Need some help!
ReiMei
71
3
I recent flashed CM9 on my Epic, and I love the ICS experience. But I've ran into a problem; the rom is said to work completely with 3g and 4g from sprint. Which is great and all, but my phone is flashed to cricket. And while my sms, mms, and voice services work perfectly I don't have any data connection.
Any ideas guys?
ReiMei
71
3
Thank you it works. Sort of. It says I have 1x right now but that'll work I suppose. :3
Edit: After playing around I found out that if you open the voice dialer and say"Open APNS" You can enter the apn manually which is probably your best bet. Google search the APN of your carrier and enter it and save it, and you'll be good to go. My 3g works perfectly now.
Reactions: jmuru
justinedwards
