Nexus S 4G ICS Bugs
johnb0072
65
I was wondering if anyone else is randomly getting no more room on this home screen pop ups? Its occurred at various times in various apps and I have no idea why.
fomotomo
53
Do you mean when you first download from play store or w/e its called?
Sent from my Nexus S 4G using Tapatalk 2
johnb0072
65
I mean sometimes on home screen..sometimes while reading the paper...when a page is loading its really random it doesn't seem to affect anything but its getting annoying.
Blatz32
Does anyone here have an issue while entering a contact to SMS or MMS? When I enter a contact, instead of recognizing my contacts, it enters what I have then sends the cursor back to the beginning of the field. It continues to do so when I try to erase what it accepts. Very stubborn and very frustrating. Does this make sense to anyone?
skidmark
356
I have had the same issue as well. I feel better that I am not the only one, and at the same time annoyed that we are having this problem.
markinbright
5
Crazy thing . . . When I dial phone numbers, every now and then it will dial one of the speed dial widgets from my home screen instead. So basically dial the wrong number. I swear it's happened when dialing other contact widgets and when manually dialing numbers. It's only happened a handful of times, and I can't make it happen on purpose so I'm not sure how to diagnose. Anyone else?
Skunkape60
4,460
344
To stop this from happening, open the play store app. Menu/settings/Deselect auto add widgets.
____________________
Just Flash It !!!
Reactions: arrasmith
wmurch3
374
6
I am having an issue where I take a few pictures and it will completely die and I have to do a battery pull to get the phone working again. Sometimes it will be okay for a few pictures but after about 4 in a row it will just go completely black. :(
v8mustang
20
Not sure if this has been reported yet.
Every time I want to copy a text or edit a text message in SMS, it would edit/copy a text message older than the ones I want to copy.
For example,
Text Msg 1
Text Msg 2
Text Msg 3
Text Msg 4
Text Msg 5
I wanted to copy Text Msg 4, it would copy Text Msg 2 or Text Msg 3. Same thing with forwarding.
Did anyone experience the same problem? Kinda annoying....
wmurch3
374
6
Signal has been the major problem for the nexus s after ICS update and some users are going back to the ginger bread.
Signal has always been bad with this phone, even on GB. I've always had less than 2 bars even when I'm in the next room from my router. Pretty sure it's hardware but I could be wrong.
docgoat1987
153
7
I hope the bug will be fixed ive noticed the wifi signal doesnt show all the bars it should be and i have a wireless n router regular signal is ok bar wise another bug is my stock browser is messed up and even using chrome sometimes messes up it will become unresponsive at time also i was playing with the exposure settings on camera app and went to take a pic and phone shut off had to pull the battery also the phone will only charge on a samsung charger or a htc charger no other charger works to charge it on gb i could use any charger now i cant
Phones battery sucks mine will only charge to 94 % then it says its charged i pull it off and still 94% plug it in and stops at 94 again
I love this ice cream sandwich but i hope they send out a fix for all the issues cause according to phonearena.com sprint put the nexus on the end of life list so i hope that since its a google phone they will send us an update for the fixes
Sent from my Nexus S 4G using Android Central Forums
Skunkape60
4,460
344
The 94% max charge is the most you can get and it won't be fixed because that's how it's designed.
_______________
Just Flash It !!!
jvai
145
anyone having applications that were installed in gingerbread, not working on the "Ice Cream Sandwich" ics upgrade?
i paid for spades king & loved it..
after the ics update, it won't load, instead i get a very fast closing pop-up reading "unfortunately spades king has stopped" .. going into the app, the option to move it to usb storage is greyed out ...
multiple un-installs / re-installs doesn't help... i've long ago wrote the devs about the issue -
Thank you for contacting Android Support for Magmic products. Your request (Ticket #119186) has been updated. You can also add a comment by replying to this email.
Queue Wait Time: *LOW*. You should expect a response within 1 to 2 business days, but it may be less.
Below you will find all the info relevant to your Support Ticket:
Ticket Subject: Spades King
Ticket ID: 119186
Comments:
Justin Price, Apr 17 09:23 (EDT):
Hi,
Thanks for your valuable feedback.
I've included this in a report for our developers to further investigate and will reply as soon as I hear from them.
We apologize for any inconvenience.
Regards
Justin Price
Customer Support
Summer_glow
