Need your Help
WillaHorton
Is Wikipedia reliable source for the information?
Moderator Note: I deleted the link since it was incorrect and could possibly lead to another source.
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
If you are looking for scholarly citation sources then Wikipedia is not a good place to look for information. Schools typically will ask that you limit sources from Wikipedia or other similarly types of online websites. If you are researching or looking for information for reference then yes, it's a good place to look. I'll suggest accompanying Wikipedia information with factual or accepted references.
Moderator Note: I deleted the URL since it was incorrect, and possibly leads to another source rather than Wikipedia.
cottoneyejoe
