[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
Can we get a VMfix for alpha10F or does test3 one works for a10F?
The current vmfix worked for me.
Edit: I just noticed flashing the old vmfix breaks phone app and causes it to fc. Sorry as I don't have minutes on my phone and didn't notice. But I just flash my wife's ov and she has minutes lol.
Thanks, if i remember correctly, i can change carrier name with cm9 reloaded, thanks again :D
There's a VM fix in the second post. Read before typing.
Anyways, installed on my Optimus V, with the keyswap from a few posts back, and all of the 5/10 fixes in the 2nd post, and videocam illusion is installed. Everything appears to be working and it feels more responsive than the last version. I just installed it (dirty, at that) so I can't tell anyone if it's stable or not. That will take a day of real world usage.
first your job it's awesome :):):)
and i have a question
i got flash player for ARMv6 and install but doesn't work, but with CM7 if it worked
i have this rom CM9 Alpha 10.
is there any way that flash player work with this ROM?
please answer :D :D
Because it's ics. The hacked version isn't the latest flash that supports ics
. Read the adobe flash changelogs.
You will need to find at least a hacked arm 6 version 11.1.115.7 for ics
Reactions: Va1ha11a
Whenever I flash a kernel that isn't built into the rom, it breaks my wifi (blacks out the option in Settings and sticks trying to initialize). Anyone have any idea what would cause this?
knock on wood, no problems at all...before flashing kernels I usually wipe cache/ dalvic cache
Added a test 10 kernel to post 2. Mainly memory management additions. Fixes data use cap and clock lags (maybe).
The powerbutton reboot menu/screen off dance is back. Prior to this fix, if I longpressed the powerbutton, the reboot menu came up. Now, it'll bring up the reboot menu AND turn the display off. This was fixed in a10d, if my memory serves me correctly.
OK thanks, I'll revert some of the ramdisk changes.
Edit. Try this boot.img below for unbroadcasted wifi.
turned my router off broadcast SSID and then forgot my network in phone settings. I then could not save the network. I then flashed the boot.img and can now connect to wifi that isn't broadcasting SSID. test on two different phones.
That happened to me before the kernel update. So it was broken before it in a10f as well. But I agree it seemed fixed in a10d.
Edit: just long pressed the power button to make sure and I don't get a menu/display dance anymore :D
Kraven: no problems her after flagging you're latest kernel update :-) no lag, all's smooth and no wifi problems yet.
Sent from my LS670 using Android Central Forums
Reactions: Buddlespit
+1
Same here. Clock is still drifting though :(
tvelez83
