I downloaded Touchdown (the correct version) on Sunday. I had the settings so that I would be notified via vibration, not sound, upon any incoming emails or reminders and it had been working perfectly. It was working just fine for the first 24 hours, then something weird happened.
I had it plugged in to my usb on my laptop and all of a sudden it was vibrating like 3 or 4 times per message or reminder, instead of just once (it was driving me nuts too hearing it vibrate so much). Then I noticed that the battery % had not changed in like 30 minutes while the lightning bolt was showing on the battery meter. When I went to pick up the phone it was very hot, and my battery meter program said ?overheating?. So I immediately unplugged and shut down my device.
Ever since then, my vibration function does not work ? even for the native HTC Inbox.
I even just uninstalled Touchdown and vibration still does not work on the native inbox.
What can i do?
What can i do?
