ottscay
When I do that it boots up, but if I hit power and volume down I get the option to boot into recovery mode.
I wonder if I have to have Enable OEM unlocking.
I'm sure you don't have to enable OEM unlocking to sideload an OTA - I just did it last night. Starting from the beginning (in case I've misunderstood where you are having problems):
You should be holding down power and both up and down volume to enter recovery (alternatively you can use the "adb reboot recovery" command if it's connected to the computer). From there you use the volume controls to select the "Recovery" option, and then you should see the little android with a red exclamation mark. From there you hit "power" and "volume" simultaneously to bring up the menu of choices in tiny font, and choose "apply update from adb". You should see little yellow text towards the bottom that saying it's waiting for a command. Then (if you aren't already) plug your phone in to the usb cord and use the "adb sideload YourFileName.zip" command. That should be it - if nothing happens, it may be that your device's driver ID when in recovery isn't set correctly (this happened to me - you can confirm while using the "adb devices" command while the phone is still in recovery mode).
If that's the case (i.e. your device isn't recognized) you need to follow these instructions:
You don't even have to reboot, just make sure the device is being recognized afterward ("adb devices") and then retype your "adb sideload ...." command. It takes a while to verify and install the file, but it should all run by itself at that point.
