chris20nyy
If it gets you through the day without an issue who cares? Seriously, you don't need the phone to last longer while its able to be on the charger while you sleep. I'm sorry but unless the phone dies on you during the day than there's no reason to be upset. I quoted you because it helps make my point but I am not actually singling you out.
Sent from my Motorola Droid Turbo
Because he didn't buy the phone under the pretense of "getting through the day". Lots of phones get through the day.
The KILLER spec on this phone was supposed to be the battery life. The enticement here is that if you CANT get to a charger within the day, or need to go beyond, you could make it because it should achieve 48 hour usage. If you're just making it through the day, well then in the situation however rare it may be that you can't charge it's going to let you down.
You're mentality towards it is like buying a car that supposedly does 0-60 in 4 seconds, finding out it does it in 10 seconds, but settling because eventually it gets you to 60.
