When ever i go on the internet without wifi, it says my data is switched off, but it has always been switched on! Help!
This. Also, make sure you are in a coverage area with data. Keep in mind that sometimes you may need to toggle airplane mode on/off to regain data if the device was in a non-service area.Go to settings,data usage, and turn mobile data on
Sent from Samsung Z1 GPE on T-Mobile
I got it sorted out, it turned out i had a problem with my sim card.
