 00000000
I/DEBUG ( 94): bea25558 00000388
I/DEBUG ( 94): bea2555c 41a84b98 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bea25560 41a8bcc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): bea25564 00000000
I/DEBUG ( 94): bea25568 00000000
I/DEBUG ( 94): bea2556c 4010131c
I/DEBUG ( 94): bea25570 00000003
I/DEBUG ( 94): bea25574 00000001
I/DEBUG ( 94): bea25578 00921730 [heap]
I/DEBUG ( 94): bea2557c 000001bc
I/DEBUG ( 94): #00 bea25580 41ac3008
I/DEBUG ( 94): bea25584 41ac3000
I/DEBUG ( 94): bea25588 00080000
I/DEBUG ( 94): bea2558c 41ac3000
I/DEBUG ( 94): bea25590 41ac3008
I/DEBUG ( 94): bea25594 417f2aad /system/lib/libdvm.so (create_mspace_with_base+76)
I/DEBUG ( 94): #01 bea25598 ffff0ff0 [vectors]
I/DEBUG ( 94): bea2559c 400ae168
I/DEBUG ( 94): bea255a0 00000000
I/DEBUG ( 94): bea255a4 00080000
I/DEBUG ( 94): bea255a8 41ac3000
I/DEBUG ( 94): bea255ac 417f4af7 /system/lib/libdvm.so
I/DEBUG ( 94): #02 bea255b0 41ac3000
I/DEBUG ( 94): bea255b4 03d75000
I/DEBUG ( 94): bea255b8 03d75000
I/DEBUG ( 94): bea255bc 007f2600 [heap]
I/DEBUG ( 94): bea255c0 bea255e8 [stack]
I/DEBUG ( 94): bea255c4 41ac3000
I/DEBUG ( 94): bea255c8 00000080
I/DEBUG ( 94): bea255cc 417f525b /system/lib/libdvm.so (dvmHeapSourceStartupBeforeFork()+350)
I/DEBUG ( 94):
I/DEBUG ( 94): 41ac2fe8 00000000 00000000 00000000 00000000
I/DEBUG ( 94): 41ac2ff8 00000000 00000000 ffffffff ffffffff
I/DEBUG ( 94): 41ac3008 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41ac3018 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41ac3028 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41ac3038 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41ac3048 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41ac3058 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41ac3068 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41ac3078 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41ac3088 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41ac3098 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41ac30a8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41ac30b8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41ac30c8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 41ac30d8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): 4179f7e0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 4179f7f0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 4179f800 e1f470b2 e207c0ff e088f30c e92d4ff0
I/DEBUG ( 94): 4179f810 e24dd004 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 4179f820 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 4179f830 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 4179f840 e1a01627 e1a00427 e1f470b2 e7952101
I/DEBUG ( 94): 4179f850 e200000f e207c0ff e7852100 e088f30c
I/DEBUG ( 94): 4179f860 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 4179f870 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 4179f880 e1d410b2 e1a00427 e1f470b4 e7952101
I/DEBUG ( 94): 4179f890 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94): 4179f8a0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 4179f8b0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 4179f8c0 e1d410b4 e1d400b2 e1f470b6 e7952101
I/DEBUG ( 94): 4179f8d0 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94):
I/DEBUG ( 94): 470f8eac 00000000 7ef0001d 470f8ee4 482713ee
I/DEBUG ( 94): 470f8ebc 47216d38 4827db84 00000000 41a93038
I/DEBUG ( 94): 470f8ecc 470f8f18 48271386 474da3a0 00000006
