Why does my battery settings say battery usage is not available?
david juarez2
7
For some reason when I try to go check my battery settings it says battery usage not available I think it started to happen after I did a security update because I remember it used to not say that and yes I have tried wiping the cache partition but still no luck I'm running Android Oreo 8.1
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,745
113
Did you just finish charging the phone? Battery stats usually aren't available for a little while after the phone has finished charging. It need some time to start estimating charge remaining based on current usage patterns.
tress
