Re: System update question
Are you sure it's a system update and not a policy update pushed by your company wifi? If a certificate or administrator was installed to be able to access the network they are able to push these and there is no way to block them other than disabling the certificates or administrator privileges (which would keep u ounfdom accessing the network).
it is a system update, my company has nothing to do with this. It has happened other places also.
That's odd because system updates will only warn you not to unplug or do it with a low battery, never not to disconnect from a network.
Depending on your carrier/model some updates might be mandatory no matter what option you've set in your settings, but these are rare.
What you turned off was auto update of apps from the Play store. What you got was an update for Android, which is usually from Samsung. Different process, different app. You can delay Android updates, but only so many times, then it just updates without asking. Your best bet is after delaying the update the first time, when you're going to be home for a while, plug in the charger and do a system update. (It has to be at least 24 hours since the last one was delayed or you'll be told that the phone is up to date.)
Oh crap. Yeah sorry, forgot that the option to not check for updates was removed from the system options! They'll ask you when it's available and not autodownload though
1 Attachment(s)
Originally Posted by
SpookDroid Oh crap. Yeah sorry, forgot that the option to not check for updates was removed from the system options! They'll ask you when it's available and not autodownload though
Depending on the phone that option is now available in the Developer Options.
Attachment 294287
Confirmed it's there for Sammy phones
1 Attachment(s)
I have an S9+ unlocked and I have to go to software in setting to find if I have a system update, even though I have it scheduled for a 2 am download, then I awake to a notiifcation of the system update, but it usually doesn't download it.
I have to manually check for the update, but why would it worry you that much since they usually take no longer than 15 minutes at best to download and install.
Attachment 294288
