Cannot identify the cause of high battery drain.
drarkayl
49
I have a Huawei Mate 10 pro and have been using it for about 9 months.
I used to have amazing battery life with close to 8-9 hours of SOT ( and still had like 20% remaining never really went too low).
Recently I have been getting a battery drain of over 20% per night even if the phone is in doze mode.
I tried every method of finding out the battery drain and could not find it, assuming its a system bug i reset the phone but it did not fix anything.
I have wifi scanning and data always on turned off , so it disconnects mobile data and wifi if the phone is not being used.
I have just factory reset my phone and am posting screenshots of all my battery monitoring.
https://imgur.com/a/vfa4SGo
Please help me identify what is causing this battery drain.
The basic GSAM stats:
The individual app view( this says this list only accounts for 7.8% of battery consumed, it got covered by that notification)
the doze stats:
GSAM graph: (cannot explain the battery drain during doze)
The BBS stats
Thank you. And to confirm, the WiFi and data settings you mention above are not new settings? You had them switched off in the same way before the high overnight drain started?
yes, those settings were always off, those aren't recent changes.
what's confusing me the most that gsam can't account for the battery drain.
It’s telling you that 19% of the battery charge was used overnight, and that the phone radio and WiFi together used 87% of that; but you mean that you can’t see how that can have happened, given Doze and the switched-off Settings you mentioned earlier?
From the graph, something is obviously repeatedly happening under Active throughout the night, and it’s that that’s baffling you?
yes exactly, every-time I pick up the phone I can see it connect to wifi/mobile data which clearly turns off when i stop using the phone.
Here is the screenshot of the phone signal :
There isn't even a case of a low signal where its needs to be amplified
The phone radio is using 80% of the battery usage. that tells me that you have a weak signal, and that's causing the drain. (If the received signal is weak, it's assumed that the phone's signal at the tower will be weak, so the phone radio is transmitting at, probably, its highest power.)
Either you put the phone down in a dead spot at night (and a dead spot can be a few inches in diameter), or you're using the wrong carrier. Install LTE Discovery and see what the signal strength is. (The number should be 100 or smaller - it's a negative number, so the smaller the number, the stronger the signal.)
Here is the screenshot from LTE discovery
One of the packages in Android OS may be the cause of the trouble...some app requesting location or trying to sync or something. I once experienced unexplained repeated overnight drain, and after several days eventually tracked it down through the system packages to a security app, which, though not set by me to do so, was performing a scan at the same odd time - 06.12 or similar - every day. Easily fixed once I knew what it was.
how do I go around tracking android packages? any specific app or process I should follow?
Its a fresh factory reset phone right now, I should do this before installing any more apps.
I would look at anything you recently added , like a app or application . In doze mode to go down 20 percent is a lot.
Ok so now you have to go on a fresh start see where things will go on battery life.
I'm going to keep my phone on airplane mode while I sleep tonight and see what stats I can record.
Let's see if there could be another issue apart from Wifi or phone signal.
I had done similar experiments in the past and I usually lost 1% on airplane mode in 10 hours.
Keep everything normal no airplane mode to see the whole thing and monitor it
Keeping everything normal is what's giving me the battery drain in the screenshots. These screenshots were taken after the factory reset.
I need to pin point the exact cause of the drain.
I understand, but u just did factory reset and have only 2 apps let's monitor it like this
I just opened Android OS in the battery stats and judged which were the most likely packages.
I stress, it’s not Android OS which is to blame, but - in my case at least - an app requesting something or other and the OS then granting that, as it’s designed to do.
One other questions , how long ago you did the factory reset ? You still seeing this kind of drain after factory reset and 2 apps installed ? I just want make sure I'm following what your saying so I can better assist you.
mohitsl
