try to get repo from here
I had an issue getting it from the tutor place and couldn't get an init
Code:curl https://dl-ssl.google.com/dl/googlesource/git-repo/repo > ~/bin/repo chmod a+x ~/bin/repo
The problem is that the custom carrier label is a two part commit. You need to pull in the other part that goes in /packages/apps/CMParts/whatever
alright it finished compiling. but no .zip. do i have to zip it all up?
EDIT: I zipped it up and get a huge .zip file. Its like 565 mb. What happened haha?
What command did you use to compile? If you use make bacon, it will give you a couple of zips.
On the build/envsetup.sh did you select optimus v?
Of course i did lol
I haven't done a build for ever, but isn't there an option to build all devices? I was wondering if you accidentally selected that instead of the ov
make clobber && make clean
im running make otapackage instead and if it doesnt work im done. im sick of all these stupid errors im getting on linux
Some say warning then i cant catch the rest because it goes to fast. heres one i got on a screen shot.
FRAMEWORKS_BASE_SUBDIRS := \
$(addsuffix /java, \
core \
graphics \
location \
media \
opengl \
sax \
telephony \
wifi \
vpn \
keystore \
voip \
+ omapmmlib \
I posted about that error a few pages back. You might want to research this thread a bit to see how we work around certain peculiarities when building.
The omap error is fixed by applying the following fix, you want to add the + line (removing the + of course):
Code:FRAMEWORKS_BASE_SUBDIRS := \ $(addsuffix /java, \ core \ graphics \ location \ media \ opengl \ sax \ telephony \ wifi \ vpn \ keystore \ voip \ + omapmmlib \ )
Let us know if you get other errors, let us know what they are, and we will try to help.
Patience is definitely one of the keys to building Android!
How do I do this?
Sorry, I left out the filename: /build/core/pathmap.mk
Look for the section I posted above, and add the line with the + (leaving out the + of course).
Note- I edited the above post so others won't be confuse.
It worked. First build is done. It came out with 2 .zip files. which do I use the cyanogen or the IHO or are they both the same.