I/DEBUG ( 94): 470f8edc 00000000 000003e8 000003e8 41a92e38
I/DEBUG ( 94): 470f8eec 00000001 00000000 07813c20 00000000
I/DEBUG ( 94): 470f8efc 07813c20 00000000 470f8f54 4915730c
I/DEBUG ( 94): 470f8f0c 474da2f8 48271386 00000000 470f8f54
I/DEBUG ( 94): 470f8f1c 000003e8 000003e8 41a92e38 00000001
I/DEBUG ( 94): 470f8f2c 00000000 07813c20 00000000 07813c20
I/DEBUG ( 94): 470f8f3c 00000000 470f8fa8 491568de 472ca018
I/DEBUG ( 94): 470f8f4c 4915730c 00000000 000003e8 000003e8
I/DEBUG ( 94): 470f8f5c 41a92e38 00000001 00000000 07813c20
I/DEBUG ( 94): 470f8f6c 00000000 07813c20 00000000 41ab4670
I/DEBUG ( 94): 470f8f7c 07813c20 00000000 472c5128 00000000
I/DEBUG ( 94): 470f8f8c 41a88c80 00000000 470f8fd4 00000000
I/DEBUG ( 94): 470f8f9c 472c9c28 491568de 41850f10 470f8fd4
I/DEBUG ( 94):
I/DEBUG ( 94): bea25a7c 00000000 00000000 00008d48 0000adf0
I/DEBUG ( 94): bea25a8c 0000adf8 0000ae00 bea25aa0 00000000
I/DEBUG ( 94): bea25a9c 4009d86b 00000005 bea25bb4 bea25bcc
I/DEBUG ( 94): bea25aac bea25bd5 bea25be1 bea25bea 00000000
I/DEBUG ( 94): bea25abc bea25c00 bea25c22 bea25c5f bea25c87
I/DEBUG ( 94): bea25acc bea25c9a bea25caf bea25cca bea25cdd
I/DEBUG ( 94): bea25adc bea25cf6 bea25d10 bea25d29 bea25f23
I/DEBUG ( 94): bea25aec bea25f3c bea25f5b bea25f70 bea25f8e
I/DEBUG ( 94): bea25afc bea25fad 00000000 00000000 00000010
I/DEBUG ( 94): bea25b0c 000001d7 00000006 00001000 00000011
I/DEBUG ( 94): bea25b1c 00000064 00000003 00008034 00000004
I/DEBUG ( 94): bea25b2c 00000020 00000005 00000008 00000007
I/DEBUG ( 94): bea25b3c 4009c000 00000008 00000000 00000009
I/DEBUG ( 94): bea25b4c 00008ce4 0000000b 00000000 0000000c
I/DEBUG ( 94): bea25b5c 00000000 0000000d 00000000 0000000e
I/DEBUG ( 94): bea25b6c 00000000 00000017 00000000 00000019
I/DEBUG ( 94):
I/DEBUG ( 94): bea25560 41a8bcc8 00000000 00000000 4010131c
I/DEBUG ( 94): bea25570 00000003 00000001 00921730 000001bc
I/DEBUG ( 94): bea25580 41ac3008 41ac3000 00080000 41ac3000
I/DEBUG ( 94): bea25590 41ac3008 417f2aad ffff0ff0 400ae168
I/DEBUG ( 94): bea255a0 00000000 00080000 41ac3000 417f4af7
I/DEBUG ( 94): bea255b0 41ac3000 03d75000 03d75000 007f2600
I/DEBUG ( 94): bea255c0 bea255e8 41ac3000 00000080 417f525b
I/DEBUG ( 94): bea255d0 0000001f 00000000 03d75000 0028b000
I/DEBUG ( 94): bea255e0 00000001 0000001f 00000000 02175000
I/DEBUG ( 94): bea255f0 00000000 00060000 00000000 41ac3000
I/DEBUG ( 94): bea25600 43c38000 41b43000 007f4700 00000000
I/DEBUG ( 94): bea25610 41834220 00000001 07813c20 417d74c7
I/DEBUG ( 94): bea25620 fffffe44 417e8c07 00000038 41a84b60
I/DEBUG ( 94): bea25630 007f4a6c bea25629 bea25624 007f4700
I/DEBUG ( 94): bea25640 07813c20 00000000 00000000 00000000
I/DEBUG ( 94): bea25650 07813c20 00000000 000003e8 00000000
I/DEBUG ( 94):
I/DEBUG ( 94): 400d3298 e1a07001 e2603000 e213301c 0a000008
I/DEBUG ( 94): 400d32a8 e1530002 8202301c e0422003 e1b03e03
I/DEBUG ( 94): 400d32b8 28a04002 28a04002 48a04002 e1b03103
I/DEBUG ( 94): 400d32c8 24801004 e2522020 e1a03001 4a000002
I/DEBUG ( 94): 400d32d8 e2522020 e8a050fa 2afffffc e2822020
I/DEBUG ( 94): 400d32e8 e1b02e02 28a0500a 48a04002 e1b02102
I/DEBUG ( 94): 400d32f8 24801004 40c010b2 e1b02102 25c01000
I/DEBUG ( 94): 400d3308 e8bd40f1 e12fff1e f5d0f000 f5d1f000
I/DEBUG ( 94): 400d3318 e0202001 e3120003 1a000023 e2102003
I/DEBUG ( 94): 400d3328 e3c00003 e3c11003 e490c004 04913004
I/DEBUG ( 94): 400d3338 0a000006 e2222003 e1a02182 e3e034ff
