speedlever
Trusted Member
I'm using what is here:
https://forums.androidcentral.com/e...ed any difference on my phone in either case.
None of these work for me. I've tried several different APN settings some found here some elsewere. NXTGENPHONE, ATT HSPA+, ATT PHONE, ATT WAP none work. Tried rebooting each and tried each with SIM slot 2. Called ATT today they gave me one to try and checked the imei number. Said it was provisioned and good to go. I have an ATT SIM card new less then a year ago working in a Blackberry Priv 4g with no issues. After all that still "H" no 4G. ???? Any ideas. I'm ready to sell this and go back to my Blackberry.
Have you tried getting a new sim card? I have had no issues on ATT at all.
That's correct. Those settings exactly. Nothing. My device has been unlocked. If that has an effect
Hmm. I just tried something. After changing my access point Name and APN settings back to ATT phone and phone respectively, I now see LTE in the notification bar. However, using LTE Discovery, it still shows I'm on Band 17.
One other thing I noticed is that with the recommended settings from the AT&T link above (access point name: NXTGENPHONE and APN: NXTGENPHONE), I couldn't get the speedtest.net app to work. It said something about connection difficulties (and yet I've noticed no difference in service). But once I change the access point name and APN back to the original settings (ATT phone and phone respectively), the Speedtest app worked and LTE shows in the notification bar.
I'm not sure what to make of that. But, I would suggest that you change your access point name and APN to:
APN: phone
and see if that makes any difference for you.
Well, the OP phones are all unlocked, fwiw (not tied to any carrier).
I'm stumped as to your problem. Have you posted over on the OnePlus Reddit? Talked to OP customer support?
https://www.reddit.com/r/oneplus/
https://forums.androidcentral.com/e...%3A%2F%2Foneplus.net%2Fsupport&token=CGedzL2P
How would the OP know whether he has a USA or a China version then? While there must be a method to the madness, it certainly doesn't make any sense to me that OP would give two different phones the same model number.
