jadaloves
Well I got it stop force closing, and it comes up. But it won't accept my yahoo emails. Any solution to this?
Thanks again!
Thanks again!
Thanks again!
If I am coming from a stock ROM, do I need to wipe data/factory reset. If so will it cause me to lose all apps, email, etc...?
Downloading this now...just finished upgrading to EE4. Is this a straightforward install? or will I need more apps other than ODIN?
kejar31, I added Mediahub with the toolbox, and it says I added MusicMod but I sure as heck don't see it. Any ideas what I may have done wrong? Even when I go and try to re-install MusicMod again, it tells me it is already installed. I'm lost.
BTW, I love this ROM. 110%.
Anyway to add backup assistant to the toolbox ???
I just tested the install of mediahub and it worked fine
Try to uninstall it through the toolbox and reinstall it again
Do you still have to wipe everything if you already have gummy 1.5?
