Hi,
I've recently got a Huawei P20 Pro and it's not receiving any ring notifications when someone rings my ring.com doorbell..
I've had a few instances where the notification has come through as it should, but literally 99% of the time i don't receive any notifications at all.
I've ran through all the steps outlined in their guide (
https://support.ring.com/hc/en-us/ar...ndroid-Devices) but none of it has made any difference.
I have checked all permissions, notification settings, disabled them, re-enabled them, cleared cache, cleared data, deleted the app, re-installed, set the "App Launch" options to allow to run in the background - all to no avail.
Got another phone (Samsung S7 Edge) set-up to receive the same notifications from the same doorbell - and that's receiving all of them absolutely fine.
My P20 Pro is running EMUI 8.1.0 and Android version 8.1.0.
I've raised a support ticket with Ring.com, but thought i'd also post here - as it seems likely this may be a P20-specific issue..