I/DEBUG ( 94): 400d3348 e1a02233 e4913004 e18cc002 e1833002
I/DEBUG ( 94): 400d3358 e52d4004 e3a04001 e1844404 e1844804
I/DEBUG ( 94): 400d3368 f5d0f008 f5d1f008 e04c2004 e15c0003
I/DEBUG ( 94): 400d3378 01c2200c 01120384 0490c004 04913004
I/DEBUG ( 94): 400d3388 0afffff6 e1a00c0c e1a0c42c e3500001
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): memory map around fault addr 41ac3008:
I/DEBUG ( 94): 41838000-41ac3000 rw- /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): 45838000-45938000 rw- /dev/ashmem/dalvik-bitmap-2 (deleted)
I/Netd (26240): Netd 1.0 starting
W/InterfaceController(26240): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/mediaserver(26241): ServiceManager: 0x1b6c4b8
I/AudioFlinger(26241): Using default 3000 mSec as standby time.
E/MediaPlayerFactory(26241): calling dlopen on FACTORY_LIB
E/MediaPlayerFactory(26241): Failed to open FACTORY_LIB Error : dlopen failed: library "libdashplayer.so" not found
I/CameraService(26241): CameraService started (pid=26241)
E/HAL (26241): load: module=/system/lib/hw/camera.msm7x27.so
E/HAL (26241): dlopen failed: could not load library "libcamera.so" needed by "camera.msm7x27.so"; caused by cannot locate symbol "_ZN7android10VectorImpl19reservedVectorImpl1Ev" referenced by "libcamera.so"...
E/CameraService(26241): Could not load camera HAL module
I/AudioPolicyManagerBase(26241): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
I/AudioHardwareMSM72XX(26241): get_audpp_filter
I/AudioHardwareMSM72XX(26241): open /system/etc/AudioFilter.csv success.
I/AudioHardwareMSM72XX(26241): EQ flag = 00.
I/AudioHardwareMSM72XX(26241): Set master volume to 7.
I/AudioFlinger(26241): loadHwModule() Loaded primary audio interface from QCOM Audio HW HAL (audio) handle 1
I/AudioFlinger(26241): HAL output buffer size 1200 frames, normal mix buffer size 1200 frames
I/AudioMixer(26241): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
I/AudioFlinger(26241): Using module 1 has the primary audio interface
D/AudioHardwareInterface(26241): setMode(NORMAL)
I/AudioFlinger(26241): AudioFlinger's thread 0x40d1a008 ready to run
W/AudioFlinger(26241): Thread AudioOut_2 cannot connect to the power manager service
I/AudioHardwareMSM72XX(26241): Routing audio to Speakerphone
D/AudioHardwareMSM72XX(26241): doAudioRouteOrMute() device 0, mMode 0, mMicMute 1, mBuiltinMicSelected 0, muted
D/AudioHardwareMSM72XX(26241): setVoiceVolume(0.000000)
I/AudioHardwareMSM72XX(26241): Setting in-call volume to 1 (available range is 0 to 7)
I/audio_a2dp_hw(26241): adev_open: adev_open in A2dp_hw module
I/AudioFlinger(26241): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
I/AudioPolicyService(26241): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/AndroidRuntime(26239):
D/AndroidRuntime(26239): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime(26239): CheckJNI is OFF
D/dalvikvm(26239): Trying to load lib libjavacore.so 0x0
D/dalvikvm(26239): Added shared lib libjavacore.so 0x0
D/dalvikvm(26239): Trying to load lib libnativehelper.so 0x0
D/dalvikvm(26239): Added shared lib libnativehelper.so 0x0
D/dalvikvm(26239): No JNI_OnLoad found in libnativehelper.so 0x0, skipping init
D/dalvikvm(26239): Note: class Landroid/app/ActivityManagerNative; has 180 unimplemented (abstract) methods
E/memtrack(26239): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug(26239): failed to load memtrack module: -2
I/SamplingProfilerIntegration(26239): Profiling disabled.
