TrikkJames
Umm.... Most of the recoveries used on the OV and OS could be considered dead projects. Zengarden is no longer under development either. The only one currently being worked on are needed to be able to flash Cm 11. I could recommend Techvendetta's TWRP but If he's not trying to flash kitkat it's a bit more complicated With its os2sd options. I've had better luck with COT than zengarden in the past and if the situation calls for it COT's fix boot loop option is far more reliable than zengardens
Sent from my XT907 using Tapatalk
Okay? I meant dead as in the download links are all corrupt now. Website is gone, people who made it are impossible to talk to, all posts and threads point to the same dead links, etc.
I didn't mean to say dead as in development. Anyway I actually TRIED to get COT (I was actually looking for ZenGarden, just got the names switched) and nowhere I went would have it available.
I think I've honestly tried COT before. Don't remember why I hated it. I just knew that ZenGarden worked wonders compared to literally every other recovery, and I could finally have a partitioned sdcard and working mass storage while in recovery. And of course it's a touch recovery too.
