I'll check frija tool also , your welcome!I can't find the verizon firmware and samfirm doesn't show it. I really appreciate the help, I'll check back tomorrow.
Which is your model number , ultra and s20+ are different and won't workI thought I needed the sm-g981u? Will the 988 work since its for the Ultra?
So you need to have your mosel number, plus and ultra will not workI have the s20, not the +
You check frija tool , similar to samfirm?Right, I need the sm-g981u vzw which I can't find. Samfirm tool doesn't work since I can't get it to update.
Use sprint since it's CDMA like VerizonFrija works much better than Samfirm but no VZW firmware, TMB and SPR do show firmware to download. Which CRC should I use since VZW doesn't show up?
Let's see what happens, don't the regular s20 not have sd card ?I really hope this works. Check your voicemail by dialing your own phone number lately? That's what I've been forced to do, I forgot how much of a pain that is! If this doesn't take I think I'm going to sell this and just get a Verizon phone. I considered doing that in the first place but the Verizon version doesn't have an sd card, seems crazy but there are tons of negative reviews on the phone on Verizons page due to it.
Wow, I didn't know they can go as far as that to alter it .They do, mine does, but from what I read Verizon had theirs made without it. If you check the reviews on the s20 in the Verizon store they are all mostly 1 star due to their version of the phone being the only one that doesn't have it and people didn't realize it until after the purchase.
You going to unlocked model or staying on carriers?Nothing happened that time, just got error message "Failed! SHA256 is invalid". Phone restarts just like nothing happened.
Ok so the firmware you download wasI was trying the Sprint version of the firmware. I just want my Verizon features to work, wifi calling and visual voicemail, if that means unlocked or sprint it doesn't matter to me.
Volume down and power button , js download modeHeld up volume and power until recovery screen came up, went to "bootloader" which brings up a download screen and connected to Odin V3.14.4. I need to get the older odin version?
