So I recently realized that snapchat is using like 10 times the data it used to use and alot more battery drain with it even on my sony z3 having the power saving mode active that it only runs when the screen is on. I did downgrade it to 8.1.2 but then got the error that I'm using an older version and I had to update in order to log in.
Running stock android 4.4.4 (never updated to the newest system as I did not want to)
Thanks
EDIT: I should mention I am in no way wanting to root my device or anything of that kind.
Thanks