I/Zygote (26239): Preloading classes...
E/cutils-trace(26239): Error opening trace file: No such file or directory (2)
V/NatController(26240): runCmd(/system/bin/iptables -F natctrl_FORWARD) res=0
V/NatController(26240): runCmd(/system/bin/iptables -A natctrl_FORWARD -j DROP) res=0
V/NatController(26240): runCmd(/system/bin/iptables -t nat -F natctrl_nat_POSTROUTING) res=0
V/NatController(26240): runCmd(/system/bin/ip rule flush) res=0
V/NatController(26240): runCmd(/system/bin/ip -6 rule flush) res=0
V/NatController(26240): runCmd(/system/bin/ip rule add from all lookup default prio 32767) res=0
V/NatController(26240): runCmd(/system/bin/ip rule add from all lookup main prio 32766) res=0
V/NatController(26240): runCmd(/system/bin/ip -6 rule add from all lookup default prio 32767) res=0
V/NatController(26240): runCmd(/system/bin/ip -6 rule add from all lookup main prio 32766) res=0
V/NatController(26240): runCmd(/system/bin/ip route flush cache) res=0
V/NatController(26240): runCmd(/system/bin/iptables -F natctrl_tether_counters) res=0
V/NatController(26240): runCmd(/system/bin/iptables -X natctrl_tether_counters) res=0
V/NatController(26240): runCmd(/system/bin/iptables -N natctrl_tether_counters) res=0
D/MDnsDS (26240): MDnsSdListener::Hander starting up
D/MDnsDS (26240): MDnsSdListener starting to monitor
D/MDnsDS (26240): Going to poll with pollCount 1
D/TextLayoutCache(26239): Using debug level = 0 - Debug Enabled = 0
I/dalvikvm(26239): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI(26239): register_android_mtp_MtpDevice
W/dalvikvm(26239): Exception Ljava/lang/UnsatisfiedLinkError; thrown while initializing Landroid/media/videoeditor/MediaArtistNativeHelper;
W/Zygote (26239): Class not found for preloading: android.media.videoeditor.MediaArtistNativeHelper
E/EmojiFactory_jni(26239): Failed to load libemoji.so: dlopen failed: library "libemoji.so" not found
I/LibraryLoader(26239): loading: webviewchromium
W/WebViewFactory(26239): error preloading provider
W/WebViewFactory(26239): java.lang.RuntimeException: Cannot load WebView
W/WebViewFactory(26239): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:32)
W/WebViewFactory(26239): at com.android.webview.chromium.WebViewChromiumFactoryProvider.<init>(WebViewChromiumFactoryProvider.java:82)
W/WebViewFactory(26239): at java.lang.Class.newInstanceImpl(Native Method)
W/WebViewFactory(26239): at java.lang.Class.newInstance(Class.java:1208)
W/WebViewFactory(26239): at android.webkit.WebViewFactory$Preloader.<clinit>(WebViewFactory.java:43)
W/WebViewFactory(26239): at java.lang.Class.classForName(Native Method)
W/WebViewFactory(26239): at java.lang.Class.forName(Class.java:251)
W/WebViewFactory(26239): at java.lang.Class.forName(Class.java:216)
W/WebViewFactory(26239): at com.android.internal.os.ZygoteInit.preloadClasses(ZygoteInit.java:291)
W/WebViewFactory(26239): at com.android.internal.os.ZygoteInit.preload(ZygoteInit.java:231)
W/WebViewFactory(26239): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:566)
W/WebViewFactory(26239): at dalvik.system.NativeStart.main(Native Method)
W/WebViewFactory(26239): Caused by: com.android.org.chromium.content.common.ProcessInitException
W/WebViewFactory(26239): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:111)
