Do you usually get 3 hours of screen time?Yes, loving the battery life. Not my heaviest day but not bad and still 65% left.
http://tapatalk.imageshack.com/v2/15/04/07/895758fdba6ae5db96f23d704d454f25.jpg
Higher. I reset the statistics recently but the screen time is creeping back up. Usually around 4 hours.Do you usually get 3 hours of screen time?
Just curious, I usually get low 3s. might be because I use survey panel apps to get a few extra bucks I downloaded the battery monitoring app to test it.Higher. I reset the statistics recently but the screen time is creeping back up. Usually around 4 hours.
Thanks all..now everytime I click the volume rocker...I can't help but notice the volume indicator being off center. :-!
So does lollipop 5.0 for the gs5 not have multiple users option? I have only seen it for the gs5 LTE-A so far.
My S5 is working pretty great! I only have a couple problems, like wifi won't connect or I lose all my phone signal after switching from wifi to data. All my problems are solved by restarting my phone though.
Yup. I did a full reset and it took care of a couple of the issues like overheating and battery issues. Honestly, alot of the problems seemed to come from apps that just were optimized for 5.0. They just didn't want to work. If you do a full reset immediately after upgrading, I think you'll be fine.that's slightly disconcerting. did you do a factory reset after upgrading? i was hoping that 100% of the issues would have been resolved by now, but i guess i can live with small issues here and there. thanks for the reply by the way
