Note 3 - While wireless charging phone won't ring
ezridermn
3
I have a Note 3 that I charge wirelessly on a Samsung S Charger Pad. I have noticed when the phone is on the charger pad it won't ring even though there are a couple of reception bars displayed. When I miss a call and someone leaves a voicemail the voicemail notification does come through. I would appreciate any advice you might have on how I can correct this problem. Thanks.
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Do you experience any connection issues even when the phone is not charging? If so, then that might be your problem.
cottoneyejoe