W/WebViewFactory(26239): at com.android.org.chromium.content.app.LibraryLoader.loadNow(LibraryLoader.java:79)
W/WebViewFactory(26239): at com.android.org.chromium.android_webview.AwBrowserProcess.loadLibrary(AwBrowserProcess.java:30)
W/WebViewFactory(26239): ... 11 more
W/WebViewFactory(26239): Caused by: java.lang.UnsatisfiedLinkError: Library webviewchromium not found; tried [/vendor/lib/libwebviewchromium.so, /system/lib/libwebviewchromium.so]
W/WebViewFactory(26239): at java.lang.Runtime.loadLibrary(Runtime.java:388)
W/WebViewFactory(26239): at java.lang.System.loadLibrary(System.java:526)
W/WebViewFactory(26239): at com.android.org.chromium.content.app.LibraryLoader.loadAlreadyLocked(LibraryLoader.java:105)
W/WebViewFactory(26239): ... 13 more
W/Zygote (26239): Class not found for preloading: java.lang.UnsafeByteSequence
I/System (26239): Loaded time zone names for "" in 298ms (273ms in ICU)
I/System (26239): Loaded time zone names for "en_US" in 202ms (171ms in ICU)
I/Zygote (26239): ...preloaded 2776 classes in 11930ms.
I/Zygote (26239): Preload resources disabled, skipped.
D/libEGL (26239): loaded /system/lib/egl/libEGL_adreno200.so
D/libEGL (26239): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
D/libEGL (26239): loaded /system/lib/egl/libGLESv2_adreno200.so
F/libc (26239): Fatal signal 11 (SIGSEGV) at 0x4195b008 (code=1), thread 26239 (zygote)
I/DEBUG ( 94): pid: 26239, tid: 26239, name: zygote >>> zygote <<<
I/DEBUG ( 94): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 4195b008
I/DEBUG ( 94): r0 4195b008 r1 00000000 r2 000001c8 r3 80000000
I/DEBUG ( 94): r8 41637800 r9 00000006 sl 40088ecc fp be860a9c
I/DEBUG ( 94): ip 00000000 sp be860580 lr 00000000 pc 401302b8 cpsr a0000010
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): be860540 41923cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be860544 4166b4bb /system/lib/libdvm.so (dvmRemoveFromReferenceTable(ReferenceTable*, Object**, Object*)+8)
I/DEBUG ( 94): be860548 005ca700 [heap]
I/DEBUG ( 94): be86054c 4166f62f /system/lib/libdvm.so (dvmReleaseTrackedAlloc+38)
I/DEBUG ( 94): be860550 41923cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be860554 00000000
I/DEBUG ( 94): be860558 00000388
I/DEBUG ( 94): be86055c 4191cb98 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be860560 41923cc8 /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): be860564 00000000
I/DEBUG ( 94): be860568 00000000
I/DEBUG ( 94): be86056c 4015e31c
I/DEBUG ( 94): be860570 00000003
I/DEBUG ( 94): be860574 00000001
I/DEBUG ( 94): be860578 006f7728 [heap]
I/DEBUG ( 94): be86057c 000001bc
I/DEBUG ( 94): #00 be860580 4195b008
I/DEBUG ( 94): be860584 4195b000
I/DEBUG ( 94): be860588 00080000
I/DEBUG ( 94): be86058c 4195b000
I/DEBUG ( 94): be860590 4195b008
I/DEBUG ( 94): be860594 4168aaad /system/lib/libdvm.so (create_mspace_with_base+76)
I/DEBUG ( 94): #01 be860598 ffff0ff0 [vectors]
I/DEBUG ( 94): be86059c 400b6168
I/DEBUG ( 94): be8605a0 00000000
I/DEBUG ( 94): be8605a4 00080000
I/DEBUG ( 94): be8605a8 4195b000
I/DEBUG ( 94): be8605ac 4168caf7 /system/lib/libdvm.so
I/DEBUG ( 94): #02 be8605b0 4195b000
I/DEBUG ( 94): be8605b4 03d75000
I/DEBUG ( 94): be8605b8 03d75000
I/DEBUG ( 94): be8605bc 005c8600 [heap]
I/DEBUG ( 94): be8605c0 be8605e8 [stack]
