I don't think the results were that significant and the V20 may have done better in some aspects.... I'd have to go back and look.
It's definitely low output so it would not make sense to run high impedance headphones with it off.
But that is NOT what Mike Dee1 says? So high impedance and low impedance are exactly the same within the same model for sound accurate quality? There is nothing different except the higher impedance model just has more volume through the DAC than the lower impedance version based on a voltage difference?It's all about power, milliwatts in this case, and the headphone's sensitivity measure in decibels per milliwatt. If both types of headphones have the same sensitivity, then they will produce exactly the same sound pressure level at the same power input. A given power can be achieved in two ways; high voltage and low current or low voltage and high current, the power output and resulting sound pressure level will be the same. Once again, there is nothing inherently "better" about high impedance phones vs low impedance phones.
You have been up front on your beliefs . I think that you are only looking to peck away at Mikes honest opinion for his own sound opinions. He has a claimed to been a "audio engineer" in the past. Everybody has a different opinion on sound quality as you know...First of all, sound quality is entirely subjective, only you can decide what sounds good to you.
For the sake of this argument lets say we have a set of Beyer DT880 headphones which is available in 32, 250 and 600 ohm models and each model has the same sensitivity, it will produce a sound output of 96 decibels (how loud it is) at 1 milliwatt of power (1/1000th of a watt). Delivering 1 milliwatt of power into 32 ohms takes .178 volts, delivering the same 1 milliwatt into 250 ohms requires .500 volts, and 1 milliwatt into 600 ohms requires .775 volts. In other words, to produce the exact same 100 decibels of sound out of a 32, 250, or 600 ohm headphone requires .178, .500 or .775 volts respectively. All the V20 is doing when it senses a high impedance headphone is turming up the gain (output voltage) by a fixed relative amount to compensate for the higher impedance so you get roughly the same sound level as a low impedance headphone. When you adjust the volume on the phone, you are just adjusting its voltage output. Even turned all the way up, most phones simply can't produce enough voltage to make a high impedance headphone get very loud, the V20 can. The actual sound quality in terms of distortion and noise the V20 produces is essentially the same regardless.
That said, another factor that hasn't been discussed is the maximum current the headphone amp can produce before distortion occurs, because of the interconnected relationship between voltage, power, impedance and current, current output is more of a concern when driving low impedance phones. Suffice it to say that the V20 can produce enough current to drive low impedance phones to the point of being uncomfortably loud.
So if I buy a 250 ohm set of headphones for my V20. The volume will just be louder than a low impedance of the same brand of headphone?
Anyone else suddenly Get a headache?
I just lower the volume and then it subsides
I meant with your conversation. It's all over my head lol
