i have set up a pattern type lock into my phone, now i forgot it,, is there any way to remove that lock, any legit way or hack?
what are the different ways?
thanks
thanks
Google Account Recovery will send your login and password to your base email account.forgot password in my mobile android ssk...email ang password
If you signed in to Google account on your phone you can use Android Device Manager to reset the password: https://www.google.com/android/devicemanager?hl=en
If you didn't sign in, then you will have to factory reset your phone by booting into recovery, its different for each phone so Google it.
Yes.will this delete "ALL" data? emails, pics, contacts, messages.
thanks