I/DEBUG ( 94): be8605c4 4195b000
I/DEBUG ( 94): be8605c8 00000080
I/DEBUG ( 94): be8605cc 4168d25b /system/lib/libdvm.so (dvmHeapSourceStartupBeforeFork()+350)
I/DEBUG ( 94):
I/DEBUG ( 94): 4195afe8 00000000 00000000 00000000 00000000
I/DEBUG ( 94): 4195aff8 00000000 00000000 ffffffff ffffffff
I/DEBUG ( 94): 4195b008 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4195b018 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4195b028 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4195b038 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4195b048 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4195b058 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4195b068 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4195b078 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4195b088 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4195b098 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4195b0a8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4195b0b8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4195b0c8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94): 4195b0d8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): 416377e0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416377f0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41637800 e1f470b2 e207c0ff e088f30c e92d4ff0
I/DEBUG ( 94): 41637810 e24dd004 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41637820 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41637830 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41637840 e1a01627 e1a00427 e1f470b2 e7952101
I/DEBUG ( 94): 41637850 e200000f e207c0ff e7852100 e088f30c
I/DEBUG ( 94): 41637860 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41637870 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 41637880 e1d410b2 e1a00427 e1f470b4 e7952101
I/DEBUG ( 94): 41637890 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94): 416378a0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416378b0 e1a00000 e1a00000 e1a00000 e1a00000
I/DEBUG ( 94): 416378c0 e1d410b4 e1d400b2 e1f470b6 e7952101
I/DEBUG ( 94): 416378d0 e207c0ff e7852100 e088f30c e1a00000
I/DEBUG ( 94):
I/DEBUG ( 94): 40088eac 00000000 7ef0001d 40088ee4 481613ee
I/DEBUG ( 94): 40088ebc 47106d38 4816db84 00000000 4192b038
I/DEBUG ( 94): 40088ecc 40088f18 48161386 473ca3a0 00000006
I/DEBUG ( 94): 40088edc 00000000 000003e8 000003e8 4192ae38
I/DEBUG ( 94): 40088eec 00000001 00000000 07813c20 00000000
I/DEBUG ( 94): 40088efc 07813c20 00000000 40088f54 4904730c
I/DEBUG ( 94): 40088f0c 473ca2f8 48161386 00000000 40088f54
I/DEBUG ( 94): 40088f1c 000003e8 000003e8 4192ae38 00000001
I/DEBUG ( 94): 40088f2c 00000000 07813c20 00000000 07813c20
I/DEBUG ( 94): 40088f3c 00000000 40088fa8 490468de 471ba018
I/DEBUG ( 94): 40088f4c 4904730c 00000000 000003e8 000003e8
I/DEBUG ( 94): 40088f5c 4192ae38 00000001 00000000 07813c20
I/DEBUG ( 94): 40088f6c 00000000 07813c20 00000000 4194c670
I/DEBUG ( 94): 40088f7c 07813c20 00000000 471b5128 00000000
I/DEBUG ( 94): 40088f8c 41920c80 00000000 40088fd4 00000000
I/DEBUG ( 94): 40088f9c 471b9c28 490468de 416e8f10 40088fd4
I/DEBUG ( 94):
I/DEBUG ( 94): be860a7c 00000000 00000000 00008d48 0000adf0
I/DEBUG ( 94): be860a8c 0000adf8 0000ae00 be860aa0 00000000
