A AC Question Aug 6, 2015 #1 Looking at getting a new phone. I really like the note edge but scared it wont be supported down the road because verizon removed it off its site. Which one should i get?
Almeuit Moderator Team Leader Moderator Apr 17, 2012 32,277 23 0 Visit site Aug 6, 2015 #2 That is a hard question to answer as phone choices are personal choices. Go with the one that you like the most / fit your needs. Upvote 0 Downvote
A ATLBRAVES12 New member Jul 15, 2015 4 0 0 Visit site Aug 6, 2015 #3 do you think the note edge will get the updates on verizon? Upvote 0 Downvote
