I just think for a device with over a 5.7 inch screen size that retails for $599, it should automatic that is has a higher resolution than 1080p. I'm not knocking honor here but I am knocking Huawei for it. I really wanted a Mate 9 but at that price point it should be a given that it have a high resolution. If the Huawei side truly wants to officially hit the US and I mean all the major carriers like their plan is do, then they will never fully over take Samsung like I've been saying they will for a long while now if they don't step up in that department. Sure the Mate 9 probably has a awesome battery life but I'm still stuck on $600 dollars on what, a 5.9 inch screen and it be the same resolution as the $350 dollar Honor 8 and 9. That was a corner that should not have been cut to me personally. I'm quite sure things like that will change once Huawei Honor officially connects with the US market and carriers or especially the Huawei side since it's branded as their flagship side and honor being their budget side. Time will tell