I/DEBUG ( 94): be860a9c 400a586b 00000005 be860bb4 be860bcc
I/DEBUG ( 94): be860aac be860bd5 be860be1 be860bea 00000000
I/DEBUG ( 94): be860abc be860c00 be860c22 be860c5f be860c87
I/DEBUG ( 94): be860acc be860c9a be860caf be860cca be860cdd
I/DEBUG ( 94): be860adc be860cf6 be860d10 be860d29 be860f23
I/DEBUG ( 94): be860aec be860f3c be860f5b be860f70 be860f8e
I/DEBUG ( 94): be860afc be860fad 00000000 00000000 00000010
I/DEBUG ( 94): be860b0c 000001d7 00000006 00001000 00000011
I/DEBUG ( 94): be860b1c 00000064 00000003 00008034 00000004
I/DEBUG ( 94): be860b2c 00000020 00000005 00000008 00000007
I/DEBUG ( 94): be860b3c 400a4000 00000008 00000000 00000009
I/DEBUG ( 94): be860b4c 00008ce4 0000000b 00000000 0000000c
I/DEBUG ( 94): be860b5c 00000000 0000000d 00000000 0000000e
I/DEBUG ( 94): be860b6c 00000000 00000017 00000000 00000019
I/DEBUG ( 94):
I/DEBUG ( 94): be860560 41923cc8 00000000 00000000 4015e31c
I/DEBUG ( 94): be860570 00000003 00000001 006f7728 000001bc
I/DEBUG ( 94): be860580 4195b008 4195b000 00080000 4195b000
I/DEBUG ( 94): be860590 4195b008 4168aaad ffff0ff0 400b6168
I/DEBUG ( 94): be8605a0 00000000 00080000 4195b000 4168caf7
I/DEBUG ( 94): be8605b0 4195b000 03d75000 03d75000 005c8600
I/DEBUG ( 94): be8605c0 be8605e8 4195b000 00000080 4168d25b
I/DEBUG ( 94): be8605d0 0000001f 00000000 03d75000 0028b000
I/DEBUG ( 94): be8605e0 00000001 0000001f 00000000 02175000
I/DEBUG ( 94): be8605f0 00000000 00060000 00000000 4195b000
I/DEBUG ( 94): be860600 43ad0000 419db000 005ca700 00000000
I/DEBUG ( 94): be860610 416cc220 00000001 07813c20 4166f4c7
I/DEBUG ( 94): be860620 fffffe44 41680c07 00000039 4191cb60
I/DEBUG ( 94): be860630 005caa6c be860629 be860624 005ca700
I/DEBUG ( 94): be860640 07813c20 00000000 00000000 00000000
I/DEBUG ( 94): be860650 07813c20 00000000 000003e8 00000000
I/DEBUG ( 94):
I/DEBUG ( 94): 40130298 e1a07001 e2603000 e213301c 0a000008
I/DEBUG ( 94): 401302a8 e1530002 8202301c e0422003 e1b03e03
I/DEBUG ( 94): 401302b8 28a04002 28a04002 48a04002 e1b03103
I/DEBUG ( 94): 401302c8 24801004 e2522020 e1a03001 4a000002
I/DEBUG ( 94): 401302d8 e2522020 e8a050fa 2afffffc e2822020
I/DEBUG ( 94): 401302e8 e1b02e02 28a0500a 48a04002 e1b02102
I/DEBUG ( 94): 401302f8 24801004 40c010b2 e1b02102 25c01000
I/DEBUG ( 94): 40130308 e8bd40f1 e12fff1e f5d0f000 f5d1f000
I/DEBUG ( 94): 40130318 e0202001 e3120003 1a000023 e2102003
I/DEBUG ( 94): 40130328 e3c00003 e3c11003 e490c004 04913004
I/DEBUG ( 94): 40130338 0a000006 e2222003 e1a02182 e3e034ff
I/DEBUG ( 94): 40130348 e1a02233 e4913004 e18cc002 e1833002
I/DEBUG ( 94): 40130358 e52d4004 e3a04001 e1844404 e1844804
I/DEBUG ( 94): 40130368 f5d0f008 f5d1f008 e04c2004 e15c0003
I/DEBUG ( 94): 40130378 01c2200c 01120384 0490c004 04913004
I/DEBUG ( 94): 40130388 0afffff6 e1a00c0c e1a0c42c e3500001
I/DEBUG ( 94):
I/DEBUG ( 94):
I/DEBUG ( 94): memory map around fault addr 4195b008:
I/DEBUG ( 94): 416d0000-4195b000 rw- /dev/ashmem/dalvik-zygote (deleted)
I/DEBUG ( 94): 456d0000-45706000 rw- /dev/ashmem/dalvik-aux-structure (deleted)
I/Netd (26525): Netd 1.0 starting
W/InterfaceController(26525): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/mediaserver(26526): ServiceManager: 0x11f44b8
I/AudioFlinger(26526): Using default 3000 mSec as standby time.
