Bad cellular signal is the most common overheating for me. Other than that, rouge app? Look at your battery usage. Post it too.
I had that issue too. I ended up doing a factory reset and setting it up as a new device (without restoring from backup). I know it's a pain to do that but now my phone is like a brand new device. Great battery life and doesn't heat up even here at work on the very edge of a signal where it's always searching.It's really nice to get a full work day out of a battery for a change. Might be worth a try for you.What would cause this? My battery life has been horrible today and now i notice my power button is real hot to the touch
My pics are backed up on several cloud services and I just re-dowloaded all the apps myself. That was the part that was a pain. Took awhile to download them all but it was worth it to fix the issues on my phone. Phone is awesome now!But if you set it up as a new device and dont restore aren't you losing your pics and apps?
