mjs2011
I'm working on some but it's taking a bit. Theming for cm9 is different than cm7
Sent from my LS670 using Tapatalk 2
Cool thanks! I remember being a big fan of your cm7 themes.
Kraven, is there going to eventually be a release with such a wide variety in settings, like in CM7? Referring more to the customization settings.
Far as I know there's only 2 ics roms and there both in alpha
Did anyone accomplish wifi tethering with this ROM? I do not use it that much but I know some people like to have this working. You can do it with existent ROMs except this one, but this is the first ICS ROM I tried.
Anyone know if a10 works on the OV? If so is there a button fix too?
Stuff is slowly making it's way into cm9.
You can try Reloaded. Now i won't support any bugs from using it.
[DEV] Reloaded ICS 1.9b4-050712 | CyanogenMod 9 UI Enhancements | All phones - xda-developers
I'm not gonna answer this one. Read the thread. Didn't you use the search button?
Oh you mean the crappy search?
Sent from my LS670 using Android Central Forums