E/MediaPlayerFactory(26526): calling dlopen on FACTORY_LIB
E/MediaPlayerFactory(26526): Failed to open FACTORY_LIB Error : dlopen failed: library "libdashplayer.so" not found
I/CameraService(26526): CameraService started (pid=26526)
E/HAL (26526): load: module=/system/lib/hw/camera.msm7x27.so
E/HAL (26526): dlopen failed: could not load library "libcamera.so" needed by "camera.msm7x27.so"; caused by cannot locate symbol "_ZN7android10VectorImpl19reservedVectorImpl1Ev" referenced by "libcamera.so"...
E/CameraService(26526): Could not load camera HAL module
I/AudioPolicyManagerBase(26526): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
I/AudioHardwareMSM72XX(26526): get_audpp_filter
I/AudioHardwareMSM72XX(26526): open /system/etc/AudioFilter.csv success.
I/AudioHardwareMSM72XX(26526): EQ flag = 00.
I/AudioHardwareMSM72XX(26526): Set master volume to 7.
I/AudioFlinger(26526): loadHwModule() Loaded primary audio interface from QCOM Audio HW HAL (audio) handle 1
I/AudioFlinger(26526): HAL output buffer size 1200 frames, normal mix buffer size 1200 frames
I/AudioMixer(26526): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
I/AudioFlinger(26526): Using module 1 has the primary audio interface
D/AudioHardwareInterface(26526): setMode(NORMAL)
I/AudioFlinger(26526): AudioFlinger's thread 0x40d31008 ready to run
W/AudioFlinger(26526): Thread AudioOut_2 cannot connect to the power manager service
I/AudioHardwareMSM72XX(26526): Routing audio to Speakerphone
D/AudioHardwareMSM72XX(26526): doAudioRouteOrMute() device 0, mMode 0, mMicMute 1, mBuiltinMicSelected 0, muted
D/AudioHardwareMSM72XX(26526): setVoiceVolume(0.000000)
I/AudioHardwareMSM72XX(26526): Setting in-call volume to 1 (available range is 0 to 7)
I/audio_a2dp_hw(26526): adev_open: adev_open in A2dp_hw module
I/AudioFlinger(26526): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
I/AudioPolicyService(26526): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/AndroidRuntime(26524):
D/AndroidRuntime(26524): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime(26524): CheckJNI is OFF
D/dalvikvm(26524): Trying to load lib libjavacore.so 0x0
D/dalvikvm(26524): Added shared lib libjavacore.so 0x0
D/dalvikvm(26524): Trying to load lib libnativehelper.so 0x0
D/dalvikvm(26524): Added shared lib libnativehelper.so 0x0
D/dalvikvm(26524): No JNI_OnLoad found in libnativehelper.so 0x0, skipping init
D/dalvikvm(26524): Note: class Landroid/app/ActivityManagerNative; has 180 unimplemented (abstract) methods
E/memtrack(26524): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug(26524): failed to load memtrack module: -2
