I just purchased the extended battery for the droid bionic today. I put it in and immediately went to my wall charger to charge it up. I was having issues during charging where the phone would become unresponsive after a while and a black screen remained. A battery pull would fix it. This happened 4 or 5 times in the 3 or so hours it took to charge to 100%. Additionally, the phone would lockup at random times after use (screen would freeze, power button would shut off screen, but never truly lock the phone). Also, i was having some issues with my network connection, and only getting 4G for a while, and speedtest not working. I tried my original battery, and every single problem stopped, even speedtest was running fine. I have it in my phone now, and things seem to be running smoothly... ok never mind, it just locked up.
i have simi battery widget on my homescreen that points to battery info, and at 100% charge the extended battery is showing about 4.15V, which seems a bit high, since the specs are 3.7 and most bionic batts run at 3.8 nominally.
I am also rooted using psouza4's rooting tool. I used tibackup to freeze several apps on Cory's "safe to freeze" list.
shoot, its actually locked up on standard battery now. If anyone techy enough can drop some knowledge or theories about the effects of switching out batteries on the stability of the operating phone, please drop me a reply.
TY in adv,
P.S. Everything has been withing expected norms until the first battery swap, thus my hypothesis that the battery is the culprit.
TY in adv,
